TeamSpeak TeamSpeak
Community
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Aug 2010
    Hungary
    8
    make it start everytime
    apt-get install rcconf
    edit the startscript (not the minimal, the other one) like this:
    COMMANDLINE_PARAMETERS="inifile=ts3server.ini"
    BINARYPATH="/path/toyour/ts3/folder"
    configure ts3server.ini to your needs
    copy the startscript to /etc/init.d
    rename it to teamspeak3
    chmod it to be able to run it
    start rcconf and tick teamspeak3
    it will start everytime you start the server
  2. #17
    Dec 2009
    Hamm / Germany
    13
    how can i do that, because the crazy thing is that my Server ins currently runnig when is using "top", but connection doesnt work
    another Port Scan Tool shows the following:
    Port # Status
    9987 Closed or Filtered
    30033 Closed or Filtered
    10011 Closed or Filtered
    The Logfiles shows now:
    2010-08-14 22:31:02.508398|INFO |ServerLibPriv | | Server Version: 3.0.0-beta27 [Build: 12002], Linux
    2010-08-14 22:31:02.508667|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2010-08-14 22:31:02.508721|INFO |DatabaseQuery | | dbPlugin version: 3.6.21
    2010-08-14 22:31:02.508986|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2010-08-14 22:31:02.522500|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-08-14 22:31:02.925428|INFO |Accounting | | Licensing Information
    2010-08-14 22:31:02.925941|INFO |Accounting | | type : Non-profit
    2010-08-14 22:31:02.926348|INFO |Accounting | | starting date : Sun Dec 20 23:00:00 2009
    2010-08-14 22:31:02.926756|INFO |Accounting | | ending date : Mon Dec 20 23:00:00 2010
    2010-08-14 22:31:02.927130|INFO |Accounting | | max virtualservers: 10
    2010-08-14 22:31:02.927586|INFO |Accounting | | max slots : 512
    2010-08-14 22:31:02.945404|INFO |FileManager | | listening on 0.0.0.0:30033
    2010-08-14 22:31:03.025587|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2010-08-14 22:31:03.025897|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2010-08-14 22:31:03.026469|INFO |Query | | listening on 0.0.0.0:10011
    2010-08-14 22:35:27.824020|INFO |ServerMain | | Received signal SIGTERM, shutting down.
    2010-08-14 22:35:27.964720|INFO |VirtualServer | 1| stopped
    Is the black one abnormal because i am using the Teamspeak Client only and no server query tool
  3. #18
    Dec 2009
    Hamm / Germany
    13
    ok i have tested teamspeak 3 with my beta V-Server which runs on the same hardware like my normal v-server, but the beta Server has only 512 MB Ram.
    Its running normal with the Beta Server. The only difference between the two Servers is that the Beta Server is Running the new Linux Kernel:
    Linux st-rollenspiel 2.6.32.15-1-openvz #1 SMP Mon Aug 9 16:38:53 CEST 2010 i686 GNU/Linux
    and my normal:
    Linux direct-host.de 2.6.27.42-2-openvz #1 SMP Sun Jan 17 23:44:39 CET 2010 i686 GNU/Linux
    I Think there must be my problem. I Hope that the new Kernel comes quickly to the productive vserver.
  4. #19
    Dec 2009
    Hamm / Germany
    13
    Ok its running correctly with Debian Lenny
    Linux direct-host 2.6.32.15-1-openvz #1 SMP Mon Aug 9 16:38:53 CEST 2010 i686 GNU/Linux
    But one problem left. When is restart the V-Server the teamspeak process doesnt start automatically again. I think thinks works fine with older Beta Version auf Teamspeak Server.
    How could i fix this ?
  5. #20
    Apr 2011
    [NPL] Server Issues
    My server won't run over 32 clients as if my NPL won't work at all.
    Here is my Log
    2011-04-15 18:46:41.406949|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta30 [Build: 12998], Linux
    2011-04-15 18:46:41.407173|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2011-04-15 18:46:41.407211|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2011-04-15 18:46:41.407460|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2011-04-15 18:46:41.418212|INFO    |SQL           |   | pruning old database log entries where timestamp is older than 90 days
    2011-04-15 18:46:42.513378|INFO    |Accounting    |   | Licensing Information
    2011-04-15 18:46:42.513447|INFO    |Accounting    |   | type              : Non-profit
    2011-04-15 18:46:42.513518|INFO    |Accounting    |   | starting date     : Mon Apr  4 00:00:00 2011
    2011-04-15 18:46:42.513549|INFO    |Accounting    |   | ending date       : Wed Apr  4 00:00:00 2012
    2011-04-15 18:46:42.513576|INFO    |Accounting    |   | max virtualservers: 10
    2011-04-15 18:46:42.513600|INFO    |Accounting    |   | max slots         : 512
    2011-04-15 18:46:42.534056|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2011-04-15 18:46:42.788489|INFO    |VirtualServer |  1| listening on 0.0.0.0:9987
    2011-04-15 18:46:42.788993|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2011-04-15 18:46:42.789661|INFO    |Query         |   | listening on 0.0.0.0:10011
    2011-04-15 18:46:56.693636|INFO    |ServerMain    |   | Received signal SIGTERM, shutting down.
    2011-04-15 18:46:56.816869|INFO    |VirtualServer |  1| stopped
    I don't understand what's going on. I have waited 2 days after I shut off my last server that was running it. Also, I haven't gave anyone access to this license. So again stated I don't understand what's going on. Please help. ~regards
  6. #21
    Nov 2010
    Pakistan
    22
    Hello Friends,
    My Server Is Crashing Day By Day , And When I Check The Logs Its This Error :-
    2011-08-06 09:52:57.011875|INFO |ServerMain | | Received signal SIGTERM, shutting down.
    Please Help Me To Solve This Problem,
    Thanks In Advance,
    Regards,
    eMPy
  7. #22
    May 2010
    11
    SIGTERM is a signal to sent from the server when you shutdown or reboot him..
    the signal goes to all running processes.
    Crash your ts3 server or your entire server(os)?
  8. #23
    Feb 2012
    Hey same here...
    Well first to give u a quick overview of what i did.
    1 installed the linux_amd64 server
    2 started it first time with - createinifile=1 .. then stoped it
    3 changed ip's in ts3server.ini ... started it again with inifile=ts3server.ini
    4 checked which ports are used
    5 edited iptables
    It is possible to connect with the admintool on port 10011 but not with the ts3 client. (Yes iptables is proof :-) )
    I'am totaly clueless please help.
    Thanks!
    dG
    -------merged-------
    There are no prblems with the connection to the ts3 accounting, but the virtual server stops ...
    ts3server_2012-02-19__23_05_58.562430_0.log
    2012-02-19 23:05:58.562605|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.1 (2011-11-17 07:34:30)
    2012-02-19 23:05:58.563386|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2012-02-19 23:05:58.563468|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2012-02-19 23:05:58.564016|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2012-02-19 23:05:58.857770|INFO    |Accounting    |   | Licensing Information
    2012-02-19 23:05:58.857871|INFO    |Accounting    |   | type              : Non-profit
    2012-02-19 23:05:58.857987|INFO    |Accounting    |   | starting date     : Sun Feb 19 00:00:00 2012
    2012-02-19 23:05:58.858045|INFO    |Accounting    |   | ending date       : Sun Aug 19 00:00:00 2012
    2012-02-19 23:05:58.858093|INFO    |Accounting    |   | max virtualservers: 10
    2012-02-19 23:05:58.858137|INFO    |Accounting    |   | max slots         : 512
    2012-02-19 23:05:58.876563|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2012-02-19 23:05:58.910994|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2012-02-19 23:05:58.911371|INFO    |Query         |   | listening on 0.0.0.0:10011
    2012-02-19 23:08:44.557695|INFO    |ServerMain    |   | Received signal SIGTERM, shutting down.
    ts3server_2012-02-19__23_05_58.562430_1.log
    2012-02-19 23:05:58.910845|INFO    |VirtualServer |  1| listening on 0.0.0.0:9987
    2012-02-19 23:08:44.657397|INFO    |VirtualServer |  1| stopped
    Anyone out there with an idea?
    Thanks!
    dG
    Thread has been moved.
  9. #24
    Apr 2011
    1,199
    I think the server got the SIGTERM because you logged out. You started the server process and it was still a child of your shell process, so after the logout your shell and all of its children receive a SIGTERM.
    You need to run the server process not as a child of you shell but as a child of the init process which is most easily done by using the right start script... for example the "ts3server_startscript.sh"
    Barungar
  10. #25
    Aug 2012
    44
    Hello I've got the same problem... My server receive a SIGTERM every hour.... I've got enough ram and disk space, I use ts3server_startscript.sh, I even tryed to let open putty season... All used ports ale open, My NPL-license is ok too.... I have no idea please help
    Log:
    2014-04-20 22:27:38.571583|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.10.3 (2014-01-01 16:28:39)
    2014-04-20 22:27:38.571723|INFO    |ServerLibPriv |   | SystemInformation: Linux 3.11.0-19-generic #33~precise1-Ubuntu SMP Wed Mar 12 21:16:27 UTC 2014 x86_64 Binary: 64bit
    2014-04-20 22:27:38.572724|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-04-20 22:27:38.572764|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2014-04-20 22:27:38.573060|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2014-04-20 22:27:39.228005|INFO    |Accounting    |   | Licensing Information
    2014-04-20 22:27:39.228096|INFO    |Accounting    |   | type              : Non-profit
    2014-04-20 22:27:39.228179|INFO    |Accounting    |   | starting date     : Mon Feb 17 00:00:00 2014
    2014-04-20 22:27:39.228208|INFO    |Accounting    |   | ending date       : Sun Aug 24 00:00:00 2014
    2014-04-20 22:27:39.228227|INFO    |Accounting    |   | max virtualservers: 10
    2014-04-20 22:27:39.228246|INFO    |Accounting    |   | max slots         : 512
    2014-04-20 22:27:42.245983|INFO    |              |   | Puzzle precompute time: 3001
    2014-04-20 22:27:42.246490|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2014-04-20 22:27:42.247810|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1,
    2014-04-20 22:27:42.248307|INFO    |Query         |   | listening on 0.0.0.0:10011
    2014-04-20 22:27:42.652624|INFO    |Query         |   | query from 1 ************** issued: login with account "serveradmin"(serveradmin)
    2014-04-20 22:27:46.275098|INFO    |VirtualSvrMgr |   | startServer() VirtualServer(1) started
    2014-04-20 23:27:45.020987|ERROR   |Accounting    |   | too many virtualservers running, shutting down!
    2014-04-21 05:03:02.305304|INFO    |Query         |   | query from 2 ************** issued: login with account "serveradmin"(serveradmin)
    2014-04-21 05:03:17.488028|INFO    |VirtualSvrMgr |   | startServer() VirtualServer(1) started
    2014-04-21 05:28:22.741625|ERROR   |Accounting    |   | too many virtualservers running, shutting down!
    2014-04-21 05:29:04.365342|INFO    |ServerMain    |   | Received signal SIGTERM, shutting down.
    Can you see that error "too many virtualservers running, shutting down!" could this cause Received signal SIGTERM, shutting down?
    Btw I don't know why is this there anyway I have only one virtual server running.
  1. Received signal SIGTERM, shutting down
    By Napster in forum Server Support
    Last Post: 31-07-2015, 20:38
  2. Received signal SIGHUP, shutting down Problem
    By Vwgolf in forum Linux / FreeBSD
    Last Post: 02-03-2014, 16:39
  3. Received signal SIGTERM
    By deeGeee in forum Linux / FreeBSD
    Last Post: 20-02-2012, 00:22
  4. Replies: 7
    Last Post: 14-02-2011, 18:38
  5. Replies: 8
    Last Post: 07-08-2010, 15:45
