Results 1 to 2 of 2
    Mar 2012
    18
    channel_icon_id problem (out of range)
    If i set icon 2682757409, server reports me channel_icon_id=-1612209887, but works correctly. Is it my problem or a bug? If not a bug, how correctly convert reported negative icon_id to icon_id i was asking to set (positive) to check if they are equal
    I think it is int datatype range problem (signed int_4 \ unsigned int_4) which is limited to 2147483647, but when client uploads icon, it gives it name in unsigned int_4, and when I set channel_icon_id, I have to use unsigned int_4 icon_id, but when i ask for channel info, i receive signed int_4 value, so, I think, it is a bug.
    3.0.5 amd64
    login *** ***
    use sid=1
    channeledit cid=36 channel_icon_id=2682757409
    channelinfo cid=36
    error id=0 msg=ok  (17 ms)
    error id=0 msg=ok  (2 ms)
    error id=0 msg=ok  (13 ms)
    pid=34 channel_name=WG\sAlly\sattacks channel_topic=WG_STATUS <....> channel_icon_id=-1612209887
    error id=0 msg=ok  (42 ms)
    Total: 74 ms
    Simply, I have a PHP script that sheduled in a cron and changes channel names and icons depending on current WOW Tol-barad and Wintergrasp locations statuses.
    For this problem I get current icon Id with this function:
    Maybe there is a more right way? ^-)
    //Tested only on amd64 pratform!
    //PHP 5.3
    //Example:
    //      $s_icon_id = uint_cor($chan['channel_icon_id']);
    // string uint_cor(string)
    function uint_cor($s_int)
    $i = floatval($s_int);
    if ($i < 0) return (string)bindec(substr(decbin($i),-32));
    else return $s_int;
    Edit by a moderator
    Please no bump posts.
    UPD. Please, say "Bugfix is planned" or "It's normal, it's not a bug because..."
    Jun 2008
    7,762
    Thisi no bug, that need to be fixed, it's a normal behavior.
    The Icons ID is genrated with a CRC32 check and result is a 32Bit unsigned value (0 up to 4.294.967.295) , but the server does use 32Bit signed(−2.147.483.648 up to 2.147.483.647).
    The negative value appears, when the generated Icon ID is 2.147.483.648 or higher.
    NPL License (Registration)
  1. [Resolved] ServerQuery channel_icon_id problem
    By devour in forum Linux / FreeBSD
    Last Post: 26-01-2012, 09:02
  2. banning by ip range!
    By Slicky456 in forum Server Support
    Last Post: 08-05-2011, 17:56
  3. IP Range Banning
    By Confedorate in forum [TeamSpeak 2] Server Support
    Last Post: 24-02-2005, 20:34
