Page 1 of 5 123 ... LastLast
Results 1 to 15 of 66
    Baghdad, Iraq
    367
    TS3Chan v2 [beta] PHP Web-based automated Channels request system
    Few months ago a user asked for a script that takes requests with admin panel to accept/deny the requests and auto create the requested channel
    i offered to help and the simple idea got bigger and bigger so here is a beta release for everyone
    --- Am not a professional programmer so am sure there is some bugs and/or bad practice so please inform me if you find any
    the history is work in progress and the settings only have change password for now
    TODO:
    - History with the ability to Redo the request, Email the owner, and delete.
    - More email options mail() and sendmail support.
    - Channels list cache to check if the channel name is already in use.
    - Bad channel names filter.
    - Verify email address option.
    Ts3Chan (Beta)
    Download: https://github.com/Ahmed-90/ts3Chan
    PHP Web based system for Teamspeak 3 servers to Request channels on the server.
    Free opensource feel free to use, edit and share but don't forget to give credit/linkback and of you added something feel free to pull request
    Features:
    • Admin CP for accepting/rejecting requests. (with the abilty to sort, search and requests per page)
    • Limit requests per email.
    • Auto channel create.
    • Create channels anywhere with base OrderID. (not only in the bottom of channels list)
    • Create channels with custom permissions. (multi permissions supported)
    • Auto email on accept/deny the request with a custom message. (SMTP based)
    • Email the channel admin token on accept.
    • Basic email templating. (also supports custom message)
    • Language/translation support with clean seperated language files.
    Installation:
    1. Import the dependencies "composer update" (more info www.getcomposer.org)
    2. Check files in "app/config" edit the values as you wish.
    3. Set the "app/cache" & "app/logs" folders to writable "chmod 777"
    4. Edit the ".htaccess" in the public folder change it to your new base Example:- link is "www.site.com/requestchannel/public" then the base is "/requestchannel/public/" so "RewriteBase /ts3chan_v2/public/" to "RewriteBase /requestchannel/public/"
    5. Create the database and import the "ts3chan.sql"
    and it should work
    --- important info ---
    • Default admin pass: "admin" (change it in settings) and admin CP link is "/public/admin"
    • If something didn't work check "app/logs/errors.log"
    • To change language go to "app/lang" copy the "en" folder and rename it then edit the language files as you wish, when done edit set your new language in the "General.php" file in the configs folder "app/config"
    THERE WILL BE BUGS
    Credits
    July 2014
    38
    Its working as it should. Thanks for your time
    October 2003
    2,527
    Very nice! :-)
    Baghdad, Iraq
    367
    Thanks ScP wouldn't happen without your awesome framework
    June 2012
    Portugal
    317
    Haven't installed since my TS has self channel creation but looks nice
    November 2014
    Red face
    Hi, thanks for you work ^^
    I have one problem when i accept the petitions heres the log:
    [2014-11-06 02:21:22] log.ERROR: Error ["[object] (TeamSpeak3_Adapter_ServerQuery_Exception: invalid channelID at /var/zpanel/hostdata/zadmin/public_html/shadowsquad_es/ts3chan/vendor/planetteamspeak/ts3-php-framework/libraries/TeamSpeak3/Node/Server.php:599)"] []
    [2014-11-06 02:21:22] log.ERROR: Error ["[object] (TeamSpeak3_Transport_Exception: Failed to parse address \":\" at /var/zpanel/hostdata/zadmin/public_html/shadowsquad_es/ts3chan/vendor/planetteamspeak/ts3-php-framework/libraries/TeamSpeak3/Transport/TCP.php:54)"] []
    May can you helpme to fix it?
    Ty
    Baghdad, Iraq
    367
    did you set the base channelID in the config??
    in the "app/tsconfig.php"
        'base'      	=> '250',		// BASE Channel ID The channels will be created ABOVE this channel.
    you simply set this to a base channel so everything you accept will be created above it this allow you to create channels anywhere see img:
    in the example above you enter the base channelID and your accepted channels will be created between the 2 spacers
    November 2014
    Thumbs up
    Quote Originally Posted by Ahmed View Post
    Thanks, now work!
    One request, may u can add one lane for Unique ID channel admin? its possible? So give auto channel-admin to the guy?
    Baghdad, Iraq
    367
    there is already a Channel admin token generated and included in the email template in app/config/email.php
    you can just make an invite url with the template there is %token% for raw tokens and %tokenURL% for url encoded token to use in a server invite link (like invite buddy feature in TS Client)
    most users dont know there UID so i guess its better this way ?? if there is a good reason not to use tokens then please tell me i will see what can i do about it
    //EDIT got this in PM but i guess it will be common issue so there you go
    Quote Originally Posted by skinhead
    Hey there got these errors:
    [06-Nov-2014 18:18:09 UTC] PHP Warning: require_once(/home/xtremecm/public_html/pan/vendor/autoload.php) [<a href='function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory in /home/xtremecm/public_html/pan/app/start.php on line 8
    [06-Nov-2014 18:18:09 UTC] PHP Fatal error: require_once() [<a href='function.require'>function.require</a>]: Failed opening required '/home/xtremecm/public_html/pan/vendor/autoload.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/xtremecm/public_html/pan/app/start.php on line 8
    you have to use composer to download the dependencies needed to run the system see: https://getcomposer.org/doc/00-intro.md
    you just need to get composer and in CMD run "composer update" it will download the needed files
    June 2012
    Portugal
    317
    How to easily get up and running composer for those who don't know:
    Go to the TS3Chan folder and:
    curl -sS https://getcomposer.org/installer | php
    Then
    php composer.phar update
    After finished it will work.
    Composer is used in all major modern frameworks
    Edit:
    I haven't used but I suggest that you show a list of the channels in the admin panel and allow to select that one as the base channel! Hehe OR suggest something on how to show channel id.
    Baghdad, Iraq
    367
    @barricas
    Thanks for your addition everyone should learn to use composer
    about the suggestion yes thats already planned its config based atm and the settings page is just for password change but am planing a full settings page where the user only needs to edit the config for the DB info on installation
    April 2013
    42
    I used composer and I got this:
    And my webpage is just white and no error logs
    monolog/monolog suggests installing graylog2/gelf-php (Allow sending log message s to a GrayLog2 server)
    monolog/monolog suggests installing raven/raven (Allow sending log messages to a Sentry server)
    monolog/monolog suggests installing doctrine/couchdb (Allow sending log messages to a CouchDB server)
    monolog/monolog suggests installing ruflin/elastica (Allow sending log messages to an Elastic Search server)
    monolog/monolog suggests installing videlalvaro/php-amqplib (Allow sending log m essages to an AMQP server using php-amqplib)
    monolog/monolog suggests installing ext-amqp (Allow sending log messages to an A MQP server (1.0+ required))
    monolog/monolog suggests installing ext-mongo (Allow sending log messages to a M ongoDB server)
    monolog/monolog suggests installing aws/aws-sdk-php (Allow sending log messages to AWS services like DynamoDB)
    monolog/monolog suggests installing rollbar/rollbar (Allow sending log messages to Rollbar)
    Writing lock file
    Generating autoload files
    Baghdad, Iraq
    367
    ignore these composer messages these are unused dependencies from monolog
    did you set the "app/logs" and "app/cache" folders permissions to writable (777)?
    April 2013
    42
    Yes I did change the permissions to 777
    Baghdad, Iraq
    367
    what about step 4 ?
  1. [Request] Welcome Popup Message based on server groups
    By MuerteInHell in forum Tools / Web Based
    Last Post: September 7th, 2018, 05:32 AM
  2. [REQUEST] Point system based on time
    By C4TFLY in forum Client Plugins / Lua Scripts
    Last Post: November 8th, 2014, 05:25 PM
  3. How to Access Channels based on their icon?
    By NYC74 in forum Permission System
    Last Post: October 22nd, 2014, 04:55 PM
  4. Possible to lock channels based on groups?
    By Somtaaw in forum General Questions
    Last Post: October 8th, 2013, 12:57 PM
  5. Token System, With Permissions. Web Based
    By slowride326 in forum Server Support
    Last Post: July 14th, 2013, 06:34 AM
