Results 16 to 30 of 44
  1. #16
    Jun 2008
    7,762
    "join1" and "join2" is not that complicated i used them for my tests.
    We try to reproduce it and fix it for the next client release.
    edit
    We still try to find an how to that works everytime.
    Edit from dante
    For all, What server version do you run?
    Please make sure it is server 3.0.6.1
    NPL License (Registration)
  2. #17
    Nov 2011
    11
    Path to the channel i join is:
    [spacer0]CHAT CHANNELS (No PVP)/Administrative Offices/Server Admin's Office
    Hope that helps.
  3. #18
    Jun 2008
    7,762
    Quote Originally Posted by LogicSequence View Post
    Hope that helps.
    This channel family works fine here.
    I guess you still get this problem? Can you do me a favour and check something in your bookmarks.ini for me?
    This is for everyone who still have this problem, but the example is for the user above. Just replace your path
    Edit: This example is for the user "LogicSequence" and you the others have to replace the channel path and do not use spacer, when your channel is no spacer at all!
    It seems that people are blind to read, that this was an example, even when i say it was an example for the post above.
    -Please press Windows + R and then enter %appdata%\TS3Client\ and press OK.
    or Go into your programs folder, where TeamSpeak is installed and search for the folder "config" inside the TeamSpeak client.
    -You will find a file called bookmarks.ini , please open it.
    - now press CTRL + F and search for [spacer0
    - A result like this should show up
    3\DefaultChannel=[spacer0]CHAT CHANNELS (No PVP)/Administrative Offices/Server Admin's Office
    --> As you can see there is a number in front of that whole text ("3" in my example).
    - Now search again for this entry (x is your number) x\ChannelID=
    - There should be one entry for this and this should show the channel id for this subchannel (Server Admin's Office).
    Can you compare this Id with your target channel?
    Thank you all for the help
    Edit from dante
  4. #19
    Jun 2012
    14
    probably i didnt understand very well, but I cant find any "spacer0" string in bookmarks.ini
    every line start with 1/
  5. #20
    Jun 2008
    7,762
    i said this is the example for the post above.
    You have to use your name or path for the channel and not [spacer0....
    Edit from dante
  6. #21
    Sep 2007
    USA
    10
    Quote Originally Posted by eckart View Post
    strange ... cant reproduce it
    Maybe a special char (or more than one) in the name of the channel?
    I'm having same issues with v3.0.8 (latest). It doesn't work with any of my Bookmarks. Those with or without special characters.
    Using WinXP SP2 if that helps.
  7. #22
    Jun 2008
    7,762
    You could send me the bookmarks.ini for testing.
    I have explained in post #18, where you can find this file.
    Please send it in a private message or everyone else will have your server ip's!
    Edit from dante
  8. #23
    Jul 2012
    i'm having the same issues too... so i tried some things and found something interesting:
    i created a new bookmark and copied the ip, pw etc (don't duplicate the bookmark... doesn't work with that)
    i joined the default channel with this new bookmark... but after joining 2 more times it didn't work anymore!
    so again i did the same things again and it worked for 2 joins!
    so the same procedure again this time with looking at the changes in the bookmark.ini
    i think the problem is: 3\ChannelID=0 changed to 3\ChannelID=11
    cause after i edited it back to 0 the bookmark worked again...
    i hope that helps the teamspeak team fixing this...
  9. #24
    Jan 2010
    2,038
    If the id is 0 the client will get the id from the name, and then cache it as its way faster than getting the id from the name first, to then switch to the channel specified by the id.
  10. #25
    Jul 2012
    Same issue here. I have latest version (3.0.8). Previous version works fine.
    My channel in bookmark is: [spacer0]╠► WoT - Panzer Division
    My friends have same issue with this channel.
  11. #26
    Apr 2010
    25
    I (kind of) fixed this by renaming bookmarks.ini and creating my bookmarks again by hand... (using the old bookmarks.ini as a backup):
    Rename bookmarks.ini to bookmarks.txt, start TS3 - bookmakrs.ini is created with default values.
    Open bookmarks.txt with notepad (or any other text editor) and copy over the neccesary information like Bookmark name, Server Address etc. to a newly created bookmark entry.
  12. #27
    Apr 2010
    25
    Quote Originally Posted by TommyB View Post
    Apparently, this was only a temporary fix... now it again does not work.
  13. #28
    Jun 2008
    7,762
    Thank you all for the help , but i had top clean up some post's. Please read my How to in post#18 first, i had to edit some text, because users ignored, that his how to was for the user above :/
    @ Jetine- My default channel works fine with your how to. Sorry.
    @ TommyB - Renaming the bookmarks.ini is useless, the bug appears in your current client and comes back.
    I wonder why you even get it with he new ini file. It seems, that you can repoduce it.
    - what are you doing, to set the chanel? Do you enter it manually?
    - What is the channel path you use?
    Edit from dante
  14. #29
    Dec 2009
    21
    Join channel on startup
    *Edit*
    Hey,
    I've got the same problem. my bookmarks.ini looks like:
    3\DefaultChannel=.:: Sitzungssaal ::.
    3\ChannelID=11
    The channel ID fits.
    This prob occurs for every user and every channel.
    BUT:
    I have 3 virtual server installed within the same routserver.
    I've tested another virtual server then my default one (I havn't been on one of the other two virtual servers since the last update): The first time i connected to this other virtual server i connected automaticaly in the personal default channel. But after a reconnect it didn't worked anymore.
    Any idea on what to do?
  15. #30
    Jul 2012
    Verbindung mit geändertem Standart channel funktioniert nicht
    german part deleted.
    Hello community,
    So my problem is, I have 3 servers stored in Favorites, in which I allow myself to connect automatically when I start the TS. Besides, I have a server for every 3 standart registered channel lest I land in Wilkommens channel. Unfortunately, this does not work more recently. I'm also on all servers SA.
    Who do I start the TS3 connects, although, on all 3 servers of their own country but I welcome the Channel.
    Can someone help me?
    mfg
    drachenkaempfer
  1. Show default channel description on joining
    By SShaadd in forum Suggestions and Feedback
    Last Post: 16-04-2010, 15:33
  2. Joining channels
    By Fluffy in forum [TeamSpeak 2] Client Support
    Last Post: 01-03-2005, 18:12
