Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    November 2014
    Ciudad Real, Spain
    41
    Uhm is there no id parameter to register notifies? I was checking the manual at http://media.teamspeak.com/ts3_liter...y%20Manual.pdf and it says the syntax is "servernotifyregister event={server|channel|textserver|textchannel|textp rivate}[id={channelID}]". I did assumed that I could change the order of the parameters since they are Keys from a Dict. I hope that's not what's causing my bug.
    What type of events end? Channel or textchannel? Did you try it with event=channel id=0?
    Textchannel. Didn't tried it before but I will try now with PuTTY (to be safe). OK, tried, still bugs out. The order doesn't matter at all.
    I always used: servernotifyregister id=9931 event=textchannel
    Now I used: servernotifyregister event=textchannel
    Even if ID is not specified, both ways seems to stop working after 60-70 seconds since last text on the channel.
    Please post a screenshot of wireshark that shows the end of the list with the last item selected after "following TCP stream" when notifications are no longer sent.
    Not sure I understood this, I did select the last item in the list, but did you want to see any of the paramaters that appear below? (Frame, Ethernet, Internet Protocol...) Anyway screenshot taken: http://i.imgur.com/kMcxIWZ.png
    To make sure it's not because of permissions, have the bot log in using the account named serveradmin.
    Can't do that myself. However I will ask to the owner to run that and try whenever i see him online.
    EDIT: More tests with PuTTY revealed that if i type servernotifyunregister after it stops sending notifications to me, it suddenly send together all the notifications that weren't send before, then it stops because it's unsubscribed. O,o This is getting weird...
    There's something wrong there for sure. Those notifications are "waiting" for something and trigger after unsubscribing.
    EDIT 2: Is not my machine, the owner of that TeamSpeak server also tried the same commands with PuTTY and the notifications also stop for him (no python or code involved, just him with PuTTY). So it's either a Teamspeak bug or just that server bug.
  2. #17
    4,368
    There are commands that require a certain key order to work (e.g. clientkick, whose own example in the documentation doesn't even work because of that). I don't think servernotifyregister requires a certain order. The id parameter is for channels. By the way, sendtexttextmessage also doesn't have a target parameter if in targetmode=2 or 3.
    I tried to do exactly what you did with a normal Serveradmin account and was not able to reproduce stuff.
  3. #18
    November 2014
    Ciudad Real, Spain
    41
    Could it be a bug of an specific server? I'm only trying with "37.187.39.202" server (which is an spanish MMO community teamspeak). Or maybe a bug of an specific build or version?
    And anyway, as I said before I don't have a serveradmin account. So all the test are used with limited permissions.
    It still makes me wonder what happened upthere in my previous post, where the notifies are send after the unregister event (edit number 1)
  4. #19
    2,360
    Unfortunately I can't reproduce this with my test query account (normal server admin group id 6) on my test TS3 server version 3.0.11. I waited 4 minutes without doing anything, but channel events will be displayed in Putty without problems.
  5. #20
    November 2014
    Ciudad Real, Spain
    41
    I feel embarrased now. numma_cway joined my teamspeak channel and we did several tests until figure out what happens. It's actually the NAT of my router, it seems to close the Port on 60 seconds if there's no data received. At least I guess this thread can help others that face the same problem. It also explains why none of you could reproduce it.
  6. #21
    18,513
    The whole conversation was moved out of the old Bug report. It has nothing to do with this bug.
    But I'm (we are) glad, that you have solved it.
  1. [Evaluation] Query stops working
    By numma_cway in forum Bug Reports [EN/DE]
    Last Post: September 9th, 2014, 08:15 AM
  2. Replies: 0
    Last Post: January 22nd, 2012, 11:19 AM
  3. TS3_RC1 server stops after a few seconds
    By {PST}Nerd in forum Server Support
    Last Post: June 7th, 2011, 04:01 PM
