TeamSpeak TeamSpeak
Community
Results 1 to 6 of 6
    Feb 2012
    Solved Running Server Issue (Logs included)
    I have successfully set up my TeamSpeak server, however I can only connect to it via 10.0.1.2 (localhost). When I type in my IP-address I can't connect. I used a application called "PortMap" to open all 3 necessary Teamspeak ports and still nothing.
    Also if I close down my teamspeak server process and try to type in the commands to open it again. ( cd /Applications/teamspeak3-server_mac
    ./ts3server_mac )
    I get this error:
    2012-02-23 03:54:31.023358|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.1 (2011-11-17 07:34:30)
    2012-02-23 03:54:31.024266|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2012-02-23 03:54:31.024329|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2012-02-23 03:54:31.024695|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2012-02-23 03:54:31.061478|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2012-02-23 03:54:31.561891|ERROR |Accounting | | local accounting reports an already running instance, instance will shutdown
    2012-02-23 03:54:31.562007|ERROR |ServerLibPriv | | Server() error while starting servermanager, error: instance limit reached
    Can anyone help?
    Jun 2008
    11,843
    This is normal, that you can't use your external IP for your own local Computer. Your router has to support that.
    The last 2 lines from your log are showing, that the server instance (whole server program) is running already.
    Please make sure that the server isn't started twice or more.
    Please don't send me private messages with support questions as long I or someone else from Teamspeak Staff asked for it.
    Seriously > They belong into the forum and maybe other users have these questions/problems too.
    TeamSpeak FAQ || What should i report, when i open a client thread? ||NPL License (Registration)
    Feb 2012
    Okay that makes sense, thanks.
    However when my TS3 server is "up", no clients can connect to it when I give them my external IP address. (from let's say ipchicken.com) Like I said above I have forwarded all the correct TS ports.
    Jun 2008
    11,843
    Please make sure ,that the port 9987 is opened as UDP only and that your correct LAN Ip is used for this port.
    Feb 2012
    Still not resolved by the way.
    I opened AirPortUtility and configured all the correct TS ports like you said @dante696, I ran the run server commands, connected through localhost, and then gave someone my IP from ipchicken.com and they said it wasn't up. I don't get it.
    Jun 2008
    11,843
    Does AirPortUtility config your router or the local computer?
    Please make sure the port is opened as udp and i nyour router!
  1. Server will not start, logs included
    By JohnBran in forum Mac OS X
    Last Post: 24-02-2015, 09:22
  2. Private messages logs, channel logs, server logs
    By tjyeee in forum [TeamSpeak 2] Client Support
    Last Post: 14-12-2011, 08:03
  3. Replies: 12
    Last Post: 19-08-2010, 17:53
  4. Installation Issue (Error Sig included)
    By Bradtv in forum [TeamSpeak 2] Client Support
    Last Post: 11-09-2006, 19:42
  5. Major pinng issue when running server
    By ZackHenning in forum [TeamSpeak 2] Server Support
    Last Post: 15-07-2004, 08:54
