Results 1 to 15 of 15
Thread: Changing port and IP
30-04-2012, 18:50 #1
-= TeamSpeak User =-
- Apr 2012
- 8
I wonder how I change the default ports to my teamspeak 10011, 9987, 30033, 41144, 2010, 2008 because I need to switch to the firewall to fit.
I wonder how I call one another teamspeak ip inside my machine for bind
30-04-2012, 20:21 #2
-= TeamSpeak Fanatic =-
- Jan 2010
- Location
- Germany
- 2,038
You can change the former 3 with command line parameters (See server_quickstart.txt in the docs Folder).
As for the latter 3 those are fixed and cannot be changed. The 41144 one is used for the Serverlist which you can disable for every virtual server (Edit Virtual Server -> More -> Misc -> Enable Reporting to Web Server List) and once none of the Virtualservers are reporting the port should not be used after restarting the instance.
The last two ports are used for Licensing / Accounting Server Connections if my memory serves me correcty.
30-04-2012, 20:50 #3
- Jan 2010
- Location
- Catalunya
- 2,330
Don't change these ports:
41144(TCP in) ...TSDNS
2010(UDP out) ...Weblist
2008(TCP out) ...Accounting
02-05-2012, 08:22 #4
-= TeamSpeak Lover =-
- Oct 2010
- 78
If you have many problems
Other suggestion is to buy a server from a Authorized Hoster http://hosting.teamspeakusa.com/
It's very easy, you forget about the configuration and they do everything for you !!! think that your pc will rest and won't be conected 24/7, it's very expensive to have that.
02-05-2012, 12:54 #5
- Apr 2012
- 8
Thank you for helping me more than I had put a rule in the firewall and the icons are gone there I set up according to one email teamspeak and the icons did not return for some people, can you help me? Have rebooted the machine, teamspeak and so far nothing ..
02-05-2012, 14:43 #6
- Jan 2010
- Location
- Catalunya
- 2,330
Any error message ?
02-05-2012, 15:10 #7
- Apr 2012
- 8
<11:09:48> The icon for the server group "ƒк ✖ ✖ ℓ (994)" was not found.
02-05-2012, 15:58 #8
Is the icon stored on the server or your local machine? If local machine, your clients wont see it.
02-05-2012, 17:05 #9
- Apr 2012
- 8
Already got it, how do I change my teamspeak ip to another in my machine because it is opening on all ip's ..
02-05-2012, 23:51 #10
- Jan 2010
- Location
- Germany
- 2,038
Commandline Parameters.
Read server_quickstart.txt in the docs Folder.
03-05-2012, 18:29 #11
- Apr 2012
- 8
How do I put a limit of 30 slots in a 30 teamspeak and another for anyone to change the value of slots?
03-05-2012, 18:41 #12
- Jan 2010
- Location
- Catalunya
- 2,330
Right click on the server name, (top of the channels tree)
Edit virtual server > Maximum Clients ...
03-05-2012, 19:16 #13
- Apr 2012
- 8
Yes is more for my clients.
04-05-2012, 03:41 #14
- Apr 2012
- 8
but then they are going to be able to change the slots Qro q I do not understand they change?
04-05-2012, 09:30 #15
- Jan 2010
- Location
- Catalunya
- 2,330
They can do it only if this permission is enabled, in their server group: b_virtualserver_modify_maxclients
edit by mod
Please edit your older post (if no new post from another user has been send meanwhile)
Sucha deleted post filles the thread with useless posts :-/Last edited by dante696; 04-05-2012 at 09:55.
Tutorial: Windows server setup + port forwarding + port changing!
By bladecx321 in forum WindowsReplies: 1Last Post: 02-05-2012, 08:12 -
Changing port
By st0ne in forum WindowsReplies: 1Last Post: 29-10-2011, 11:00 -
[Resolved] Changing TSDNS port
By erikz in forum Linux / FreeBSDReplies: 2Last Post: 15-06-2011, 15:56 -
changing default port
By MrTee in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 29-03-2004, 22:10
