I want to setup a SRV record that points to my TeamSpeak 3 server running on an Ubuntu 14.04 server.
I have searched for several hours with no luck. There are plenty of guides saying different thing and telling each other are wrong.
I want the final result to be ts.mydomain.com that lets me connect to my Teamspeak server. I used to have a A record just pointing to my server IP, but due to DDoS attacks, I am forced to move over to SRV.
As of now I have this in my DNS control panel:
_ts3._tcp.ts.mydomain.com 1 hour SRV 0 5 10011
_ts3._udp.ts.mydomain.com 1 hour SRV 0 5 9987
These are pointed towards a domain that again points to my IP setup by a provider after the resent DDoS attacks. I can connect to the TS3 server by using the domain setup by the provider, so I guess the ports I have added into the DNS control panel are wrong. I am unable to find the wanted ports as several guides giving different ports.
The install is a fresh install from the TeamSpeak 3 website. No system files has been changed.
What ports do I add as tcp and udp?
Thanks in advance!
EDIT: I changed the ports as shown above and it worked!![]()
