Results 1 to 7 of 7
    July 2007
    Denver
    TS3 server wont' start.Thinks another instance is running
    So, I have a VMware server setup with an Ubuntu VM running TS3.0.10.1.
    When I try to start the server I get the following error in the log:
    2014-06-25 03:35:31.414391|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.10.1 (2013-11-08 11:09:56)
    2014-06-25 03:35:31.414560|INFO    |ServerLibPriv |   | SystemInformation: Linux 2.6.38-15-server #66-Ubuntu SMP Tue Aug 14 17:42:23 UTC 2012 x86_64 Binary: 64bit
    2014-06-25 03:35:31.415905|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-06-25 03:35:31.415951|INFO    |DatabaseQuery |   | dbPlugin version: 3.7.3
    2014-06-25 03:35:31.416463|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2014-06-25 03:35:31.462862|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2014-06-25 03:35:31.963107|ERROR   |Accounting    |   | local accounting reports an already running instance, instance will shutdown
    2014-06-25 03:35:31.963168|ERROR   |ServerLibPriv |   | Server() error while starting servermanager, error: instance limit reached
    This all started after my son (age 1.5) decided it would be run to unplug the server. (No, he wasn't supposed to be down there... thank the wife for that one)
    So TS3 thinks there is already an instance of the server running, but there isn't. Nothing in ps, no .pid file anymore. I'm not sure what to do from here....
    any ideas?
    OTF
    6,078
    Hate to point out the obvious but...
    Quote Originally Posted by Roy
    Have you tried turning it off and on again?
    When checking if there is an instance running, make sure to check all processes, even those of other users. While you're at it you should also update to the latest TeamSpeak server version, which currently is 3.0.10.3
    December 2014
    Server seems to have died.
    Hello everyone,I have a little problem with my teamspeak3,hosted on a Linux server (Debian 7)
    My teamspeak runs perfectly,but when i check his status (by typing ./ts3server_startscript.sh status) it says "Server seems to have died".
    This is the log
    2014-12-05 12:23:54.123617|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.11.1 (2014-10-15 07:06:31)
    2014-12-05 12:23:54.123797|INFO    |ServerLibPriv |   | SystemInformation: Linux 2.6.32-042stab094.7 #1 SMP Wed Oct 22 12:43:21 MSK 2014 x86_64 Binary: 64bit
    2014-12-05 12:23:54.126759|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2014-12-05 12:23:54.126822|INFO    |DatabaseQuery |   | dbPlugin version: 3.6.21
    2014-12-05 12:23:54.127932|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2014-12-05 12:23:54.161972|WARNING |Accounting    |   | Unable to find valid license key, falling back to limited functionality
    2014-12-05 12:23:54.662835|ERROR   |Accounting    |   | local accounting reports an already running instance, instance will shutdown
    2014-12-05 12:23:54.662949|ERROR   |ServerLibPriv |   | Server() error while starting servermanager, error: instance limit reached
    It says that i have a running instance,and that might be the problem. Could you help me out?This is a screen of my running istances
    18,151
    There is already a server running.
    The error message does and PID 1989 also does tell you.
    You can not run a second instance without a license.
    Please stop the process, before you try to start your server.
    December 2014
    I fixed it,I had to stop the instance from the other user and start it again from Root
    Thank you for your kind answer.
    December 2004
    RF
    3,006
    Don't run your servers as root. It is unsupported.
    6,078
    Quote Originally Posted by Shining Crystal View Post
    which is something you shouldn't do. It warns you about it for a reason.
    You should create a new limited user account that runs the server.
  1. Replies: 0
    Last Post: February 23rd, 2014, 03:47 PM
  2. Replies: 2
    Last Post: August 20th, 2010, 02:31 PM
