Page 1 of 7 123 ... LastLast
Results 1 to 15 of 103
    Krün, Germany
    509
    [Beta Channel] TeamSpeak Client 3.0.14
    just in time for Christmas, we are happy to release the next TeamSpeak Client version for testing in the beta channel.
    This release is somewhat special. While there are very little visibile changes, there have been various changes to the core system. Most noteable is the upgrade to the latest Qt version 5.2.0. Also we have updated pretty much everything in our build and deployment system. For you, the users, this release may be somewhat boring as there are no new cool things to look at. If everything works as before, the test is successful.
    Overall memory usage and performance should be noticably improved.
    There are still a couple of unfinished things in this release, it is an early beta and there will more beta releases in January. The upgrade to Qt 5 has been drastic and was much more time consuming than expected.
    The plugin API has been increased to 20. All plugins which depend on the TeamSpeak Qt libraries have to be rebuilt with Qt 5.2.0. There are some further plugin API changes in the pipeline which didn't make it into this first beta yet (PTT hotkeys, hi to the Arma 2 plugin guys, we have not forgotten you). This should follow with the second beta release expected in January.
    As usual, all feedback is greatly appreciated.
    The TeamSpeak dev team will be on vacation over the christmas holidays and will get back to this in beginning of January.
    We wish you all a happy Christmas and a successful new year.
    The changelog:
    === Client Release 3.0.14 28 Feb 2014
    + Updated to Qt 5.2.0. Updated compilers, runtime and third party libraries.
      This includes a multitude of changes to the TeamSpeak client to ensure
      transition from Qt 4 to 5. This is a major update under the hood.
    + Iconpacks can now be provided as a zip file. See gfx/default.zip
      Old folders gfx/default and gfx/countries will be emptied on update.
      Custom iconpacks are still supported. Icons in extracted folders take
      priority over zip archives if both exist.
      Note: Plugin authors have to provide their own icons.
    + The plugin SDK is now distributed as zip archive in pluginsdk.zip. The old
      pluginsdk folder is no longer updated, original files will be automatically
      deleted on update.
    + Added https support, so the client can now load and display remote icons from
      https pages. A https server banner will work after the next server release.
    * Distribute Windows runtime as DLLs in TeamSpeak installation root instead of
      using vcredist package. This is a temporary solution until the updater is
      able to run a downloaded vcredist package post-update if required.
    * Unused Qt 4 libraries will be deleted by the updater when the updater starts
      (so not immediately on first update, as the old updater still requires Qt 4).
    * Memory usage and overall performance optimizations.
    * Plugin API increased to 20. Plugins depending on Qt 4.8 have to be updated.
    * Plugin API: Added isDown parameter to requestHotkeyInputDialog function to
      support PTT key bindings. Note: It's in the pluginsdk.zip now!
    * Prevent client from connecting to ports > 65535.
    * Missing icons will be shown as a blue bordered icon with a number.
    * Inform users when a recording client joins or leaves your channel.
    * Permissions window allows to set b_channel_join_ignore_password for server
      groups, channel groups and clients.
    * "Install Overwolf" checkbox in Windows installer is now disabled by default.
    * Cache animated avatars/banners to lower hard disk access.
    * On Linux the system tray icon is now hidden by default due to incompatibilities
      with Qt and freedesktop tray icon standards. It can be activated in the
      options.
    * Privilege key window supports Multi-select for copy to clipboard action.
    * Improved integration with Overwolf for their latest 2014-02-03 release.
    * Moved chat format buttons from mainwindow into the chat input contextmenu.
      These actions will now add bbCode tags to the text instead of using a very
      basic WYSIWYG approach, which is too dependant on Qt CSS formatting risking
      to break on any Qt update.
    * Automatically format *bold* and _underline_ in received chat messages.
    - Fixed joystick/gamepad button count.
    - Fixed renaming profiles.
    - Fixed saving preset messages.
    - Removed "Hide in taskbar" option
    - Removed "Use double click to activate" option, tray icon activation is now
      using the platform standard behavior (double click on Windows, single click
      on other platforms)
    - Fixed an undefined file transfer status when transfer starts.
    - Fixed a possible file transfer crash when transfer starts.
    - Updated emoticons display which can now show more icons at once.
    - Fixed showing a blank main window when minimizing/maximizing the window
      quickly.
    - PTT key in capture profile is only shown from default hotkey profile.
    - Show error message on missing sound files.
    - Fixed possible crash when deleting a profile.
    - Fixed possible animated avatar freeze.
    - Fixed rare crash when increasing identity security level.
    - Fixed client name format in client banned message
    - Fixed wrong notification ID in channel created event
    To join the TeamSpeak beta channel, go to the TeamSpeak 3 Client installation folder and create a file "update.ini" with this content:
    [Channel]
    beta=true
    Last edited by dante696; February 28th, 2014 at 03:05 PM. Reason: Updated changelog for current beta version
    May 2010
    Verona - Italy
    120
    Can you explain why two spacers with two different simbols generate two different fonts: http://puu.sh/5RAr1.png ?
    15,368
    The font in server tree is hardcoded on every operation system.
    QT is doing that and there are more problems on Linux and MAC and Some on Windows8
    TeamSpeak FAQ || What should i report, when i open a client thread? ||NPL (Registration)
    May 2010
    Verona - Italy
    120
    Ok, then since Qt 5.2.0 bye bye stars, lol. I'll wait for a fix.
    April 2011
    Brasil
    25
    Quote Originally Posted by PeterS View Post
    The changelog:
    === Client Release 3.0.14 19 Dec 2013
    * Plugin API increased to 20. Plugins dependant on Qt 4.8 have to be updated.
    * Prevent client to connect to ports > 65535.
    [Channel]
    beta=true
    And Opus 1.1?
    Krün, Germany
    509
    Quote Originally Posted by Xteam View Post
    And Opus 1.1?
    Not yet. That's on our TODO list.
    September 2010
    30
    Channel / User appears twice.
    Don't know why but the expand button to show all channel is at standard at "+" even if all channel are displayed.
    So i clicked on that button and than i can see all channels / User twice. Looks a bit weird
    I took a small video to make it more visualize...
    Probably cause of a addon Theme in teamspeak (standard Stile and Icon pack only a different Theme)?
    ->Same problem at the standard Theme too.
    Last edited by Tomi-Toma; December 19th, 2013 at 03:19 PM. Reason: Same Problem on standard Theme
    15,368
    I can reproduce that.
    This happens when you have a sub-sub-channel.
    You will be able to expand it after your login, but it's wrong. It's already expanded.
    Thank you i will create a ticket for that.
    December 2013
    Bug with special character in 3.0.14 [Beta]
    The name of channels tree is bug with client 3.0.14 [Beta]
    http://puu.sh/5RKip.jpg
    http://puu.sh/5RKph.png
    http://puu.sh/5RKkR.png
    http://puu.sh/5RKjT.png
    2,702
    Using Windows Vista Home Premium SP2
    at the start of the program, windows shows a pop-up:
    ts3client_win32.exe Entry point not found
    "Entry point not found for the procedure
    K32GetProcessImageFileNameW
    in dynamic link library KERNEL32.dll"
    After "Accept" the client starts and, apparently, works as usual.
    In the client log:
    19/12/2013 17:00:53		Info	TeamSpeak 3 Client 3.0.14 (2013-12-19 09:08:14)
    19/12/2013 17:00:53		Info	SystemInformation: Windows Vista SP2 (6002) x86 Binary: 32bit
    19/12/2013 17:00:53	Direct Sound	Debug	setting timer resolution to 1ms
    19/12/2013 17:00:53		Info	*** Time [SPAWN_EVENTCONVERTER]: 266
    19/12/2013 17:00:58		Info	Failed to load plugin: C:\PotaBlava\TeamSpeak3_Client_Beta\plugins\appscanner_plugin.dll
    19/12/2013 17:00:58		Info	LoadLibrary error: 127
    19/12/2013 17:00:58		Info	*** Time [PLUGINS]: 5168
    19/12/2013 17:00:58	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    19/12/2013 17:00:58	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    19/12/2013 17:00:58		Info	*** Time [SERVERVIEWMANAGER]: 205
    19/12/2013 17:00:59	Input	Info	Default monitoring enabled
    19/12/2013 17:00:59		Info	*** Time [MAINWINDOW]: 6088
    19/12/2013 17:00:59		Info	*** Time [INIT]: 6089
    19/12/2013 17:00:59	ClientUI	Info	Qt version: 5.2.0
    19/12/2013 17:00:59	ClientUI	Info	Using configuration location: C:/PotaBlava/TeamSpeak3_Client_Beta/config/settings.db
    19/12/2013 17:00:59	ClientUI	Info	Last update check was: jue dic 19 16:31:04 2013
    And the appscanner plugin appears in red.
    15,368
    We thougt only WindowsXP runs into that problem.
    Thank you for that report.
    August 2011
    14
    Sometimes the chat sounds won't work.
    60
    Anyone have the problem when your client simply wont start?
    2013-12-19 18:08:09.555081|INFO    |              |   | TeamSpeak 3 Client 3.0.14 (2013-12-19 09:08:14)
    2013-12-19 18:08:09.555081|INFO    |              |   | SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    2013-12-19 18:08:09.555081|INFO    |              |   | Using hardware aes
    2013-12-19 18:08:09.610084|DEBUG   |Direct Sound  |   | setting timer resolution to 1ms
    2013-12-19 18:08:09.652087|INFO    |              |   | Skipping Qt4 dependant overlay plugin
    And thats all she wrote?
    Edit:
    Well i ended up restarting with no success. I tried to update again and it didnt download anything however i got a QtGUI4.dll error with it not existing. So me and my infinite wisdom decided to rename the Qt5Gui.dll to Qt5GUI4.dll and she fired up real quick.
    **i may have renamed the file while the popup was there and clicked ok and it started. So this rename may not have fixed anything fyi**
    2013-12-19 18:25:56.437281|INFO    |              |   | TeamSpeak 3 Client 3.0.14 (2013-12-19 09:08:14)
    2013-12-19 18:25:56.437281|INFO    |              |   | SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    2013-12-19 18:25:56.437281|INFO    |              |   | Using hardware aes
    2013-12-19 18:25:56.487284|DEBUG   |Direct Sound  |   | setting timer resolution to 1ms
    2013-12-19 18:25:56.529286|INFO    |              |   | Skipping Qt4 dependant overlay plugin
    2013-12-19 18:32:35.794123|INFO    |              |   | Failed to load plugin: C:\Program Files\TeamSpeak 3 Client\plugins\MusicBot.dll
    2013-12-19 18:32:35.795123|INFO    |              |   | LoadLibrary error: 126
    2013-12-19 18:32:35.825124|INFO    |              |   | Api version is not compatible for plugin: C:\Program Files\TeamSpeak 3 Client\plugins\TS3MassMover.dll
    2013-12-19 18:32:35.845126|INFO    |              |   | Api version is not compatible for plugin: C:\Program Files\TeamSpeak 3 Client\plugins\libtslove.dll
    2013-12-19 18:32:35.865127|INFO    |              |   | Api version is not compatible for plugin: C:\Program Files\TeamSpeak 3 Client\plugins\volumecontrol_plugin_win64.dll
    2013-12-19 18:32:35.866127|INFO    |              |   | *** Time [PLUGINS]: 399337
    2013-12-19 18:32:36.111141|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-12-19 18:32:36.111141|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-12-19 18:32:36.164144|INFO    |              |   | *** Time [SERVERVIEWMANAGER]: 146
    2013-12-19 18:32:36.310152|INFO    |Input         |   | Default monitoring enabled
    2013-12-19 18:32:36.364155|INFO    |              |   | *** Time [MAINWINDOW]: 399929
    2013-12-19 18:32:36.364155|INFO    |              |   | *** Time [INIT]: 399929
    2013-12-19 18:32:36.450160|INFO    |ClientUI      |   | Qt version: 5.2.0
    2013-12-19 18:32:36.450160|INFO    |ClientUI      |   | Using configuration location: C:\Users\Andrew\AppData\Roaming\TS3Client\settings.db
    2013-12-19 18:32:36.951189|INFO    |ClientUI      |   | Last update check was: Thu Dec 19 17:52:05 2013
    2013-12-19 18:32:36.952189|INFO    |ClientUI      |  1| Connect to server: 192.168.0.10
    2013-12-19 18:32:36.953189|INFO    |ClientUI      |  1| Blacklist check ok
    2013-12-19 18:32:36.953189|INFO    |ClientUI      |  1| Initiating connection: 192.168.0.10:9987 192.168.0.10
    2013-12-19 18:32:37.065195|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-12-19 18:32:37.065195|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-12-19 18:32:37.065195|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2013-12-19 18:32:37.093197|DEBUG   |Windows Audio Session|   | WAS Buffer size: 960
    2013-12-19 18:32:37.093197|DEBUG   |Windows Audio Session|   | WAS::openDevice-leave
    2013-12-19 18:32:37.094197|DEBUG   |Windows Audio Session|   | WAS::startDevice-enter
    2013-12-19 18:32:37.094197|DEBUG   |Windows Audio Session|   | WAS::startDevice-leave
    2013-12-19 18:32:37.248206|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-12-19 18:32:37.248206|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-12-19 18:32:37.248206|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2013-12-19 18:32:37.255206|DEBUG   |Windows Audio Session|   | WAS Buffer size: 960
    2013-12-19 18:32:37.255206|DEBUG   |Windows Audio Session|   | WAS::openDevice-leave
    2013-12-19 18:32:37.255206|INFO    |PreProSpeex   |  1| Speex version: speex-1.2beta3
    2013-12-19 18:32:37.255206|DEBUG   |Windows Audio Session|   | WAS::startDevice-enter
    2013-12-19 18:32:37.256206|DEBUG   |Windows Audio Session|   | WAS::startDevice-leave
    2013-12-19 18:32:37.258206|INFO    |ClientUI      |  1| Connect status: Connecting
    2013-12-19 18:32:37.266207|DEVELOP |PktHandler    |   | Puzzle solve time: 8
    2013-12-19 18:32:37.290208|INFO    |ClientUI      |  1| Connect status: Connected
    2013-12-19 18:32:37.395214|INFO    |ClientUI      |  1| Connect status: Establishing connection
    2013-12-19 18:32:37.404215|INFO    |ClientUI      |  1| Connect status: Connection established
    2013-12-19 18:32:37.416215|INFO    |PermManager   |   | Loading permissions from cache
    2013-12-19 18:32:37.998249|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - enter
    2013-12-19 18:32:37.998249|DEVELOP |Windows Audio Session|   | DeviceDeleteList::waitForDeletes - leave
    2013-12-19 18:32:37.998249|DEBUG   |Windows Audio Session|   | WAS::openDevice-enter
    2013-12-19 18:32:38.025250|DEBUG   |Windows Audio Session|   | WAS Buffer size: 1323
    2013-12-19 18:32:38.025250|DEBUG   |Windows Audio Session|   | WAS::openDevice-leave
    2013-12-19 18:32:38.025250|DEBUG   |Windows Audio Session|   | WAS::startDevice-enter
    2013-12-19 18:32:38.026250|DEBUG   |Windows Audio Session|   | WAS::startDevice-leave
    2013-12-19 18:32:38.026250|INFO    |              |   | *** Time [PLAYBACKPROFILE]: 118
    2013-12-19 18:32:38.039251|INFO    |              |   | *** Time [SERVERVIEW]: 133
    Thats what was spewed up to the server connection point (i auto connect to 5 servers at start)
    September 2010
    30
    Wrong translation in the rightclick menu from the chatbox.
    15,368
    Approved and ticket created for that.
    Thank you again (=
  1. [Beta Channel] TeamSpeak 3 Client 3.0.18
    By Chris in forum Archive
    Last Post: September 18th, 2015, 12:42 PM
  2. [Beta Channel] TeamSpeak 3 Client 3.0.17
    By PeterS in forum Archive
    Last Post: August 10th, 2015, 08:35 AM
  3. [Beta Channel] TeamSpeak 3 Client 3.0.10.1
    Last Post: April 1st, 2013, 11:50 AM
  4. [Beta Channel] TeamSpeak 3 Client 3.0.10
    Last Post: March 4th, 2013, 09:22 AM
  5. [Beta Channel] TeamSpeak 3 Client 3.0.9
    Last Post: October 22nd, 2012, 07:41 AM
