Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
  1. #31
    18,261
    Quote Originally Posted by ikjadoon View Post
    Is it over? Am I done? Should I just give up and use Overwolf?
    Yes, Yes and Yes or use any other overlay.
    The support and development of the old overlay was dropped.
  2. #32
    September 2013
    Overlay Problems
    Since the 9/15 release of World of Tanks the Overlay feature hasn't worked. Please advise how to correct this. Thank you.
  3. #33
    July 2016
    overlay doesn't work
    I upgraded to the new version and I beleive it was working fine at first but then i fired ts up one day and no overlay in BlackOps. Any ideas? Can I roll back to theprevious version?
    Thx
  4. #34
    December 2015
    If the client created a crashdump (see %Userprofile%\Documents) please upload that file.
    You may also try the latest overlay, which you can get here.
    Your link downloads but puts up an error when i try to install it
  5. #35
    August 2016
    team speak 3 overlay
    Why is it that sometimes when i use overlay in world of tanks it wont kick in and sometimes it works just fine, just wondering if there is a fix for this problem.
  6. #36
    December 2015
    Since Windows 10 Annivesary update today I can't run TS and WWIIOL.
    I had to do the Windows 10 Anniversary update and now when I have TS running, it won't let me launch my WWIIOL game. Acts like it does if you have TS running and try and open Internet Explorer. Game tells me it can't connect and Windows is looking for a solution? I can launch the game without TS fine. Suggestions/help?
    Thanks,
    Lowflyr
    I just had to do the Windows 10 Anniversary update and now if I have TS running and try launching my online game (WWIIOL) it will not open and tells me it can't connect as there is a problem and Windows is looking for a solution. I can launch the game fine without TS running.
    I then tried to go to the TS forums by going from the TS help scroll down menu and it won't open So I next tried having internet explorer running and tried to launch TS and it dumped explorer? For some reason TS and internet won't work simultaneously now. I'm wondering if I need to change a setting in TS or Windows?
    Help/solutions?
    Thanks,
    Lowflyr
    Well I found the problem. Can't use overlays atm. If I shut it off, I can use explorer. Are there options for overlay fix
    Have recent Windows 10 update I can't run TS and explorer at same time without disabling overlays? Suggestions/help?
    Thanks,
    Lowflyr
    Last edited by dante696; September 25th, 2016 at 09:56 AM. Reason: merged 4 Posts. this Plug-in is still unsupported
  7. #37
    18,261
    This plugin is still unsupported. Do not use this outdated thing!
  8. #38
    January 2017
    ts3_overlay not working
    Hi there.
    My ts3_overlay is not working. It states Plugin failed to load: API version not compatible: 20 (current: 21)
    I'm using TS3 x64 V3.1
  1. Replies: 0
    Last Post: August 10th, 2013, 07:09 AM
  2. How to get overlay working?
    By ajappat in forum Client Support
    Last Post: December 28th, 2012, 09:26 AM
  3. [Resolved] Overlay not working
    By Mia_ser in forum General Questions
    Last Post: August 1st, 2012, 12:37 PM
