Results 1 to 11 of 11
    February 2015
    External Connection Not Working
    I have ports 9987, 10011, and 30033 all forwarded through my router. Connecting through 127.0.0.1 works no problem, but my external IP connection isn't working. Nobody is able to connect to the server using my external IP.
    Port Forwarded screenshot: http://gyazo.com/3bff4e25d1d88b65503704d2c2a03f06
    Can anyone help me with this?
    December 2004
    RF
    3,004
    9987 is an UDP port. You can't test it directly, unless you know the protocol.
    February 2015
    Well I'm more concerned about why external connections aren't working.
    December 2004
    RF
    3,004
    You forewarded wrong ports/types.
    Your clients use wrong IP/address.
    You don't have routable IPv4 on your side.
    February 2015
    9987 is forwarded as UDP. The clients are using my external IP address.
    Could I get someone that can explain it further and please help as to how I can get this working? Much appreciated.
    Sorry ANR Daemon, I just hate people who seem like they're gonna be a dbag at the start.
    18,003
    Are you really sure the port is opened for UDP only? The screenshot does not show this.
    Does other software work with external connections?
    Could it be a problem, that you use 10.0.0.5 for internal IP? I know this is also a private IP range but maybe this causes problem here for users somehow.
    Does it work, when you enable DMZ?
    Have you tried another Router or without a router?
    We have a lot of such threads with same problems and we always have the same questions.
    Off-topic about your complian against ANR Daemon
    He just tried to help you with notes, this was ok.
    He could not see if the port is open for UDP, it looks like it is open for both (this can cause errors too).
    You could have searched forum before you post your problem :/
    February 2015
    I'm sorry, I can't realy help this thread ...
    I have the same problem ... the 3 ports are open (My intern IP is 192.168.1.13).
    When I clic on launched program icon, I can't see my IP like everyone say.
    When my friends try to connect my external IP, they can't ...
    Thanks you
    and ... My firt log ....
    2015-02-20 22:14:44.545348|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.11.2 (2014-12-15 14:43:52)
    2015-02-20 22:14:44.545348|INFO |ServerLibPriv | | SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    2015-02-20 22:14:44.546348|INFO |ServerLibPriv | | Using hardware aes
    2015-02-20 22:14:44.559349|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2015-02-20 22:14:44.559349|INFO |DatabaseQuery | | dbPlugin version: 3.8.0.2
    2015-02-20 22:14:44.561349|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2015-02-20 22:14:44.717358|INFO |SQL | | db_CreateTables() tables created
    2015-02-20 22:14:47.500517|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2015-02-20 22:14:50.979716|INFO | | | Puzzle precompute time: 3454
    2015-02-20 22:14:50.983716|INFO |FileManager | | listening on 0.0.0.0:30033
    2015-02-20 22:14:51.029719|INFO |VirtualSvrMgr | | executing monthly interval
    2015-02-20 22:14:51.030719|INFO |VirtualSvrMgr | | reset virtualserver traffic statistics
    2015-02-20 22:14:52.897826|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2015-02-20 22:14:52.899826|INFO |Query | | listening on 0.0.0.0:10011
    December 2004
    RF
    3,004
    That's just a warning. From your log, the server has started fine.
    February 2015
    yes, but ... no one, external to my local network, can join ...
    December 2004
    RF
    3,004
    That's a different question. Please use forum search, we're getting this kind of questions daily, and they've been answerd tens of times, if not hundreds.
    February 2015
    Here's the log from my server.
    2015-02-23 06:24:54.867916|INFO |ServerLibPriv | | TeamSpeak 3 Server 3.0.11.1 (2014-10-15 07:06:31)
    2015-02-23 06:24:54.868916|INFO |ServerLibPriv | | SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 64bit
    2015-02-23 06:24:54.868916|INFO |ServerLibPriv | | Using hardware aes
    2015-02-23 06:24:54.879916|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2015-02-23 06:24:54.879916|INFO |DatabaseQuery | | dbPlugin version: 3.8.0.2
    2015-02-23 06:24:54.879916|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2015-02-23 06:24:54.958921|INFO |SQL | | db_CreateTables() tables created
    2015-02-23 06:24:56.163990|WARNING |Accounting | | Unable to find valid license key, falling back to limited functionality
    2015-02-23 06:24:58.479122|INFO | | | Puzzle precompute time: 2289
    2015-02-23 06:24:58.487123|INFO |FileManager | | listening on 0.0.0.0:30033
    2015-02-23 06:24:58.509124|INFO |VirtualSvrMgr | | executing monthly interval
    2015-02-23 06:24:58.509124|INFO |VirtualSvrMgr | | reset virtualserver traffic statistics
    2015-02-23 06:24:59.379174|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2015-02-23 06:24:59.380174|INFO |Query | | listening on 0.0.0.0:10011
    2015-02-23 06:25:55.575388|ERROR |DatabaseQuery | | db_exec() update clients set client_login_name='serveradmin', client_login_passw error: column client_login_name is not unique
    2015-02-23 06:24:59.292169|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
  1. no connection from external ip
    By daverogers in forum Windows
    Last Post: January 3rd, 2011, 09:37 PM
  2. No Connection with External IP
    By Redstar in forum Windows
    Last Post: December 21st, 2009, 01:34 PM
