17-03-2003, 00:21
-= TeamSpeak User =-
Connect from the web!
Okay, I need a script there can connect to my TeamSpeak server from my website!
It shall NOT be the Webpost/script because I only have one server...
So you when you come in to my homepage, you Shall write you name, Chanal you wanna join and Password for the chanal!
Like this:
Nickname:
Chanal:
Chanal password:
Then it connect to my server!
Can someone help me with that?
Maybe if you make a link like this:
teamspeak://MyIP -nick +nick+ -chanal +chanal+ -pass +chanalpass+
(I dont know the right parameter, can someone also tell me those?)
17-03-2003, 00:27
I would also like to know the parameters ... if it is a option .... let's hope so
18-03-2003, 15:42
-= TeamSpeak Lover =-
Should the script be written in ASP or PHP????
Or do you want it written in a Java Applet?
18-03-2003, 18:04
Just forget it...
I find the parameters my self,
and maid a script self...
A very simple Javascript!!!
But it works..., and that is what I need!
21-03-2003, 14:03
The Parameters can be found here:
http://forum.teamspeak.com/show...&threadid=1135
Its in the sticky FAQ of the German Windows Server Forum.
Here the most important line:
teamspeak://xxx.xxx.xxx.xxx/?channel=Channelname&loginname=CHEFTEST&password=t est&nickname=TESTER
20-06-2003, 05:07
Great, that is just what I was looking for. But I have a question about that. Is it possible to have them enter their information into some empty fields and then when they click ok, that they will join the desired channelwith their desired username?
Any information on this would be greatly appreciated.
Thank You In Advance,
Hybrid
25-01-2007, 13:04
Use the following code in your webpage, replace www.yourtsserver.com with the URL of your TS Server.Change Appearance using the .style sections
Paste this into the HEAD section:
Quote:
<style type="text/css">
.style1 {
font-family: Arial, Helvetica, sans-serif;
font-size: x-small;
.style3 {font-family: Arial, Helvetica, sans-serif; font-size: xx-small; }
body {
background-color: #000000;
.style4 {
color: #FFFFFF;
font-weight: bold;
.style5 {color: #FFFFFF}
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
Paste this into the BODY section:
Quote:
<FORM>
<p><br>
</p>
<table width="497" border="0" align="center" bgcolor="#000000">
<tr>
<td colspan="3"><div align="center">
<p class="style1"><span class="style4">Input your Name and Password and press the Button to connect<br>
</span><span class="style5">The connection to the Team Speak server will be automatic <br>
</span><br>
</div></td>
</tr>
<tr bordercolor="#FFFFFF" bgcolor="#FF9900">
<td width="144" height="17"><div align="center" class="style3">Name </div></td>
<td width="144"><div align="center" class="style3">Password</div></td>
<td width="215"><div align="center" class="style3">Connect</div></td>
</tr>
<tr bgcolor="#FF9900">
<td><div align="center">
<input name="text1" type=Text>
</div></td>
<input name="pw" type=Text>
</div></td>
<input name="submit" type=Button value="Connect to TS" onClick="window.location='teamspeak://www.yourtsserver.com:31105/nickname='+form.text1.value+'?password='+form.pw.v alue">
</div></td>
</tr>
</table>
<p><br>
</p>
</FORM>
Reason: Added Head section
25-01-2007, 23:13
-= TeamSpeak Fanatic =-
<html>
<body>
<script type="text/JavaScript">
function func_ts(){
var nickname = document.TS_Form.nickname.value;
var login = document.TS_Form.login.value;
var password = document.TS_Form.password.value;
var gotothispagenow=window.setTimeout(location.href="teamspeak://scserver.no-ip.org:8767/nickname="+nickname+"?loginname="+login+"?password="+password, 1);
document.write('<script type="text/JavaScript"> this_window = window.open("teamspeak://scserver.no-ip.org:8767/nickname='+nickname+'?loginname='+login+'?password='+password+'"); this_window.close(); </script>');
//teamspeak://Address: Port/nickname=?loginname=?password=
</script>
<form onSubmit="func_ts()" name="TS_Form" action="ts.html" method="post">
Nickname: <input type="text" name="nickname"><br>
Login: <input type="text" name="login"><br>
Password: <input type="password" name="password"><br>
<input type="submit" value="Submit">
</form>
</body>
</html>
Someone made the above up for me before for a similar function
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Powered by vBulletin® Version 3.7.3 Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Add to Bookmarks
Printview
Contact Us
Legal Notices
