Results 1 to 5 of 5
    May 2012
    11
    Solved Editing Mic Click Sound Files
    Hi everyone, I've downloaded some radio bleeps which I plan to replace the mic click files with. Firstly, I opened up TS and enabled the mic clicks to ensure it works before I start changing anything (which it does). Then I replace the two files located in: G:\Program Files\TeamSpeak 3 Client\sound\default now I open up TS again and make sure the mic clicks are enabled but there is no noise being made by myself or other users in terms of mic clicks, not even the old sounds, just no noise at all.....
    Anyone got any ideas of what i'm doing wrong?
    Jan 2010
    1,286
    Hello.
    New sounds are wav files too?
    Have you tried testing them?
    Settings --> Options --> Notifications --> +Special --> Select any 'Mic xxxx' sound and 'Play' button
    Greetings.
    May 2012
    11
    Yep, doesn't work. The files are both .wav
    Jan 2010
    Catalunya
    2,330
    Look at the files names: mic_click_??.wav / mic_click_other_??.wav / mic_click_self_??.wav
    In the Default folder there is a file named settings.ini, where you can see the same file(mic_click_??.wav) is used for all cases (mic_click_other_??.wav or mic_click_self_??.wav). You need to change this.
    May 2012
    11
    Problems fixed now, I solved it myself thanks.
  1. [Resolved] Sound pack default_speech's mic click is invalid.
    By Coryf88 in forum Bug Reports
    Last Post: 06-09-2011, 08:15
  2. [solved] click sound when keying up
    By slopland in forum Windows
    Last Post: 30-07-2010, 08:14
  3. Wierd click sound and sound turn-off!
    By naitsirk in forum [TeamSpeak 2] Client Support
    Last Post: 14-06-2009, 17:36
