TeamSpeak TeamSpeak
Community
Page 12 of 34 FirstFirst ... 2101112131422 ... LastLast
Results 166 to 180 of 507
  1. #166
    Mar 2003
    Sweden
    21
    My server list wanted this gif ?? it was on the player list .. what status is that? coz i didnt have that gif in the image folder ?
  2. #167
    Jun 2002
    Everett, WA, USA
    332
    Yeah, I think there are a bunch that I missed. I will include images for those.
  3. #168
    Jun 2002
    Michigan
    49
    Do you have a web link or a tutorial on how to get this webpost up and working? I'm a newbie to programming HTML and I think I'm going to need some help on this. The readme.txt file is really about the updates.
    Thanks
  4. #169
    Feb 2003
    Louisiana
    63
    the current version of webpost no longer funcitons with rc2. you must wait for the new release.
  5. #170
    Mar 2003
    Sweden
    21
    I have webpost2 and linux server RC2 works petty fine for me
  6. #171
    Mar 2003
    california
    8
    works great for me aswell and i am using the newest versions
  7. #172
    Feb 2003
    Louisiana
    63
    if you re not using the latest version of mysql then webpost should function, but some of the rc2 stuff i believe is not avalible on the current webpost version.
  8. #173
    Aug 2002
    Haydock
    73
    Just a quicky can someone check my page and see if they see any errors, ive been told there are but for some reason i dont see them on my machine. cheers
    http://www.bigman.34sp.com/nuke/html/listing.php
  9. #174
    Mar 2003
    california
    8
    Warning: Cannot add header information - headers already sent by (output started at /usr/local/psa/home/vhosts/bigman.34sp.com/httpdocs/nuke/html/db_inc.php:286) in /usr/local/psa/home/vhosts/bigman.34sp.com/httpdocs/nuke/html/mainfile.php on line 74
    yea your site has errors. are you using the nuke mod for webpost??
  10. #175
    Aug 2002
    Haydock
    73
    No im just using the normal one not the modded one for nuke, reckon thats the problem
  11. #176
    Aug 2002
    Haydock
    73
  12. #177
    Mar 2003
    california
    8
    no more errors but you need to have the module active but if you want an even easier to way to get webpost added to phpnuke without haveing to use the module or anything all you have to do is the following
    if you guys are looking to integrate webpost into your phpnuke there are easier ways then just creating blocks or even modules. here is how i did mine. My way gives the same effect of the module without all the fuss or even mess. any n00b can make theirs seem like a module if you follow my stepshere is mine
    step 1 install webpost to the base directory in phpnuke
    step 2 open listing.php in a text editor i used a free one called crimson editor
    step 3 find line include("db_inc.php");
    step 4 insert include("header.php");
    step 5 save the file
    step 6 upload and overwrite the file.
    step 7 goto your http://www.youraddress.com/nukedirectory/listing.php
  13. #178
    Mar 2003
    San Francisco
    27
    Has Any one here successfully installed the phpnuke ported version of webpost to phpnuke 6.5.
    I for the life of me cant get any connection to my TS servers on my Linux box.(which is a remote server not local) but are running nicely!
    But the webpost installed ok with no errors.
    RedHat Linux 7.2 Features:
    Red Hat Applications
    RedHat 7.2
    Apache 1.3.22
    Sendmail 8.11.6
    Bind 9.1.0
    MySQL 3.23.36
    mod_perl 1.24
    Kernel 2.4.9-31
    EXT3 Filesystem
    PHP 4.0.6
    PERL 5.6.0-12
    OpenSSH 2.9
    Seem to be ok on the nessacerry apps but still no reading.
    You can view it here http://www.clanselite.com/html/modules.php?name=webpost
    Can anyone spare a few mins to help me install this if they have, my AIM is EnigmaPrime01 cheers in advance
  14. #179
    Mar 2003
    california
    8
    if you read the post above you. you will find a much easier way of integrating phpnuke and webpost
  15. #180
    Mar 2003
    San Francisco
    27
    Integrating is not the prob, ive done that successfully with no errors, this is a mod made specifically for phpnuke, it was installed with no errors, the problem is the server is not showing up in webpost.
  1. gllcTS2?
    By quaddel94 in forum [TeamSpeak 2] Addons & Scripts
    Last Post: 02-10-2009, 21:30
  2. A little problem with the GLLCTS2 webpost
    By saj0577 in forum [TeamSpeak 2] Addons & Scripts
    Last Post: 10-04-2007, 02:32
  3. alternative downloadsource for the gllcTS2 Webpost for TeamSpeak 2
    By M4dD0g in forum [TeamSpeak 2] Addons & Scripts
    Last Post: 18-01-2006, 12:23
  4. TS2, MySQL, & webpost with GLLCTS2
    By Ironbar in forum [TeamSpeak 2] Server Support
    Last Post: 05-05-2004, 02:53
