Results 1 to 4 of 4
    August 2014
    Problem configuring the temporary channel delete delay
    In my TS3 server I allow the guests to create new temporary channels and that channels are deleted when are empty.
    I would like to configure the delete delay for that channels setting the delay in 2 days (172800 seconds) and I prefer to force this configuration, dont allowing the users to modify it.
    I tried several configuration options trying to achieve that but anyone of them has worked (is my first TS3 server, im a noob configuring it). Let me show you how looks my Permissions > "Server group" tab, filtering by "delay":
    What am I doing wrong?
    Thanks!
    April 2014
    Seattle, WA, USA
    141
    Please remove the "Temporary channel delete delay" permission from all/any Server Groups and Channel Groups.
    To set Temporary channel delete delay, right-click on the top most "channel" (should have the name over your server) and select Edit Virtual Server
    In the pop-up, in the bottom half, select the Misc tab.
    Then enter your value in seconds for the option Delete delay for temporary channels.
    Click Apply / OK and you're all set.
    By default no users will have the option to change the "temporary delete delay" unless you give it to them.
    August 2014
    Thats exactly what I wanted to do, thanks!!
    December 2012
    8
    default temp delete delay
    Is there a possibility to put
    i_channel_create_modify_with_temp_delete_delay
    to a default of 2 days? So when a user creates a channel it will always have a default of 172800 seconds.
    I hope this is possible.
  1. Replies: 10
    Last Post: November 19th, 2015, 12:30 PM
  2. [No Bug] Temporary Channel deletion delay only 24 hours
    By Soulflare3 in forum Bug Reports [EN/DE]
    Last Post: September 25th, 2015, 09:24 AM
  3. [Not possible] Increase limit on delete delay for temporary channels
    By qvazzler in forum Suggestions and Feedback
    Last Post: May 2nd, 2014, 11:20 AM
  4. Delete Delay For Permanent Channels.
    By H3LLFIRE in forum Suggestions and Feedback
    Last Post: April 26th, 2014, 12:07 PM
  5. Replies: 3
    Last Post: May 7th, 2010, 10:39 AM
