Results 1 to 12 of 12
    June 2014
    10
    Teamspeak 3 does not work outside lan with 2 NIC's enabled
    I have an issue to where Teamspeak will not connect a user outside of my LAN when I have 2 active Network Cards running Windows 7 Professional. If I disable to network card teamspeak works great, if I enable it, no one outside of my internal network can connect.
    I am running Teamspeak vers 3.0.11.2 on Windows (7 Pro)
    Thanks in advance for any assistance on this issue, When running on Windows Server 2008 with 2 NICS it works great.
    UK
    768
    Post the output of ipconfig /all
    June 2014
    10
    ipconfig/all with 1 NIC active (Outside WAN Connection)
    Windows IP Configuration
       Host Name . . . . . . . . . . . . : insurgency
       Primary Dns Suffix  . . . . . . . :
       Node Type . . . . . . . . . . . . : Hybrid
       IP Routing Enabled. . . . . . . . : No
       WINS Proxy Enabled. . . . . . . . : No
    Ethernet adapter Outside:
       Connection-specific DNS Suffix  . :
       Description . . . . . . . . . . . : Realtek PCI GBE Family Controller
       Physical Address. . . . . . . . . : C8-60-00-12-CD-F3
       DHCP Enabled. . . . . . . . . . . : No
       Autoconfiguration Enabled . . . . : Yes
       IPv4 Address. . . . . . . . . . . : 173.12.236.117(Preferred)
       Subnet Mask . . . . . . . . . . . : 255.255.255.248
       Default Gateway . . . . . . . . . : 173.12.236.118
       DNS Servers . . . . . . . . . . . : 173.12.236.113
                                           75.75.75.75
       NetBIOS over Tcpip. . . . . . . . : Enabled
    Tunnel adapter isatap.{37156CDE-2688-4989-B628-0164C1CE97D4}:
       Media State . . . . . . . . . . . : Media disconnected
       Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
       Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
    Tunnel adapter Local Area Connection* 11:
       Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
       IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:3414:2b90:52f3:138a(Preferred)
       Link-local IPv6 Address . . . . . : fe80::3414:2b90:52f3:138a%15(Preferred)
       NetBIOS over Tcpip. . . . . . . . : Disabled
    Tunnel adapter 6TO4 Adapter:
       Description . . . . . . . . . . . : Microsoft 6to4 Adapter
       IPv6 Address. . . . . . . . . . . : 2002:ad0c:ec75::ad0c:ec75(Preferred)
       Default Gateway . . . . . . . . . : 2002:c058:6301::
                                           2002:c058:6301::c058:6301
                                           75.75.75.75
    ipconfig/all with Both NICs active (Outside WAN Connection)
       DNS Suffix Search List. . . . . . : roavanet
    Ethernet adapter Inside:
       Connection-specific DNS Suffix  . : roavanet
       Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
       Physical Address. . . . . . . . . : 04-8D-38-40-DE-7F
       DHCP Enabled. . . . . . . . . . . : Yes
       IPv4 Address. . . . . . . . . . . : 192.168.1.118(Preferred)
       Subnet Mask . . . . . . . . . . . : 255.255.255.0
       Lease Obtained. . . . . . . . . . : Sunday, February 08, 2015 6:27:16 PM
       Lease Expires . . . . . . . . . . : Saturday, February 14, 2015 6:27:16 PM
       Default Gateway . . . . . . . . . : 192.168.1.1
       DHCP Server . . . . . . . . . . . : 192.168.1.99
       DNS Servers . . . . . . . . . . . : 75.75.75.75
                                           192.168.1.99
                                           192.168.1.109
                                           75.75.75.75
    Tunnel adapter isatap.roavanet:
       IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:ced:e2b:3f57:fe89(Preferred)
       Link-local IPv6 Address . . . . . : fe80::ced:e2b:3f57:fe89%15(Preferred)
                                           75.75.75.75
    December 2004
    RF
    3,004
    [ code ] block pretty please.
    Check your firewall and routing. I don't see any other reasons.
    Also, make sure you didn't bind TS to a specific IP.
    June 2014
    10
    I did not do any specific install, Would it help to uninstall and then Reinstall?? I will try that and see if it works. Sorry about the CODE posting.
    Just a question, How would I bind TeamSpeak to a specific IP address.. As for the Firewall it is not running, also it works with the internal lan NIC is disabled, and stops working when it is on. I can connect to it at anytime from inside the lan, but not outside of the lan.
    Also, Uninstalled and Reinstalled no help... It only works with the Inside Lan card disabled.
    April 2011
    1,266
    You have two default gateways configured!!
    173.12.236.118 and 192.168.1.1
    This isn't a recommended setup. The rule of thumb should be one computer, many network adapter, but only one default getway. Hence the name default gateway.
    Even Microsoft warns his customers to configure more then one default gateway because it can result in total network chaos. ==> http://windows.microsoft.com/en-us/w...twork-gateways
    The better solution would be configure one default gateway on the main network adapter, remove on all others and use static routes if you have multiple subnets on any other network.
    With two default gateways you practically tell the computer it can reach any network adress using any of his network adapters, which in most setups with more than one network adapter isn't true (or desired).
    June 2014
    10
    It works perfectly on Windows XP and Server 2008R2, but not on Windows 7... Seems like MS has introduced another bug... Never had this problem before.. Will try it there way,.... UGH... Hate taking a working system and changing it. But it is working now... Why does this work perfectly with Server 2008 and XP, but not 7... Makes no sense....
    UK
    768
    Quote Originally Posted by sparkie951 View Post
    It shouldn't have done, and it certainly isn't a bug. You will have got errors / warnings when trying to set up the second default gateway.
    A default gateway will be used when there is no other defined path to the destination. When you gave the internal adapter it's IP address it would have set up a route for the 192.168.1.0/24 network so a default gateway on the interface isn't necessary
    December 2004
    RF
    3,004
    It doesn't. If you didn't run into any issues, this means, you didn't look close enough.
    June 2014
    10
    It is working now and all is well... We can mark this one as resolved. Hopefully it will help someone else in the future with a similar problem.
    UK
    768
    It would help others if you posted the fix (if it was anything other than having two default gateways)
    June 2014
    10
    Quote Originally Posted by Air SeaTac View Post
    Only thing that fixed it was going to 1 Default Gateway... Nothing else was done.
  1. [Resolved] TeamSpeak Server with Opus Music Enabled
    By patlaw in forum General Questions
    Last Post: February 19th, 2013, 03:58 PM
  2. [Resolved] Battlefield 3 crashes when TeamSpeak 3 overlay is enabled
    By rc3764 in forum Bug Reports [EN/DE]
    Last Post: April 24th, 2012, 09:54 AM
  3. Replies: 3
    Last Post: August 29th, 2011, 01:49 PM
