Dear whoever will help,
Seen a few of these threads but nothing specific to my issue
FACTS:
-I cannot connect to any server
-My clanmates can connect to our clan server
-I can ping the server just fine
-running a tracert on the server address returns final IP just fine
-i cannot connect to voice.teamspeak.com either
here is my client log
07/11/2014 00:50:51 Info TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
07/11/2014 00:50:51 Info SystemInformation: Windows 7 SP1 (7601) x86 Binary: 32bit
07/11/2014 00:50:51 Direct Sound Debug setting timer resolution to 1ms
07/11/2014 00:50:51 Info Loading plugin: appscanner_plugin
07/11/2014 00:50:51 Info Loading plugin: clientquery_plugin
07/11/2014 00:50:51 Info Loading plugin: lua_plugin
07/11/2014 00:50:51 Info Loading plugin: teamspeak_control_plugin
07/11/2014 00:50:51 Info Loading plugin: test_plugin
07/11/2014 00:50:51 Info Loading plugin: ts3g15
07/11/2014 00:50:51 Query Info listening on 127.0.0.1:25639
07/11/2014 00:50:52 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
07/11/2014 00:50:52 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
07/11/2014 00:50:52 Info *** Time [SERVERVIEW]: 119
07/11/2014 00:50:52 Info *** Time [SERVERVIEWMANAGER]: 242
07/11/2014 00:50:52 Input Info Default monitoring enabled
07/11/2014 00:50:52 Info *** Time [MAINWINDOW]: 869
07/11/2014 00:50:52 Info *** Time [INIT]: 870
07/11/2014 00:50:52 ClientUI Info Qt version: 5.2.1
07/11/2014 00:50:52 ClientUI Info Using configuration location: C:\Users\MARK\AppData\Roaming\TS3Client\settings.d b
07/11/2014 00:50:53 ClientUI Info Last update check was: Fri Nov 7 00:20:02 2014
07/11/2014 00:50:56 ClientUI Info Connect to server: ts.britishelites.com
07/11/2014 00:50:56 ClientUI Info Trying to resolve ts.britishelites.com
07/11/2014 00:50:56 TSDNS Info SRV DNS resolve unsuccessful for "_ts3._udp.ts.britishelites.com"
07/11/2014 00:50:56 TSDNS Info No SRV TSDNS found at "_tsdns._tcp.ts.britishelites.com"
07/11/2014 00:50:56 TSDNS Info No SRV TSDNS found at "_tsdns._tcp.britishelites.com"
07/11/2014 00:50:56 TSDNS Info DNS resolve successful, "ts.britishelites.com"=86.8.25.153
07/11/2014 00:51:00 ClientUI Info Lookup finished: 86.8.25.153 9987 ts.britishelites.com 0 0
07/11/2014 00:51:00 ClientUI Info Resolve successful: 86.8.25.153:9987
07/11/2014 00:51:00 ClientUI Info Blacklist check ok
07/11/2014 00:51:00 ClientUI Info Initiating connection: 86.8.25.153:9987 ts.britishelites.com
07/11/2014 00:51:00 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
07/11/2014 00:51:00 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
07/11/2014 00:51:00 Windows Audio Session Debug WAS:penDevice-enter
07/11/2014 00:51:00 Windows Audio Session Debug WAS Buffer size: 3840
07/11/2014 00:51:00 Windows Audio Session Debug WAS:penDevice-leave
07/11/2014 00:51:00 Windows Audio Session Debug WAS::startDevice-enter
07/11/2014 00:51:00 Windows Audio Session Debug WAS::startDevice-leave
07/11/2014 00:51:00 Windows Audio Session Debug WAS Buffer size: 960
07/11/2014 00:51:00 PreProSpeex Info Speex version: speex-1.2beta3
07/11/2014 00:51:00 Windows Audio Session Debug WAS::associateAECDevice-enter
07/11/2014 00:51:00 Windows Audio Session Debug WAS::associateAECDevice-leave
07/11/2014 00:51:00 ClientUI Info Connect status: Connecting
07/11/2014 00:51:05 ClientUI Info Connect status: Disconnected
here is my ping test
http://gyazo.com/b75d9ad4925e996624977997092e5cfa
and here is my tracert
http://gyazo.com/8607f8d1644ae74210a6659efedabe0f
Any suggestions will be met with gratitude
I have tried uninstalling and reinstalling the software, running malware checks, running CCleaner, turning it off and on again >.<
-*UPDATE*-
Have tried running without firewalls and cleaning out my registry files, still nothing
