Page 1 of 2 12 LastLast
Results 1 to 15 of 24
    December 2011
    Can't create / edit Channel without password
    I can't create a channel without a password
    Catalunya
    2,350
    Uncheck this permission, in your server group: b_channel_create_modify_with_force_password
    Secret Base in Arctic Region
    1,671
    If its not your server, you have to talk with the server admin about this.
    Otherwise do as Jordi said.
    Can't seem to create a channel, TS3 is forcing a password
    So, when I try to make a Channel, TS3 froces me to make a password. Is there something I need to do in the permissions for server admin?
    NOTE: I am not very technical about TS3, please try to use clear instructions.
    regards,
    linksword01
    December 2014
    Canīt create Channel without password
    I recently have tried to create a channel but it says that a password is needed. I donīt understand why because I looked through my permissions and b_channel_create_modify_with_force_password is not set. I tried it with Admin Server Query too but it doesnīt work. I hope you guys can help me.
    Greets f70r1an
    August 2013
    530
    Please right click on yourself, click on Permissions, Permission Overview. Type b_channel_create_modify_with_force_password into the filter and verify that you don't have the permission activated anywhere. If this does not work, try to enable the permission but uncheck it and enable the Skip checkbox for it.
    December 2014
    Quote Originally Posted by Matthias B View Post
    Thanks the skip flag made it work not thought of this *derp*
    February 2015
    Password box turns red when I try to create/edit the channel
    Hello everybody, when I recentrly edited some permissions in my server, something happened: When I try to remove a password and erase it from the channel, the password box turns red and it doesn't let me edit nothing. The same thing happens when I try to create a channel without a password. It seems like the server requires a password: how can i change that permission?
    April 2008
    USA
    29
    Unable to create Channel/Sub-Channel without a PW
    Hi All,
    I am unable to create or modify a channel or sub-channel to be without a PW. I was able to do this until recently. Now I receive a popup saying I am forced to enter a PW.
    Any Ideas why or how to bypass this?
    -NJ
    April 2011
    1,266
    Why didn't you try the MIGHTY SEARCH function?
    http://forum.teamspeak.com/showthrea...ssword+channel
    April 2008
    USA
    29
    I did and did not find that Thread - It helped - Thanks!
    October 2013
    12
    Can't delete the channel password
    hi so how the tittle says I can't delete or create a channel without a password anymore, every time I try I get this error
    http://i.imgur.com/uYnKFe9.png
    can someone help me out? thanks
    November 2012
    33
    Creating a new channel
    When I try to create a new or sub channel it says I am required to put in a password. I do not want it to be pass worded. I have multiple channels with different permission settings and everything has been fine until now.
    If I need to provide any more info let me know.
    Thanks for the help,
    Tink
    November 2012
    33
    I checked and unchecked everything. I still cant create a channel without a password. What's next?
    July 2011
    29
    Same thing here.
    Server not mine, but I'm an admin. Tried everything. I have a few servers and it's the first time when I see this.
  1. Password for Server, how to create open channel?
    By jsh0602 in forum Permission System
    Last Post: May 3rd, 2014, 01:25 PM
  2. Create a channel that Admins cannot join / edit
    By -Panda in forum Permission System
    Last Post: January 26th, 2014, 11:51 PM
  3. create/edit channel
    By amojica in forum Suggestions and Feedback
    Last Post: January 14th, 2011, 10:42 AM
  4. [solved] How can I create a channel with password?
    By endri0 in forum General Questions
    Last Post: September 24th, 2010, 09:19 AM
