This problem came up first time for a long time usage of teamspeak 3. When I try to join this specific server it connects me, but not completely and it only shows the people in the entrance channel. There is usually 40-60 people on the server.
I have tried:
- Reinstalling TS
- Restarting router
- Restarting PC
- Updating virus protection
<23:51:00> Trying to resolve hostname <server name here>
<23:51:00> Trying to connect to server on <server name here>
<23:51:49> Connection to server lost
<23:51:50> Trying to resolve hostname <server name here>
<23:51:51> Trying to connect to server on <server name here>
This keeps happening over and over and over again. Sometimes it lets me to go to a channel for a while and then disconnects.
Logs/Warning message:
2.8.2014 23:50:56 Info TeamSpeak 3 Client 3.0.15.1 (2014-07-14 12:31:32)
2.8.2014 23:50:56 Info SystemInformation: Windows 7 (7600) x64 (AMD or Intel) Binary: 64bit
2.8.2014 23:50:56 Direct Sound Debug setting timer resolution to 1ms
2.8.2014 23:50:56 Info Loading plugin: appscanner_plugin
2.8.2014 23:50:56 Info Loading plugin: clientquery_plugin
2.8.2014 23:50:56 Info Loading plugin: lua_plugin
2.8.2014 23:50:56 Info Loading plugin: teamspeak_control_plugin
2.8.2014 23:50:56 Info Loading plugin: test_plugin
2.8.2014 23:50:56 Info Loading plugin: ts3g15
2.8.2014 23:50:56 Query Info listening on 127.0.0.1:25639
2.8.2014 23:50:56 Info *** Time [PLUGINS]: 117
2.8.2014 23:50:56 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
2.8.2014 23:50:56 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
2.8.2014 23:50:56 Info *** Time [SERVERVIEWMANAGER]: 124
2.8.2014 23:50:57 Info *** Time [LOAD_usb_ids]: 220
2.8.2014 23:50:57 Input Info Default monitoring enabled
2.8.2014 23:50:57 Info *** Time [HOTKEYS]: 222
2.8.2014 23:50:57 Info *** Time [MAINWINDOW]: 817
2.8.2014 23:50:57 Info *** Time [INIT]: 817
2.8.2014 23:50:57 ClientUI Info Qt version: 5.2.1
2.8.2014 23:50:57 ClientUI Info Using configuration location: C:\Users\Santeri\AppData\Roaming\TS3Client\setting s.db
2.8.2014 23:50:57 ClientUI Info Last update check was: la elo 2 12:12:32 2014
2.8.2014 23:51:00 ClientUI Info Connect to server: ts.realliferpg.net
2.8.2014 23:51:00 ClientUI Info Trying to resolve ts.realliferpg.net
2.8.2014 23:51:00 TSDNS Info SRV DNS resolve unsuccessful for "_ts3._udp.ts.realliferpg.net"
2.8.2014 23:51:00 TSDNS Info No SRV TSDNS found at "_tsdns._tcp.ts.realliferpg.net"
2.8.2014 23:51:00 TSDNS Info DNS resolve successful, "ts.realliferpg.net"=66.150.214.111
2.8.2014 23:51:00 ClientUI Info Lookup finished: 66.150.214.111 9987 ts.realliferpg.net 0 0
2.8.2014 23:51:00 ClientUI Info Resolve successful: 66.150.214.111:9987
2.8.2014 23:51:00 ClientUI Info Blacklist check ok
2.8.2014 23:51:00 ClientUI Info Initiating connection: 66.150.214.111:9987 ts.realliferpg.net
2.8.2014 23:51:00 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
2.8.2014 23:51:00 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
2.8.2014 23:51:00 Windows Audio Session Debug WAS:penDevice-enter
2.8.2014 23:51:00 Windows Audio Session Debug WAS Buffer size: 882
2.8.2014 23:51:00 Windows Audio Session Debug WAS:penDevice-leave
2.8.2014 23:51:00 Windows Audio Session Debug WAS::startDevice-enter
2.8.2014 23:51:00 Windows Audio Session Debug WAS::startDevice-leave
2.8.2014 23:51:00 PreProSpeex Info Speex version: speex-1.2beta3
2.8.2014 23:51:00 ClientUI Info Connect status: Connecting
2.8.2014 23:51:01 PktHandler Devel Puzzle solve time: 9
2.8.2014 23:51:02 ClientUI Info Connect status: Connected
2.8.2014 23:51:02 ClientUI Info Connect status: Establishing connection
2.8.2014 23:51:49 SCHandler Warning Got command data while disconnected, dropping
2.8.2014 23:51:49 ClientUI Info Connect status: Disconnected
2.8.2014 23:51:49 ClientUI Info Connection lost, want autoreconnect = 1
2.8.2014 23:51:50 ClientUI Info Autoreconnecting
2.8.2014 23:51:50 ClientUI Info Connect to server: ts.realliferpg.net
2.8.2014 23:51:50 ClientUI Info Trying to resolve ts.realliferpg.net
2.8.2014 23:51:50 TSDNS Info DNS resolve successful, "ts.realliferpg.net"=66.150.214.111
2.8.2014 23:51:50 TSDNS Info SRV DNS resolve unsuccessful for "_ts3._udp.ts.realliferpg.net"
2.8.2014 23:51:51 ClientUI Info Lookup finished: 66.150.214.111 9987 ts.realliferpg.net 0 0
2.8.2014 23:51:51 ClientUI Info Resolve successful: 66.150.214.111:9987
2.8.2014 23:51:51 ClientUI Info Blacklist check ok
2.8.2014 23:51:51 ClientUI Info Initiating connection: 66.150.214.111:9987 ts.realliferpg.net
2.8.2014 23:51:51 ClientUI Info Connect status: Connecting
2.8.2014 23:51:51 PktHandler Devel Puzzle solve time: 13
2.8.2014 23:51:52 ClientUI Info Connect status: Connected
2.8.2014 23:51:52 ClientUI Info Connect status: Establishing connection
2.8.2014 23:52:39 SCHandler Warning Got command data while disconnected, dropping
2.8.2014 23:52:39 ClientUI Info Connect status: Disconnected
2.8.2014 23:52:39 ClientUI Info Connection lost, want autoreconnect = 1
2.8.2014 23:52:40 ClientUI Info Autoreconnecting
2.8.2014 23:52:40 ClientUI Info Connect to server: ts.realliferpg.net
2.8.2014 23:52:40 ClientUI Info Trying to resolve ts.realliferpg.net
2.8.2014 23:52:40 TSDNS Info SRV DNS resolve unsuccessful for "_ts3._udp.ts.realliferpg.net"
2.8.2014 23:52:40 TSDNS Info No SRV TSDNS found at "_tsdns._tcp.realliferpg.net"
2.8.2014 23:52:40 TSDNS Info DNS resolve successful, "ts.realliferpg.net"=66.150.214.111
2.8.2014 23:52:41 ClientUI Info Lookup finished: 66.150.214.111 9987 ts.realliferpg.net 0 0
2.8.2014 23:52:41 ClientUI Info Resolve successful: 66.150.214.111:9987
2.8.2014 23:52:41 ClientUI Info Blacklist check ok
2.8.2014 23:52:41 ClientUI Info Initiating connection: 66.150.214.111:9987 ts.realliferpg.net
2.8.2014 23:52:41 ClientUI Info Connect status: Connecting
2.8.2014 23:52:41 PktHandler Devel Puzzle solve time: 13
2.8.2014 23:52:52 ClientUI Info Connect status: Disconnected
2.8.2014 23:52:52 ClientUI Info Failed to connect to server, want autoreconnect = 1
2.8.2014 23:52:53 ClientUI Info Autoreconnecting
2.8.2014 23:52:53 ClientUI Info Connect to server: ts.realliferpg.net
2.8.2014 23:52:53 ClientUI Info Trying to resolve ts.realliferpg.net
2.8.2014 23:52:53 TSDNS Info DNS resolve successful, "ts.realliferpg.net"=66.150.214.111
2.8.2014 23:52:53 TSDNS Info SRV DNS resolve unsuccessful for "_ts3._udp.ts.realliferpg.net"
2.8.2014 23:52:57 ClientUI Info Lookup finished: 66.150.214.111 9987 ts.realliferpg.net 0 0
2.8.2014 23:52:57 ClientUI Info Resolve successful: 66.150.214.111:9987
2.8.2014 23:52:57 ClientUI Info Blacklist check ok
2.8.2014 23:52:57 ClientUI Info Initiating connection: 66.150.214.111:9987 ts.realliferpg.net
2.8.2014 23:52:58 ClientUI Info Connect status: Connecting
2.8.2014 23:52:58 PktHandler Devel Puzzle solve time: 6
2.8.2014 23:52:59 ClientUI Info Connect status: Connected
2.8.2014 23:52:59 ClientUI Info Connect status: Establishing connection
