Results 1 to 9 of 9
    November 2010
    18
    TeamSpeak freezes after trying to edit nickname in default identity
    I have the following problem with TeamSpeak 3.0.16:
    If I select "Settings", "Identities" and then edit the nickname of my "Standard" identity and press OK, then the TeamSpeak GUI completely freezes and doesn't recover anymore within the next five minutes. If I'm connected to a server I can still talk and listen, but the user interface is completely frozen and it is not redrawn anymore and doesn't react to any input. I have to close Teamspeak by forcing it in the taskbar or by using the Taskmanager. Trying to set a Phonetic Nickname for my "Standard" identity has the same effect.
    However if I don't change anything at my default identity, pressing OK doesn't cause a freeze. Furthermore I can edit the nickname of other identities without any problems. I don't know if it matters, but Security Level of my "Standard" identity is 32. My other identities only have 20.
    Another user at my Teamspeak server has the same problem. But the problem also happens when I'm not connected to any server.
    I don't know if this problem already existed in earlier versions of TeamSpeak.
    TS3 Version: 32 bit, 3.0.16 (04.08.2014 15:42:43) [Stable]
    OS Version: Windows XP, 32 bit (latest updates)
    17,939
    We are aware of a small freeze, when an identity nickname was changed, while you have some bookmarks using this idenity.
    All Bookmarks are updating during this.
    How many bookmarks use this identity?
    what CPU do you have?
    November 2010
    18
    Processor: Intel Core 2 Duo, E8400 @ 3,00GHz
    Number of Bookmarks: 96 (all of them are using the standard identity)
    I have checked my bookmarks. All of them had a Phonetic Nickname set to the value from my test, but the standard identity was not changed.
    17,939
    WOOW, that are more than a lot bookmarks. Just tested this with ~10.
    I will add this topic for the next Dev meeting, maybe something can be improved here.
    November 2010
    18
    Collected within 3,5 years of MMORPG. Well, I have to admit that about 50% of them are dead. I'm too lazy to sort them out. But the others are really used when needed. And those which are used on a regular basis (about 10%) are organized.
    17,939
    We will fix this problem in one of our upcomming client version.
    No ETA for this.
    September 2015
    United Kingdom
    No ETA for this.
    Still getting this issue. I do have a lot of bookmarks.
    March 2011
    39
    Same issue here... I have about 80 bookmarks.
    17,939
    Client 3.1 will remove & replace the feature that renaming the identity renames the set nickname in your bookmarks.
    In client 3.1 you need to remove the nickname from bookmark(s).
    The client will use the nickname that is set in your selected identity.
  1. Replies: 5
    Last Post: December 15th, 2014, 11:21 AM
  2. Programmatically edit connected client's nickname
    By Geedon in forum Server Support
    Last Post: February 22nd, 2013, 02:55 PM
  3. Identity and nickname questions
    By 3niv2 in forum Windows
    Last Post: October 20th, 2011, 07:39 AM
  4. nickname edit
    By laraiders2 in forum Client Support
    Last Post: August 5th, 2011, 11:38 AM
  5. [Suggestion] Lock NickName to Identity Option
    By HakuAnime in forum Suggestions and Feedback
    Last Post: January 14th, 2010, 12:40 PM
