Results 1 to 3 of 3
    August 2014
    Connection problems to TS3 on Centos7
    I have installed a Teamspeak3 Server on Centos 7. The installation was as easy as I know it from several previouse installations on Linux. This server installation is for a LAN only server. Now my problem is to conenct to the server. Teamspeak is running but I canīt connect. I donīt know why. Is there probably a problem because of the server hat 4 LAN interfaces?
    What I allready tried is to set the IP to 0.0.0.0 and I even tried to set the IP to 192.168.22.100.
    Do you have any ideas?
    Thanks
    Moddi89
    August 2014
    try turnning off firewalld
    service firewalld stop
    August 2014
    Quote Originally Posted by Moddi89 View Post
    Thanks
    Moddi89
    First you have to know in which zone (firewalld) are your LAN Interface with (root):
    firewalld-cmd --list-all
    By default all interfaces are in public (non-trusted).
    You can create a new zone (HOME) or continue to use public.
    if you decide to use public you can open ts3 server port :
    firewalld-cmd --zone=public --add-port=9987/udp
    firewalld-cmd --zone=public --add-port=30033/tcp
    firewalld-cmd --zone=public --add-port=10011/tcp
    Now you can test your client's connection.
    If your clients can connect, you have to open the port permanently with --permanent and reload firewalld:
    firewalld-cmd --permanent --zone=public --add-port=9987/udp
    firewalld-cmd --permanent --zone=public --add-port=30033/tcp
    firewalld-cmd --permanent --zone=public --add-port=10011/tcp
    firewalld-cmd --reload
    If you don't do that, after next reboot the port will be closed.
    I hope it will help you.
    PS: in CentOS/Redhat 7 use systemctl instead of service : systemctl stop firewalld
  1. Connection and connection lost problems.
    By Kalic in forum Windows
    Last Post: July 16th, 2012, 11:31 AM
  2. Replies: 3
    Last Post: February 10th, 2011, 11:26 AM
