Results 1 to 10 of 10
    July 2014
    TSDNS/Hostname Error on 4G LTE, Works Fine on WiFi
    Carrier - T Mobile
    Phone - Note 3
    Android 4.4.2
    Can I connect to the public server on 4G? Yes
    I am attempting to connect to a teamspeak server using it's hostname and port. I do not know or have access to the IP address of this server.
    I have been looking everywhere I could for a fix to this or a workaround and found nothing that works or is reasonable. In all of my research, all I have found is a plethora of reviews citing this same issue, and posts and complaints citing this same issue. I also found that people that had a previous version of this app were able to connect to a server with mobile data but now they cannot. Thus, the claim that "it's your mobile carrier's fault" seems extremely unlikely to me. From what i've gathered, this issue is occurring on every mobile carrier and the only common issue is this version of the app.
    I also have and can use mumble and ventrilo apps and can connect to servers with them, but teamspeak alone is not working.
    Is there a workaround for this issue that I am not finding? Is there a fix in the works for this issue that is affecting quite a few users?
    May 2007
    Eastern NC
    1,798
    Carrier - Straight Talk (AT&T network sim)
    Phone - Samsung Galaxy S4 (GT-I9500 "octacore" running CM11-20140716-NIGHTLY)
    Android 4.4.4
    I'm having no problems with TSDNS while on WiFi or 3G. Some of my servers have SRV records and those are working fine also.
    I've attempted with and without the port and it is working fine for me.
    example of my tsdns setting file:
    example.domain.us=1.2.3.4:1337
    # following for backward compatibility for old bookmarks
    *=1.2.3.4:$PORT
    If I use example.domain.us or misspelled.domain.us:1337 I get to the correct server.
    July 2014
    Android 4.4.4
    *=1.2.3.4:$PORT
    Thanks?
    Not sure how this post is supposed to assist with this issue.
    If it helps, the server I am trying to connect to is nepenthium.typefrag.com:7075
    2,698
    Quote Originally Posted by Atreties View Post
    I've connected without issues to this server: Samsung TAB2 in wi-fi
    If you have issues, try connecting to glycol.typefrag.com:7075
    July 2014
    It works fine on wifi for me too, but that is completely useless to me and is not my issue.
    My issue is that i cannot connect using mobile data - 3G, 4G, 4G LTE. That is what i need solved.
    2,698
    Have you tried glycol.typefrag.com:7075 ??
    For this server the final IP is 54.86.92.103:7075
    July 2014
    YESSSS!!!
    thanks, super helpful.
    What solved my problem: Using the direct IP of the server instead of it's address name.
    I still consider this an issue that the app needs to solve, but this workaround works.
    18,037
    It's a problem with your mobile phone provider. He just can not resolve the address.
    It worked fine on my phone without Wifi enabled.
    May 2007
    Eastern NC
    1,798
    I could also connect using my mobile data.
    December 2011
    USA
    55
    Works fine with Sprint as well
  1. TSDNS Settings (can't resolve hostname)
    By lightitwithfire in forum Linux / FreeBSD
    Last Post: July 19th, 2014, 04:26 AM
  2. Replies: 1
    Last Post: June 20th, 2014, 03:54 AM
