Results 1 to 12 of 12
05-05-2012, 16:47 #1
-= TeamSpeak User =-
- May 2012
- 5
Permanent noise after I unplug the microphone
Hello everyone,
TS works fine so far. The only problem is, after unplugging the microphone there is a permanent static noise on the channel wich disturbes my TS friends.
Any ideas where this permanent noise comes from? Right now it only helps to plugin the microphone back. But keeping it plugged is no solution for me
05-05-2012, 17:08 #2
Does muting your mic in ts fix the problem?
05-05-2012, 18:09 #3
- May 2012
- 5
Hello there, yes it does, but is not really an option... it was possible to plug of the micro w/o any noise and now I have that. I wonder if its TS related or if its WIN7/ulitmate 64bit related
09-05-2012, 09:56 #4
-= TeamSpeak Team =-
- Jun 2008
- 7,764
I can imagine, that the default device does change under windows and maybe this input device does send that noise.
Or the port, where you pllug in your microphone is broken? < If that noise does sound electronicLast edited by dante696; 10-05-2012 at 07:30.
NPL License (Registration)
09-05-2012, 16:42 #5
- May 2012
- 5
09-05-2012, 16:58 #6
-= TeamSpeak Fanatic =-
- Jan 2010
- Location
- Germany
- 2,039
Do you have a TV Card in your PC?
09-05-2012, 20:38 #7
- May 2012
- 5
10-05-2012, 07:33 #8
- Jun 2008
- 7,764
Does not mean, that you would have a general problem, but it could be, that your input is broken somehow. This can happen
And have you checked what recording device is selected under windows, when you unplug the the headset?---------------------------------------------------------
10-05-2012, 18:57 #9
- May 2012
- 5
Damn, I guess I found the error. I am using an USB Audio Stick in parallel (Multimedia Center PC) and the Microphone Audio In of that stick took over TS since I only defined "standard" in the record settings for the microphone. Now I am using the Front Audio and it seems to be ok when plugging off - doing so results in "microphone offline" since the USB Stick does not interfere any more.
Hooray... thanks for helping me to brainstorm!
11-05-2012, 02:01 #10
Thanks for posting your solution. Glad you are no longer having a problem.
11-05-2012, 08:35 #11
- Jun 2008
- 7,764
LOL so post #4 was the answer here
The default device under windows has changed.
11-05-2012, 19:27 #12
It's often the simplest solution...
Microphone noise being detected
By RioTaRD in forum [TeamSpeak 2] Client SupportReplies: 7Last Post: 23-05-2008, 23:18 -
non microphone statis noise
By xevean in forum [TeamSpeak 2] Client SupportReplies: 3Last Post: 12-01-2007, 12:37 -
Permanent ban
By St33pNoW in forum [TeamSpeak 2] Client SupportReplies: 7Last Post: 10-10-2005, 18:53 -
Memory access Violation when I unplug my joystick
By Balthzar in forum [TeamSpeak 2] Client SupportReplies: 0Last Post: 09-03-2004, 01:12
