Results 1 to 2 of 2
    Oct 2013
    Exclamation upgraded from 3.0.8 to 3.0.10 and won't start
    update: not a bug... error with archlinux package
    I've upgraded the server from 3.0.8 to 3.0.10 and now when I start the server... I see this error
    Oct 03 11:52:48 linuxboxname teamspeak3-server[1933]: 2013-10-03 10:52:48.802067|ERROR |DatabaseQuery | | db_connect() failed unable to open database file
    Oct 03 11:52:48 linuxboxname teamspeak3-server[1933]: 2013-10-03 10:52:48.802092|CRITICAL|ServerLibPriv | | Server() DatabaseError out of memory
    ... I downgraded to 3.0.8 and rebooted and still see this error
    I've opened the sqlite db file manually using sqlitebrowser and it opens fine and all the data is still there so it's not corrupted...
    the permissions on the file ts3server.sqlitedb hasn't changed
    there is plenty of memory free...
    these are the only 2 parameters I pass to the daemon
    logpath=/var/log/teamspeak3-server/ dbsqlpath=/usr/share/teamspeak3-server/sql/
    using archlinux 3.10.13-1 64bit
    This a bug?
    Last edited by sinatosk; 03-10-2013 at 15:17. Reason: not a bug... error with archlinux package
    Jan 2011
    15
    Are you sure, the files chown are the same as before? Usually this error "Database Out of Memory" could happen when the user changed, the wrong user is trying to start ts, or chmod is wrong.
  1. [Resolved] upgraded and ts3 stopped working
    By silvershunketsu in forum Linux / FreeBSD
    Last Post: 24-01-2013, 01:23
  2. Haven't upgraded in a while... need help.
    By Arterio in forum Server Support
    Last Post: 03-06-2010, 02:03
  3. upgraded server need lic to upgrade
    By loosenut in forum Server Support
    Last Post: 01-03-2010, 12:11
  4. Just upgraded to MySQL 3.23.54
    By alphaman36 in forum [TeamSpeak 2] Server Support
    Last Post: 01-10-2005, 19:54
