Results 16 to 30 of 38
  1. #16
    18,255
    It would solve the problem that the value is not stored in the database as it should.
    But biggest problem now would be that the client isn't able to set a channel icon any longer.
    We may overhaul this or the client or delay the change.
  2. #17
    18,255
    With next server version 3.9.0 we decided to deny when a user tries to set a channel icon with the channeledit command.
    Back to this.
    We evaluated if something would break. Everything works as expected.
    Clients still can set icons via permission or channel create/edit dialog and the ServerQuery allows to set icons with command channeladdperm cid=x i_icon_id=x
    Server 3.9.0 will no longer allow to use the channeledit command for this.
  3. #18
    October 2003
    2,527
    Just to clarify the situation... the reason why we decided to prevent the icon ID from being set using channeledit is that is was inconsistent behavior. Other commands like serveredit and clientedit do not allow setting the icon ID either since it's supposed to be changed via permission. What happened before is that channeledit updated the read-only channel property... which might seem convenient, but actually was a bug and lead to a series of issues such as the permissions not being updated.
    Anyway... we feel it's better to provide a consistent API to our users and there are a lot of other things we need to tackle in that area.
  4. #19
    February 2014
    276
    Do you have to channeldelperm each time to add a new perm or is there a way to edit it?
    With my testing if you try to set a new value with channeladdperm it will error with:
    channeladdperm cid=453 permsid=i_icon_id permvalue=2524640421
    error id=1540 msg=convert\serror
    as
    channeledit cid=453 channel_icon_id=2524640421
    Works consistently without any problems for me.
  5. #20
    October 2003
    2,527
    Quote Originally Posted by Patrick1164 View Post
    Just calling channeladdperm again with the new value is enough.
    This will be fixed with the upcoming 3.9.0 server release.
  6. #21
    September 2016
    76
    Back to this.
    Great, thanks for the clarification
  7. #22
    February 2014
    276
    Ah okay great thanks, wont update my code until 3.9 is running then!
  8. #23
    4,368
    Ehm, what?
  9. #24
    October 2003
    2,527
    Ehm, what?
    My mistake... obviously, the server itself has no permissions. So we're only talking about clientedit and channeledit.
  10. #25
    February 2014
    276
    No mention of the fix for channeladdperm being able to change icon if channel already has perm in 3.9 changelog, is this included?
  11. #26
    18,255
    There is no fix to set an icon with that command when a icon is set already.
    That worked before and still works.
    New is that you can use 2524640421 (Unsigned Int) or -1770326875 (Signed Int) to set an icon via permission commands.
  12. #27
    February 2014
    276
    I don't understand, this doesn't work.
    I first set the channel with no icon perm to:
    channeladdperm cid=453 permsid=i_icon_id permvalue=2101350922
    error id=0 msg=ok
    Then:
    Third:
    channeladdperm cid=453 permsid=i_icon_id permvalue=3373850627
    But if I then do:
    channeladdperm cid=453 permsid=i_icon_id permvalue=-1770326875
    error id=0 msg=ok
    Is this fixed in 3.9?
  13. #28
    18,255
    Are you talking about 3.8.0 where you get the errors?
    Yes this was changed (not fixed) for server 3.9.0 Beta1
  14. #29
    February 2014
    276
    Well you're disabling channel edit being able to set the icon, which I use in some code so I'm preparing for that change in 3.9, I wanted to know if this behaviour was changed so that you could set an icon via permission if the channel already has one.
    Is this now possible in 3.9?
  15. #30
    4,368
    Using channeledit to set icons never worked properly, so you shouldn't have done it before. That's why this thread was created. And TeamSpeak now removed a feature that never worked. So I don't see the issue.
    dante said that 3.9.0 accepts signed and unsigned integers.
  1. [Resolved] setChannelVariable CHANNEL_ICON_ID impossible to change ID
    By MiguelSnake in forum Client Plugins / Lua Scripts
    Last Post: November 29th, 2016, 01:18 PM
  2. Is there an possibility to make channeledit silent?
    By globalcookie in forum Server Support
    Last Post: May 17th, 2016, 12:28 PM
  3. channel_icon_id problem (out of range)
    By filimonic in forum Linux / FreeBSD
    Last Post: June 19th, 2012, 12:07 PM
  4. [Resolved] ServerQuery channel_icon_id problem
    By devour in forum Linux / FreeBSD
    Last Post: January 26th, 2012, 10:02 AM
  5. Query channeledit and codec encrypted
    By florian_fr40 in forum Bug Reports [EN/DE]
    Last Post: October 13th, 2010, 12:04 PM
