Results 1 to 13 of 13
Thread: Backup Restore 32bit to 64bit
19-04-2012, 15:14 #1
-= TeamSpeak User =-
- Oct 2011
- 5
Hello.
I was hosting a teamspeak server
It was on windows xp 32 bit, Now i want to run it on Windows Server 64 bit
But I cant restore the backup
I tried searching over the internet but didnt found something that could work.
Is there any way to restore it?
Thankyou for helping.
19-04-2012, 15:20 #2
-= TeamSpeak Guru =-
- May 2010
- 6,372
Your backup is :
- Server folder copy ?
- Database copy ?
- Snapshot file ?
Please be more specific about your problem
19-04-2012, 15:39 #3
- Oct 2011
- 5
I have the whole folder, I'm trying to replace the ts3server.sql file
Here's the snapshot.
http://i.imgur.com/eXCVQ.png
19-04-2012, 15:42 #4
- May 2010
- 6,372
But what do you mean by "I can't restore the backup"
By default in your case, you just have to copy/paste the ts3server.sqlitedb file and files folder into your new server folder.
19-04-2012, 15:42 #5
-= TeamSpeak Fanatic =-
- Jan 2010
- Location
- Secret Base in Arctic Region
- 1,187
You should use the server-64bit-binary then.
Transfer of the database shouldnt be a problem, just copy yolur sqlite db to your new server.
/* edit
Seems, that Mods are favored here when posting
19-04-2012, 15:52 #6
- Oct 2011
- 5
http://forum.teamspeak.com/showthrea...e-on-64Bit-TS3
This thread helped me!
Its working now.
Thanks anyways!
22-06-2012, 01:24 #7
- Jun 2012
- 4
Ts3 server downgrade 64bit to 32bit
Dear Teamspeak team,
I'm running a ts3 64 server. Because of "new" hardware, a downgrade is necessary from 64bit to 32bit.
There are many threads about upgrades (32bit to 64bit). I noticed, the database should't be changed to upgrade, but for downgrades this way doesn't working. I think i have to change my database before running my old preferences on the new server, right? (like a complete read and a complete write in a 32bit achitecture).
Are there other problems which i have to solve and how can i rebuild my db?
Thanks for your help!!
p.s. sry for my very bad english
lordjimh
22-06-2012, 07:58 #8
-= TeamSpeak Team =-
- Jun 2008
- 7,763
NPL License (Registration)
22-06-2012, 10:18 #9
- Jun 2012
- 4
i said about nothing about my systems because i think i can't start a 64bit application on every 32bit system
however i've got windows 7 ultimate on my source system (64bit) and i'm running windows 7 ultimate (32bit) on my destination system.
22-06-2012, 10:38 #10
- Jun 2008
- 7,763
http://forum.teamspeak.com/showthrea...759#post312759
Post #4 helps here.
and you are right, the 64 bit server wont work on a 32 bit system
22-06-2012, 10:49 #11
- Jun 2012
- 4
i tryed to copy my database and my files folder. my ts3 32 starts perfectly but i can't connect. if i delete my old database and restarting my server, there is no connection problem. thats the reason, why I posted here, and why i tought there is a difference between the 32bit database and die 64bit database
22-06-2012, 10:50 #12
- Jun 2008
- 7,763
Please checkyour server logs. I guess there is a warning or error.
Or maybe the ports need to forwared to a new ip?---------------------------------------------------------
22-06-2012, 10:55 #13
- Jun 2012
- 4
damn i'm soooo stupid..... i forgot to copy my licence.....i'm ashamed..... sry!!!
many thanks for your perfekt help!!!!!
lordjimh
Restore channel backup
By Creativeee in forum ToolsReplies: 1Last Post: 27-11-2011, 08:46 -
32Bit migrate on 64Bit TS3
By SoundY in forum Linux / FreeBSDReplies: 4Last Post: 18-08-2011, 17:41 -
[Solved] 32bit/64bit Help
By LANapalooza in forum Server SupportReplies: 2Last Post: 07-07-2010, 08:26 -
32bit db on 64bit server
By The_bad_Frag in forum WindowsReplies: 3Last Post: 19-03-2010, 23:49 -
backup/restore of client files
By F6Hawk in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 03-06-2008, 13:29
