Page 5 of 6 FirstFirst ... 3456 LastLast
Results 61 to 75 of 76
  1. #61
    June 2018
    I want to back up my server
    I want to back up my teamspeak3 server, the host owner I bought will close the company, I'll go to another company, and I want to back up my teamspeak3 server as more than 300 players get in a day
  2. #62
    August 2018
    Update server to 3.3 without permissions
    Removed unsupported language.
    Hello, I would like to know how to set up a Linux server on my server with the new version without permission
  3. #63
    August 2018
    Update TS3 server to new version and migrate from previous version
    What is the best way to backup and migrate my server to the new version? First try was a fail for me and I lost access to my original server. I have access back now thanks to Putty but need help with this migration as I have been searching google and these forums for 2 days. I am very sorry if this has been asked before.
  4. #64
    August 2018
    update to 3.3 server with configuration
    I have a win server ts 3.0. How i can update to 3.3 version with my config (group, permissions, etc.)? i try just copy folders, but server dont start.
    Thanks for reading.
  5. #65
    17,363
    Please read server log 0.
    How to is explained in post #2
    Quote Originally Posted by Kayakoh View Post
    I doubt that you can setup/update anything without permissions. They are at least the minimum to do something server related.
    Last edited by dante696; August 17th, 2018 at 09:02 AM. Reason: Quote and answer added
  6. #66
    August 2018
    Upgrading a new server on top of an existing/established one
    Getting an error saying the server is too old and needs to upgrade, as it does not recognize the new clients.
    Is there a way to do this WITHOUT redoing the whole damn thing...
    (As it is a big server and ALOT of work keeping it afloat as it is)
    What files pertain to the clients and the channels in the server and I will restore those and ONLY those if it comes necessary, as we back this up regularly.
    Respectfully,
    MM3 N.A Miller, USN Ret.
    Protected Veteran/Gentleman Writer
    Lead Administrator / First Officer / CISO
    FlightSimX Co. Gaming Community.
    99.8.84.167:9987
    www.mrcats21FSimX.ning.com
  7. #67
    August 2018
    Clean Install
    I want to do a clean install. How do I delete the old version... Ive tried and then I install 3.3 yet somehow its still the old version.. I dont need anything from the old version... I never have more than 5 people in the server
  8. #68
    17,363
    The reason why the server shows an old er version is easy to explain.
    You did start the old version or you did not overwrite the server.
    To make a clean start just delete the old server directory.
  9. #69
    September 2018
    how do i backup a server
    Hello there,
    I have a qeusting, how do i backup my own teamspeak server, because everytime i restart my pc the server resets its self, and i don't want to make the server over and over again.
    kind regards gregory
  10. #70
    17,363
    A backup will not help you. You should read the server log for error and make sure your user who started the server has all permissions to write and read files in your server folder.
    About the backup:
    Scroll up to this post and then follow step 3 (optional 3.1).
    Or copy the whole server folder.
  11. #71
    February 2019
    TeamSpeak Server Migration CentOS 7
    I was using TS in CentOS 7 server. I need to migrate the old TS to another CentOS 7 server. I already installed fresh copy TS in the new server but I need all old channels and configuration. How can I migrate my old TS channels and configuration to the new server?
    I already deleted the new server ts3server.sqlitedb and uploaded old server ts3server.sqlitedb but it did not work.
    Kindly please help me. Which files I need to replace so that my old TS server channels and configuration I can get back.
    Thank So Much In Advanced
    Jubayer Rahman
  12. #72
    February 2019
    Not Working Anymore. Not Worked For Me :'(
  13. #73
    17,363
    Quote Originally Posted by Jub-AIUB View Post
    This how to is still working.
    Please give us more details than that. At least a server log?
    Please do not create new threads with same content.
  14. #74
    February 2019
    I stop the previous server and created a backup. Then I set up a new TS server in the new CentOS 7 server. Then I replaced these files:
    query_ip_blacklist
    query_ip_whitelist
    ts3server
    files
    logs
    After that I tried to start the server:
    systemctl start teamspeak
    and its giving me following error:
    teamspeak.service - TeamSpeak Server Service
    Loaded: loaded (/usr/lib/systemd/system/teamspeak.service; enabled; vendor preset: disabled)
    Active: activating (auto-restart) (Result: exit-code) since Thu 2019-02-07 22:23:26 UTC; 3s ago
    Process: 17403 ExecStop=/opt/teamspeak/ts3server_startscript.sh stop (code=exited, status=0/SUCCESS)
    Process: 17394 ExecStart=/opt/teamspeak/ts3server_startscript.sh start inifile=ts3server.ini (code=exited, status=0/SUCCESS)
    Main PID: 17398 (code=exited, status=1/FAILURE)
    Feb 07 22:23:26 ip-172-31-28-118.ap-south-1.compute.internal systemd[1]: Unit teamspeak.service entered failed state.
    Feb 07 22:23:26 ip-172-31-28-118.ap-south-1.compute.internal systemd[1]: teamspeak.service failed.
    Any help please?
    Thank You In Advance
  15. #75
    February 2019
    journalctl -xe
    Feb 07 22:45:58 ip-172-31-28-118.ap-south-1.compute.internal teamspeak[20283]: TeamSpeak 3 server started, for details please view the log file
    Feb 07 22:45:58 ip-172-31-28-118.ap-south-1.compute.internal teamspeak[20283]: ERROR: openFile( file:logs/ts3server_2019-02-07__22_45_58.194506_0.log) failed
    Feb 07 22:45:58 ip-172-31-28-118.ap-south-1.compute.internal teamspeak[20283]: 2019-02-07 22:45:58.215346|CRITICAL|SQL | |failed to update permissions, halted!
    Feb 07 22:45:58 ip-172-31-28-118.ap-south-1.compute.internal teamspeak[20283]: ts3server has crashed. A crashdump has been generated at "/opt/teamspeak/crashdumps/ts3server_3_6_1_linux_amd64_21f8-6002-f436-f5d1.dmp"
    Feb 07 22:45:58 ip-172-31-28-118.ap-south-1.compute.internal systemd[1]: teamspeak.service: main process exited, code=exited, status=1/FAILURE
    Feb 07 22:45:58 ip-172-31-28-118.ap-south-1.compute.internal teamspeak[20292]: Stopping the TeamSpeak 3 serverdone
    Feb 07 22:45:58 ip-172-31-28-118.ap-south-1.compute.internal systemd[1]: Unit teamspeak.service entered failed state.
    Feb 07 22:45:58 ip-172-31-28-118.ap-south-1.compute.internal systemd[1]: teamspeak.service failed.
  1. Hard drive failure resulting in corrupt DB file
    By OhYou_ in forum Server Support
    Last Post: April 13th, 2017, 12:25 PM
  2. How to get ts unique id of recoverd hard drive
    By nick2031 in forum General Questions
    Last Post: July 20th, 2013, 05:24 AM
  3. Move Teamspeak-Server to another machine?
    By c0bra in forum Linux / FreeBSD
    Last Post: June 21st, 2012, 07:26 AM
  4. Hard drive crashed - Accessing TS3 servers again
    By subrand0m in forum Client Support
    Last Post: January 23rd, 2011, 07:01 AM
  5. Help:- How can I backup all my hard work Please ?
    By MagicBytes in forum Windows
    Last Post: February 16th, 2010, 01:24 PM
