Results 1 to 4 of 4
Thread: Various TS Problems
05-07-2012, 21:25 #1
-= TeamSpeak User =-
- Jul 2012
- 2
Various TS Problems
Always liked TS until the latest update - program is nearly unusable now:
1. Stops detecting keyboard input after joining a server. If I open TS, keyboard works fine. When I join a server, I lose some functionality. Hotkeys and esc seem to work, but no other keys are registered. Configuring my PTT key doesn't do anything, I press my Caps key but nothing happens. It accepts my mouse though. Also accepts Esc to cancel PTT input. Only way to regain keyboard input is to restart the program, but as soon as I join a server, keyboard goes dead again. I've only started having this problem with the latest TS update.
2. TS randomly kills my in-game sound and completely mutes it. Again, only started having this problem with the latest update.
3. This doesn't directly relate to TS, but I'll post anyways. I updated my Arma 2 ACRE plugin to 1.47 for the TS update, and now my in-game ACRE radio doesn't work. And, yet again, I've only started having this problem after the latest update.
Tried both x64 and x86 versions, clean installs, comparability modes - nothing seems to help. Running on Win7 x64. Help would be appreciated(obviously).
05-07-2012, 22:09 #2
-= TeamSpeak Fanatic =-
- Jan 2010
- Location
- Germany
- 2,042
1) Go to Settings -> Options -> Hotkeys. There choose a different Hotkey Detection Method from the bottom right Dropdown (above the Apply button). See if one of them works, make sure to restart TeamSpeak after changing (even though it shouldn't be necessary).
2) Right Click Speaker Icon in Systray (next to clock) -> Recording Devices -> Communications -> Do Nothing -> Ok
3) Consult the Author of that Plugin for this one.
06-07-2012, 03:30 #3
- Jul 2012
- 2
Awesome! Thanks for the help SilentStorm. First 2 problems seem fixed and everything is working fine, until the next update at least lol. Thanks again.
13-07-2012, 16:32 #4
- Jul 2012
- 1
I have the same Problem, the second one. TS mutes ingame sounds "World of Tanks" in this case. WOT runs in exclusive mode, I use volume control mod- so it should be okay TS reduces the volume to 50%- but it mutes it completely and not only for the 5 or 7 seconds it should. Itīs not a problem of win7(64bit) system control, I just verified that. Maybe it haves to do with that VIA-sound control?
Everything else with TS works perfect. Hope i could explain my Problem lucidly....english is not my native language
Any of u can help? Merci bien
