Results 1 to 6 of 6
    July 2014
    Android client auto-connect
    Does anyone know if it is possible to get the android client to automatically connect to a server / bookmark when the app is launched?
    I am trying to use an old android phone to inject audio into a channel (like the radio / TV) It works fine but occasionally TS logs out after a while (around 8 hours) so i would like to set the phone to reboot every 6 hours, load Teamspeak 3 on boot and automatically connect to a server.
    Thanks,
    Chris.
    18,513
    This not possible with the mobile apps.
    The only way to connect to a server automatically** is to use a server invite. **But you have to apply, that you want to connect to it.
    July 2014
    Thanks for the quick reply. Saves me trying to make it work. Is this something that could be added in the future or is there a reason the mobile clients do not have this?
    18,513
    I don't think this will be added, as long no multi tabs are supported.
    *currently not planned on android*
    2,698
    Quote Originally Posted by chris021 View Post
    What value do you have in Settings --> Reconnect (Retry count, 0=no reconnect) ?
    July 2014
    Hi, i did have 15, but then i found out just how quickly 15 tries takes. i have now set it to 1500 which has kept it online for almost 24 hours now so that might have helped
