Results 1 to 8 of 8
Thread: Insufficient Group Modify Power
23-04-2012, 13:33 #1
-= TeamSpeak User =-
- Apr 2012
- 4
Hi.
When I try to create a group, i can do it just fine. But when I'm adding that group as "Guest", "Normal" or "ServerAdmin" I get that error: Insufficient Group Modify Power
What can I do?
I can acess the server query, is there a way to change the permissions?
23-04-2012, 13:47 #2
-= TeamSpeak Guru =-
- May 2010
- 6,372
The Insufficient group modify power means that the i_permission_modify_power permission in a group is less than the Grant value or there is no Grant value.
Check it
23-04-2012, 15:43 #3
- Apr 2012
- 4
23-04-2012, 15:47 #4
- May 2010
- 6,372
For my understanding:
You are in which group ?
What do you mean exactly by But when I'm adding that group as "Guest", "Normal" or "ServerAdmin" ?
Do you mean using the type select box (...will be set as) ?
23-04-2012, 15:50 #5
- Apr 2012
- 4
23-04-2012, 16:20 #6
- May 2010
- 6,372
Do you try with the Advanced Permission system (Settings > Options) ?
Are you only in this group ?
Could you provide a permission overview from you (right click on you > Permissions > Permission Overview > export as pdf)
23-04-2012, 17:32 #7
- Apr 2012
- 4
Thanks for helping.
Here it is, the PDF.perm.pdf
[B][QUOTE=florian_fr40;313204]Do you try with the Advanced Permission system (Settings > Options) ?
--- Merged ---
I already archieved it! Thanks!
But do you know how i can change the server admin password?Last edited by florian_fr40; 24-04-2012 at 07:14.
23-04-2012, 20:28 #8
-= TeamSpeak Fanatic =-
- Jan 2010
- Location
- Germany
- 2,039
Yes, by searching the Forums
Doing so would've given you this
[Resolved] Channel admin cannot set subscribe power: insufficient permission modify power
By Westingham in forum Permission SystemReplies: 5Last Post: 24-02-2012, 08:40 -
By HxCRobb in forum Permission SystemReplies: 1Last Post: 07-12-2011, 19:01 -
Editing Group Auto Update Type - Insufficient Group Modify Power
By Sheps in forum Permission SystemReplies: 3Last Post: 07-07-2011, 23:25 -
Modify Power insufficient
By kyanos in forum Permission SystemReplies: 2Last Post: 08-01-2011, 19:36 -
[Solved] insufficient group modify power
By MrT99 in forum Permission SystemReplies: 16Last Post: 01-03-2010, 17:30
