(gdb) r
Starting program: /opt/teamspeak3/ts3client_linux_amd64
warning: Could not load shared library symbols for linux-vdso.so.1.
Do you need "set solib-search-path" or "set sysroot"?
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
[New Thread 0x7fffe8d75700 (LWP 5500)]
[New Thread 0x7fffe03c2700 (LWP 5503)]
2014-11-01 21:42:01.912923|INFO | | | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
2014-11-01 21:42:01.912975|INFO | | | SystemInformation: Linux 3.17.2-1-ARCH #1 SMP PREEMPT Thu Oct 30 20:49:39 CET 2014 x86_64 Binary: 64bit
2014-11-01 21:42:01.912986|INFO | | | Using hardware aes
[New Thread 0x7ffff7f28700 (LWP 5504)]
[New Thread 0x7fffe8163700 (LWP 5505)]
[New Thread 0x7fffdf5d4700 (LWP 5506)]
[New Thread 0x7fffd8e60700 (LWP 5507)]
[New Thread 0x7fffd865f700 (LWP 5508)]
2014-11-01 21:42:01.960828|DEBUG |PulseAudio | | connected to pulse audio server
[New Thread 0x7fffd7e5e700 (LWP 5509)]
2014-11-01 21:42:02.019447|INFO | | | Loading plugin: libappscanner_plugin
2014-11-01 21:42:02.019499|INFO | | | Loading plugin: libclientquery_plugin
2014-11-01 21:42:02.019514|INFO | | | Loading plugin: liblua_plugin
2014-11-01 21:42:02.019526|INFO | | | Loading plugin: libtest_plugin
[New Thread 0x7fffd58aa700 (LWP 5510)]
[New Thread 0x7fffd57a9700 (LWP 5511)]
[New Thread 0x7fffd56a8700 (LWP 5512)]
[New Thread 0x7fffd5551700 (LWP 5513)]
2014-11-01 21:42:02.160759|INFO | | | *** Time [MAINWINDOW]: 110
2014-11-01 21:42:02.160835|INFO | | | *** Time [INIT]: 110
2014-11-01 21:42:02.162416|INFO |ClientUI | | Failed to init text to speech engine
2014-11-01 21:42:02.162466|INFO |ClientUI | | Qt version: 5.3.2
2014-11-01 21:42:02.162482|INFO |ClientUI | | Using configuration location: /home/adys/.ts3client/settings.db
2014-11-01 21:42:02.661481|INFO |ClientUI | 1| Connect to server: lords-zodiac.com
2014-11-01 21:42:02.663946|INFO |ClientUI | 1| Trying to resolve lords-zodiac.com
[New Thread 0x7fffd4cf9700 (LWP 5514)]
[New Thread 0x7fffcb21b700 (LWP 5515)]
[New Thread 0x7fffcaa1a700 (LWP 5516)]
[New Thread 0x7fffca219700 (LWP 5517)]
2014-11-01 21:42:02.669505|INFO |ClientUI | | Last update check was: lör nov 1 21:40:53 2014
2014-11-01 21:42:02.703915|INFO |TSDNS | | DNS resolve successful, "lords-zodiac.com"=194.242.114.183
[Thread 0x7fffcaa1a700 (LWP 5516) exited]
2014-11-01 21:42:02.922546|INFO |TSDNS | | SRV DNS resolve unsuccessful for "_ts3._udp.lords-zodiac.com"
[Thread 0x7fffcb21b700 (LWP 5515) exited]
2014-11-01 21:42:03.087650|INFO |ClientUI | 1| Lookup finished: 194.242.114.183 9987 lords-zodiac.com 0 0
2014-11-01 21:42:03.088153|INFO |ClientUI | 1| Resolve successful: 194.242.114.183:9987
[Thread 0x7fffca219700 (LWP 5517) exited]
[New Thread 0x7fffca219700 (LWP 5518)]
2014-11-01 21:42:03.088702|INFO |ClientUI | 1| Blacklist check ok
2014-11-01 21:42:03.088724|INFO |ClientUI | 1| Initiating connection: 194.242.114.183:9987 lords-zodiac.com
[New Thread 0x7fffcb21b700 (LWP 5519)]
[Thread 0x7fffca219700 (LWP 5518) exited]
2014-11-01 21:42:03.150903|INFO |PreProSpeex | 1| Speex version: 1.2rc1
warning: The VAD has been replaced by a hack pending a complete rewrite
2014-11-01 21:42:03.151184|DEBUG |PulseAudio | | Opening echo stream alsa_output.usb-Corsair_Vengeance_2100-00-V2100.iec958-stereo
2014-11-01 21:42:03.151813|INFO |ClientUI | 1| Connect status: Connecting
[Thread 0x7fffd4cf9700 (LWP 5514) exited]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffd8e60700 (LWP 5507)]
0x00007ffff4fec158 in __memmove_avx_unaligned () from /usr/lib/libc.so.6
(gdb) bt
#0 0x00007ffff4fec158 in __memmove_avx_unaligned () from /usr/lib/libc.so.6
#1 0x00007fffdeb32da2 in ?? () from /opt/teamspeak3/soundbackends/libpulseaudio_linux_amd64.so
#2 0x00007fffdeb32ebe in ?? () from /opt/teamspeak3/soundbackends/libpulseaudio_linux_amd64.so
#3 0x00007fffde8a15c6 in ?? () from /usr/lib/libpulse.so.0
#4 0x00007fffde6536cb in ?? () from /usr/lib/pulseaudio/libpulsecommon-5.0.so
#5 0x00007fffde6559cb in ?? () from /usr/lib/pulseaudio/libpulsecommon-5.0.so
#6 0x00007fffde655c34 in ?? () from /usr/lib/pulseaudio/libpulsecommon-5.0.so
#7 0x00007fffde65658a in ?? () from /usr/lib/pulseaudio/libpulsecommon-5.0.so
#8 0x00007fffde8b688f in pa_mainloop_dispatch () from /usr/lib/libpulse.so.0
#9 0x00007fffde8b6c9c in pa_mainloop_iterate () from /usr/lib/libpulse.so.0
#10 0x00007fffde8b6d40 in pa_mainloop_run () from /usr/lib/libpulse.so.0
#11 0x00007fffde8c5056 in ?? () from /usr/lib/libpulse.so.0
#12 0x00007fffde665358 in ?? () from /usr/lib/pulseaudio/libpulsecommon-5.0.so
#13 0x00007ffff5574314 in start_thread () from /usr/lib/libpthread.so.0
#14 0x00007ffff4fad3ed in clone () from /usr/lib/libc.so.6
