TeamSpeak TeamSpeak
Community
Results 1 to 14 of 14
    Jan 2010
    UK
    7
    TS3 Web link & Shortcut syntax and auto connect
    Hi
    I spent a lot of time trying to find the answer to a few questions on TS3, with limited success.
    So I thought I would post all the answers here so others can find answers easier than i did.
    I'm using XP Pro 32 bit and TS3-beta 9
    Questions
    1) What is the syntax to connect to a TS3 server from a web link?
    2) What is the syntax to connect to a TS3 server from a desktop shortcut?
    3) Why does my client fail to connect via a web link?
    Answers
    1) <a href="ts3server://IPADDRESS/?port=YOUR PORT&nickname=Web
    Guest">Connect to Server</a>
    2) "C:\Program Files\TeamSpeak 3 Client\ts3client_win32.exe" ts3
    server://IPADDRESS/?port=YOUR PORT&nickname=YOUR NICKNAME
    3) Neither 1 nor 2 will work if you have, via a bookmark in the TS3 client,
    set the client to auto connect to your preferred server and you attempt
    to click on a web link or shortcut to another server.
    To turn off the auto connect within the client; go to bookmarks and
    highlight the server you auto connect to; press More at the bottom of the dialogue box and un-check connect at startup
    SDT HAMMER
    Jan 2010
    UK
    7
    Follow-up post
    Hi All
    Well the auto connect issue (number 3 above)has been accepted as a bug and will be addressed.
    I add a number 4
    Question
    4) What is the syntax to connect via a batch file (.bat)
    Answer
    4) path="C:\Program Files\TeamSpeak 3 Client"
    start ts3client_win32.exe "ts3server://IPADDRESS?port=YOURPORT&nickname=YOUR NICKNAME"
    SDT HAMMER
    Dec 2009
    Belgium
    Join teamspeak Weblink
    I want to connect to teamspeak by clicking a button on my website. But when i just use the link ts3server://ip/?port it automaticly gives the name TeamSpeakUser.
    No i've read on some forums it's possible to connect with a custom nickname with following code:
    ts3server://IP/?PORT&nickname=NICKNAME
    Now i want a screen to popup (javascript) when i click the button, ask for a nickname and then connect with that nickname. How can i realise this?
    This is the code i used
    <a href="ts3server://teamspeak.onlydutch.com/?port=9987&nickname=WebGuest">Join</a>
    May 2004
    Berlin
    try this ...
    e.g. ts3server://ts3server:78.46.90.80:9987 working with WinVST
    e.g. ts3server://78.46.90.80:9987 working with WinXP
    Not really helpful ...
    g, Niceguy.
    Jan 2010
    UK
    7
    Further Update
    The approach is always to make things easier/simpler when dealing with computers and other people.
    So to that end I'll update my posting above.
    1. web link = <a href="ts3server://IPADDRESS/?port=YOUR PORT&nickname=Web
    2. desktop shortcut = ts3server://"YOUR IP?port=YOUR PORT&nickname=YOUR NICKNAME"
    3. batch file= start ts3server://"YOUR IP?port=YOUR PORT&nickname=YOUR NICKNAME"
    Don't forget the "quotes"
    SDT HAMMER
    Jan 2010
    UK
    7
    Default Channel and Password in a weblink
    Had a search for the answer to this but failed to find anything for TS3.
    I want to be able to auto join to a server via
    1. a weblink
    2. a desktop shortcut
    3. a DOS batch file
    The channel I want to join is not the default channel for the server.
    So I expect to have to specify the channel and its password in the link/shortcut/batch file
    Can anyone help please?
    SDT HAMMER
    Jan 2010
    Virginia
    Just installed TS3 and love it. Busy replacing the functions in TS2 with the TS3 versions.
    Thanks to Hammer for the posting this. It took me 2 hrs to find someone that had checked on this syntax for TS3.
    However, I still find the explaination a bit confusing without an example (I like examples), so here is an example of the syntax for #2.
    desktop shortcut = "C:\Program Files\TeamSpeak 3 Client\ts3client_win32.exe" ts3server://"IPADDRESS/?port=YOUR PORT&nickname=YOUR NICKNAME"
    example -
    The TS3 server name you want to connect to is named "MyTS3server.net"
    You are using the defualt port of "9987"
    Your nickname is "G4meDTP"
    Here is how the syntax would look if you are using the default port (this does not acctually set the port).
    "C:\Program Files\TeamSpeak 3 Client\ts3client_win32.exe" ts3server://"MyTS3server.net?9987&nickname=G4meDTP"
    If you really want to change the port number you will need to change to;
    "C:\Program Files\TeamSpeak 3 Client\ts3client_win32.exe" ts3server://"MyTS3server.net/?port=1234&nickname=G4meDTP"
    You can use an IP address for the servername if you wish, but I will let DNS figure out the IP, just in case the Admin changes it at some point.
    Capitalization is likely not needed, but I did not test.
    Peace!
    Sep 2004
    UK
    8
    Exclamation More than 1 TS not connecting with the shortcuts,
    My clan GD has 2 TS's maybe more, on the gravediggers.eu Web address one on port 9000 and others on other ports but the shortcut
    "ts3server://gravediggers.eu/?PORT=9000/username=MrDemon" Does not connect to the 9000 server and connects to the 9987 server instead,
    Ok just found a area in "Bookmarks" in TS3 "Connect on startup. Auto connects to the server there n then when u load TS3.
    Sep 2004
    UK
    8
    Red face Huh
    ts3server://gravediggers.eu/?port=9000&nickname=MrDemon
    Wierd this is now working,.....
    looking at it now, funny, not reading what i was doing as usual, the /username and not &nickname, lol
    Feb 2010
    Toronto
    The weblink is working… ts3server:// and although I haven't found a complete reference guide, I is covered in the server quick reference and some threads.
    http://forum.teamspeak.com/showthread.php?t=48960
    The desktop shortcut could just be a saved link for the weblink…. the Batch file would need a client reference guide to know which args to use for the app…. haven't seen completed TS3 server or client docs released yet.
    …T.
    --- Merged ---
    Does anyone have a complete list of all new argument that can be passed using the weblink? I don't see a reference guide for this anywhere yet.
    …T.
    Jun 2008
    Krün, Germany
    503
    Dec 2009
    New York
    20
    <form name="tsform">
                <p align="center"><font face="Arial"><img border="0" src="/forums/foets.png" width="283" height="54"></font>
                </p>
                <p align="center"><font face="Arial">Choose A Nickname:<br> <input type="text" name="NICKNAME">
                <br />
                <input type="button" value="Connect To TeamSpeak" onClick="javascript:location.href='ts3server://foe-rs.com/?port=9987&nickname=' + tsform.NICKNAME.value">
                </font><br>
                <font face="Arial" size="1">You Must Have
                TeamSpeak Preinstalled to Use This Function.<br><a href="#" onClick="window.open('http://foe-rs.com/forums/index.php?topic=31.0', 'teamspeak')">Check This Guide for More Info</a></font>
                </p>
            </form>
    I got that code together with some friends and its working fine, but how can I make it so it connects to a specific channel + insert the channel's password...
    Great thx if you can help.
    Thx!
    Aug 2007
    FL, USA
    9
    i got this to work in IE8, not sure if works for firefox(dont have it installed) but i want to get it to work for chrome and it wont. is that just a chrome thing? or is there something else that i need to do for this to work.
    spook24
    Nov 2011
    Quote Originally Posted by SDT HAMMER View Post
    1. a weblink
    3. a DOS batch file
    SDT HAMMER
    this works for me as a windows desktop shortcut ......
    ts3server://SERVERIPADDRESS?password=PASSWORD&channel=CHANNEL% 2FSUBCHANNEL&channelpassword=PASSWORD&nickname=NIC KNAME
    The syntax should also work for a weblink as well as a batch file
    Cheers,
    PhilC
There are currently 3 users browsing this thread. (0 members and 3 guests)
  1. Replies: 3
    Last Post: 11-01-2010, 17:28
  2. Http Server Link Syntax
    By fleury in forum [TeamSpeak 2] Server Support
    Last Post: 11-12-2004, 17:10
