TeamSpeak TeamSpeak
Community
Page 2 of 11 FirstFirst 1234 ... LastLast
Results 16 to 30 of 165
  1. #16
    Dec 2009
    2,157
    Quote Originally Posted by mlkjhqsdfg View Post
    Plugin failed to load:
    Api version is not compatible
    I know, TS3 client beta 28 updates the API version again.
    But currently I have a problem, my plugin is currently unable to get a list of clients from a channel (with beta 28). I need a fix for this first.
    My problem is described here: http://forum.teamspeak.com/showpost....69&postcount=4
    --- Merged ---
    Problem solved, new version released:
    Version 0.2 (09.09.2010)
    o Small changes releated to TS3 client beta 28.
    o Updated TS3 Client API version to 8 (needed for beta 28+)
    Download link in first post.
  2. #17
    Dec 2009
    FR
    6
    big, thanks
  3. #18
    Jan 2010
    Catalunya
    2,375
    Sorry, I have the wrong thread.
    I'm sure your plugin has nothing strange.
    The problem is with TruPrevent Technologies, which blocks the application.
    It also happening with the two latest versions of the Server.
    I am attaching a link, if you do not know TruPrevent.
    http://research.pandasecurity.com/ho...event-works-i/
  4. #19
    Dec 2009
    2,157
    New version:
    Version 0.3 (07.11.2010)
    + Added commands sgt and sgh to move all members of a server group.
    Download link in first post on page 1.
  5. #20
    Dec 2004
    18
    It woul be great if you can add a similar feature with channelgroups.
    For example:
    /m cgh "id of channel" "id of channelgroup"
    cu...
  6. #21
    Dec 2009
    2,157
    Quote Originally Posted by mcfly_98 View Post
    For example:
    Would be possible, but not that easy, because the channel groups are channel based and would make some things much more complicated. Thats why I do not implement such a feature in the next time.
  7. #22
    Feb 2010
    Internet
    51
    Can I make two sugestions?
    If possible:
    + organize channels by name (alphabetic order, like in ts2).
    + move channels/sub-channels to other, not clients, reorganize these specific channels.
    I don't know any plugin or command in ts3, if exist, to do this.
    These possibilities will be very useful, specially for servers admins with hundreds of channels.
    Thank you for your plugins!
  8. #23
    Dec 2009
    2,157
    @ TeamSpeak3: This plugin is not for changing the channel order. This plugin is only intended to move a bigger amount of clients to another channel.
  9. #24
    Jan 2011
    Is there a command to move people from one channel to annother if you are not a member of that channel? For example. I am in the lobby, 5 people are in general. Can I move the 5 people in general to AFK whilst I am in lobby?
    If this is not currently there, think it could be something that you could add?
  10. #25
    Dec 2009
    2,157
    @ Tharkun: Currently not, but I will implement this in the next version. Currently I wait for the RC1 release of the client plugin SDK.
  11. #26
    Feb 2011
    East Coast
    I am in a Massive gaming clan/organization, and well... I really want to completely remove the chance of moving every one in the server to a channel. I don't think my future in the clan will be to long if i move 100 people into 1 channel....
    I tried doing this myself for myself, but I was unable to recompile the source code. Would you also be able to point me in a direction of successfully doing so?
  12. #27
    Dec 2009
    2,157
    Quote Originally Posted by Robirt55 View Post
    The plugin only move all peoples, if you use the command to do so. You can also use commands for only one channel.
    Just to make sure that you don't use that commands by an accident, just remove the "else if" block in file main.cpp for
    command "ah" at line 133
    command "at" at line 141
    That should make that two commands undetected. But remember, this is untested.
  13. #28
    Feb 2011
    East Coast
    I have done so in the source file but am unable to compile it. Where can i find out how to compile it?
  14. #29
    Dec 2009
    2,157
    Which compiler do you use? I used MinGW.
  15. #30
    Feb 2011
    East Coast
    Microsoft Visual C++ 2010 Express
  1. Cant move clients?
    By PowerSSaiyanX in forum Client Support
    Last Post: 13-08-2013, 06:54
  2. Unable To Move Clients
    By coolthunder39 in forum Permission System
    Last Post: 31-08-2012, 00:02
  3. [Suggestion] Move the clients instead of a channel with D&G
    By Worfox in forum Suggestions and Feedback
    Last Post: 21-04-2012, 22:32
  4. move clients
    By amz86 in forum Permission System
    Last Post: 08-04-2011, 23:23
  5. Replies: 3
    Last Post: 14-07-2010, 09:30
