Results 1 to 2 of 2
31-07-2012, 21:34 #1
-= TeamSpeak User =-
- Jul 2012
- 2
Notification-Sound problem after soundpack installation.
some days ago i've installed a tts soundpack and now i don't get it deactivated.
I noticed that the notification sound menu in the options dialog doesn't work like the way it should.
Everytime i start teamspeak the option gets set back to the tts soundpack even when i've set the standard female soundpack.
Also deactivation of all sounds or any other possibility in this dialog hadn't have any effect.
But also just in the notification sound options tab.
More worse is that i need to change the soundpack back to normal through the menubar->status->Soundpack action since the options dialog doesn't take any effect like stated above.
Sincerely,
Remolus
Thread was moved out of the bug section...Last edited by dante696; 01-08-2012 at 07:15.
31-07-2012, 21:39 #2
-= TeamSpeak Fanatic =-
- Jan 2010
- Location
- Germany
- 2,042
Soundpacks (just as Hotkey, Playback and Capture profiles) are set separately for each Bookmark. The Setting in the Options Dialog are Default Values for new Connections through the Connect Dialog (which will also save and use the ones from the last connection established through this Dialog) and for Connections you establish by clicking on ts3server Links.
[Rejected] Sound profile instead of soundpack in bookmarks
By eckart in forum Suggestions and FeedbackReplies: 2Last Post: 25-07-2012, 12:53 -
Soundpack with a sound for determined group
By the_zoker_09 in forum WindowsReplies: 3Last Post: 29-03-2011, 16:50 -
[No Bug?] No sound from Default Soundpack
By Daemonium Noctis in forum Bug ReportsReplies: 4Last Post: 11-11-2010, 12:50 -
[Bug] Sound and Soundpack
By KevinGregull in forum Bug ReportsReplies: 1Last Post: 11-11-2010, 09:26 -
TS Sound Notification
By Zavin in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 21-04-2008, 02:38
