Results 1 to 5 of 5
Thread: Router problems
    Aug 2003
    Canton, MI
    Router problems
    I am running Windows XP and Cookies are enabled I have tried disableing my internet security and nothing works I am on version 2.0.19.40, my sound card is a 32MB creative labs audigy sound blaster PCI, the game I am trying to use is Planet Side, when I run the server no one outside of my LAN can join I have tried port triggering and I am not 100% sure if I am doing it right.
    When I go to my port triggering page I have 4 boxes to fill in one is the application name I put "server.ini" in that box and then I got trigger port range has 2 boxes I put the numbers 8767 in both those boxes (they are seperated by a "~") and 2 more boxes where I put the number 8767 (seperated by a "~") labled incoming port range.
    Server Log says:
    -------------- log started at 15-08-03 16:29 -------------
    15-08-03 16:29:47,ALL,Info,server, Server init initialized
    15-08-03 16:29:47,ALL,Info,server, Server version: 2.0.19.40 Win32
    15-08-03 16:29:47,WARNING,Info,SQL, created table ts2_servers
    15-08-03 16:29:47,WARNING,Info,SQL, created table ts2_channels
    15-08-03 16:29:47,WARNING,Info,SQL, created table ts2_clients
    15-08-03 16:29:47,WARNING,Info,SQL, created table ts2_channel_privileges
    15-08-03 16:29:47,WARNING,Info,SQL, created table ts2_server_privileges
    15-08-03 16:29:47,WARNING,Info,SQL, created table ts2_bans
    15-08-03 16:29:47,ALL,Info,server, Starting server with port: 8767
    15-08-03 16:29:47,WARNING,Info,SERVER, Default Server created
    15-08-03 16:29:47,WARNING,Info,SERVER, admin account info: username: ******* password: ******
    15-08-03 16:29:47,WARNING,Info,SERVER, superadmin account info: username: ************* password: *******
    15-08-03 16:29:47,ALL,Info,server, Server init finished
    16-08-03 01:26:45,ALL,Info,server, Server shutdown initialized
    16-08-03 01:26:48,ALL,Info,server, Server shutdown finished
    --------------- log ended at 16-08-03 01:26 --------------
    -------------- log started at 16-08-03 01:27 -------------
    16-08-03 01:27:52,ALL,Info,server, Server init initialized
    16-08-03 01:27:52,ALL,Info,server, Server version: 2.0.19.40 Win32
    16-08-03 01:27:52,ALL,Info,server, Starting server with port: 8767
    16-08-03 01:27:52,ALL,Info,server, Server init finished
    16-08-03 02:09:31,ALL,Info,server, Server shutdown initialized
    16-08-03 02:09:34,ALL,Info,server, Server shutdown finished
    --------------- log ended at 16-08-03 02:09 --------------
    -------------- log started at 16-08-03 03:10 -------------
    16-08-03 03:10:37,ALL,Info,server, Server init initialized
    16-08-03 03:10:37,ALL,Info,server, Server version: 2.0.19.40 Win32
    16-08-03 03:10:37,ALL,Info,server, Starting server with port: 8767
    16-08-03 03:10:38,ALL,Info,server, Server init finished
    16-08-03 03:11:08,ALL,Info,server, Server shutdown initialized
    16-08-03 03:11:11,ALL,Info,server, Server shutdown finished
    --------------- log ended at 16-08-03 03:11 --------------
    -------------- log started at 16-08-03 11:58 -------------
    16-08-03 11:58:35,ALL,Info,server, Server init initialized
    16-08-03 11:58:35,ALL,Info,server, Server version: 2.0.19.40 Win32
    16-08-03 11:58:35,ALL,Info,server, Starting server with port: 8767
    16-08-03 11:58:35,ALL,Info,server, Server init finished
    16-08-03 12:05:10,ALL,Info,server, Server shutdown initialized
    16-08-03 12:05:12,ALL,Info,server, Server shutdown finished
    --------------- log ended at 16-08-03 12:05 --------------
    16-08-03 12:05:12,ALL,Info,server, Server shutdown initialized
    16-08-03 12:05:14,ALL,Info,server, Server shutdown finished
    -------------- log started at 16-08-03 15:10 -------------
    16-08-03 15:10:50,ALL,Info,server, Server init initialized
    16-08-03 15:10:50,ALL,Info,server, Server version: 2.0.19.40 Win32
    16-08-03 15:10:50,ALL,Info,server, Starting server with port: 8767
    16-08-03 15:10:51,ALL,Info,server, Server init finished
    16-08-03 15:29:25,ALL,Info,server, Server shutdown initialized
    16-08-03 15:29:27,ALL,Info,server, Server shutdown finished
    --------------- log ended at 16-08-03 15:29 --------------
    -------------- log started at 17-08-03 00:12 -------------
    17-08-03 00:12:42,ALL,Info,server, Server init initialized
    17-08-03 00:12:42,ALL,Info,server, Server version: 2.0.19.40 Win32
    17-08-03 00:12:42,ALL,Info,server, Starting server with port: 8767
    17-08-03 00:12:42,ALL,Info,server, Server init finished
    17-08-03 02:02:12,ALL,Info,server, Server shutdown initialized
    17-08-03 02:02:14,ALL,Info,server, Server shutdown finished
    --------------- log ended at 17-08-03 02:02 --------------
    -------------- log started at 17-08-03 23:00 -------------
    17-08-03 23:00:51,ALL,Info,server, Server init initialized
    17-08-03 23:00:51,ALL,Info,server, Server version: 2.0.19.40 Win32
    17-08-03 23:00:51,ALL,Info,server, Starting server with port: 8767
    17-08-03 23:00:51,ALL,Info,server, Server init finished
    17-08-03 23:52:00,ALL,Info,server, Server shutdown initialized
    17-08-03 23:52:02,ALL,Info,server, Server shutdown finished
    --------------- log ended at 17-08-03 23:52 --------------
    -------------- log started at 18-08-03 01:46 -------------
    18-08-03 01:46:45,ALL,Info,server, Server init initialized
    18-08-03 01:46:45,ALL,Info,server, Server version: 2.0.19.40 Win32
    18-08-03 01:46:46,ALL,Info,server, Starting server with port: 8767
    18-08-03 01:46:46,ALL,Info,server, Server init finished
    18-08-03 02:03:37,ALL,Info,server, Server shutdown initialized
    18-08-03 02:03:40,ALL,Info,server, Server shutdown finished
    --------------- log ended at 18-08-03 02:03 --------------
    if you want to see a pic of my port triggering screen I can e-mail it to you. (in case I sounded drunk when I was explaining that part)
    Jun 2002
    Ontario, Canada
    911
    Do you have your XP firewall disabled?
    [Internet connection Properties] {Advanced} (Internet connection Firewall) not selected.
    Jun 2003
    ct
    Router usage
    When using a machine behind a router for the server, the router must know to forward an incoming connect request from the internet, I'm not entirely sure exactly how the triggering works. Easiest way to get this working is go into router config, and find the DMZ host , put in the local ip of the machine that is running the teamspeak server ( ie i have two machines on my router, the ip to one is 192.168.1.100, and the other is 192.168.1.101) my teamspeak server runs on the 101 machine, so thats what i put in dmz. If you dont want to forward ALL incoming port requests by using dmz. Then use port forwarding. In which case this is what i would use, i have a linksys router and this is how my port forwarding would look.
    Port Forwarding
    14534 ext port, tcp udp =checks in both, ip addy 192.168.1.101
    also do the same for the following two ports.
    51234
    8767
    This will foward any incoming requests on these 3 ports to the computer with the ip address of 192.168.1.101. ( all 3 ports are needed for teamspeak to work properly)
    May 2006
    Europe/Czech Rep.
    1,299
    Quote Originally Posted by bigteam0385 View Post
    Please, port triggering is not port forwarding !! (I will skip describing the differences.)
    remove port triggering records that you have added for teamspeak2 and configure something that is called:
    "virtual server" or "port forwarding" in your router. For that you know the ports protocols and IP address so thats fine
    What router do you have? Company? model?
    If you still can not get it working give us links/attachments with screenshots of :
    router setup for port (forwarding)
    firewall configuration on pc
    screenshot of ipconfig on pc
    If you are desperate use DMZ and set it to that teamspeak server ip.
    Jun 2008
    7,764
    OMG! 2003! Tomas? Welcome to a new decade
    NPL License (Registration)
  1. Router Problems
    By Malus in forum [TeamSpeak 2] Client Support
    Last Post: 21-02-2008, 09:56
  2. connection problems after change router
    By Slevin in forum [TeamSpeak 2] Server Support
    Last Post: 23-02-2007, 21:11
  3. No response server problems using router
    By Sceptre in forum [TeamSpeak 2] Server Support
    Last Post: 14-02-2005, 10:21
  4. I am having problems with the router and ts
    By AVNSpider in forum [TeamSpeak 2] Server Support
    Last Post: 06-01-2005, 01:28
  5. Router problems
    By Chris-WAG54G in forum [TeamSpeak 2] Server Support
    Last Post: 07-09-2004, 18:40
