Results 1 to 3 of 3
    December 2014
    Chile
    13
    i need script for show icon of servergroup
    Hi, I'm putting together a small script to change ranges via web, and I'm in the part where ready available ranges (based on sort_id) but not how to make it show a picture of the range and tried some codes but give error and no I know how to fix it ...
    PHP Code:
     <?php
            session_start
    $_SESSION['client_uid'] = $_GET['uniid'];
    $client_uid $_SESSION['client_uid'];
        try {
    $connect "serverquery://".$USER_QUERY.":".$PASS_QUERY."@".$HOST_QUERY.":".$PORT_QUERY."/?server_port=".$SERVER_PORT."";
    $ts3_VirtualServer TeamSpeak3::factory($connect);
    $ts3_VirtualServer->execute("clientupdate", array("client_nickname" => 'Manager Group'));
    //$ts3_VirtualServer->message("TEST - Vengo a tomar datos :D");
            //$client = $ts3_VirtualServer->clientGetByUid($client_uid);
    $client $ts3_VirtualServer->clientGetByUid($client_uid);
    //print_r($client);
    $userlist $ts3_VirtualServer->clientList();
    //print_r($userlist);
            //$iconos = $ts3_VirtualServer->iconDownload();
            //print_r($iconos);
    echo "ID obtenida: ".$client_uid."<br>";
            if(
    $client["client_nickname"] ==  'Manager Group') {
                echo
    "Ultimo nombre usado: NO DISPONIBLE<br>";
            } else {
                echo
    "Ultimo nombre usado: ".$client["client_nickname"]."<br>";
            echo
    "Procesando el sistema <br>";
    $listagroups $ts3_VirtualServer->serverGroupList();
                    echo
    "<form name='formulario' method='get' action='guardargrupos.php'>";
            foreach(
    $listagroups as $groups)
    //$icons = $groups->getIcon();
                //print_r($icons);
    if($groups["sortid"] == $SID_GROUP) {
    $miembros $ts3_VirtualServer->serverGroupClientList($groups["sgid"]);
    $estaengrupo False;
                foreach(
    $miembros as $m) {
                    if(
    $m["client_unique_identifier"] == $client_uid) {
    $estaengrupo True;
    //Show Icon for Group listed...
    if (file_exists($cachefile)) {
    $img file_get_contents($cachefile);
                            } else {
    $query = new TSQuery($HOST_QUERY$PORT_QUERY);
                                if (
    $config['login_needed']) {
    $query->login($USER_QUERY$PASS_QUERY);
    $query->use_by_port($SERVER_PORT);
    $img $query->download("/icon_" $m['sid'], 0);
    $query->quit();
    $file fopen($cachefile"wb");
    fwrite($file$img);
    fclose($file);
    //header("Content-Type: image/png");
    echo $img;
                            if(
    $estaengrupo) {
                                echo
    " <input type=checkbox value=".$m["cldbid"]." name='group[]' checked >".$groups["name"]."<br>";
                            } else {
                                echo
    " <input type=checkbox value=".$m["cldbid"]." name='group[]' >".$groups["name"]."<br>";
                     echo
    "<input type=submit name=save value='Guardar'><br></FORM>";
        } catch(
    Exception $e) {
            echo
    "[DEBUG] Ha ocurrido un error inesperado <br>";
            echo
    "[DEBUG] Mensaje de error DEBUG: ".$e->getMessage()."<br>";
            echo
    "[DEBUG] El codigo de error fue ".$e->getCode()."<br>";
            if(
    $e->getCode() == 0) {
                echo
    "Error desconocido. Metodo invalido";
            } else if(
    $e->getCode() == 10060) { //Codigo de error de error en la conexion
    echo "No se pudo conectar con el servidor de teamspeak 3";
            } else if(
    $e->getCode() == 512) { //Codigo de error cuando la UUID no es valida
    echo "La UUID ingresada no es valida o no esta actualmente conectada al ts3";
            } else if(
    $e->getCode() == 520) { //Codigo de error cuando login o pass estan mal
    echo "Los datos de acceso query no son correctos";
            } else if(
    $e->getCode() == 3329) { //Codigo de error cuando la conexion fue baneada por el tsquery
    echo "La conexion fue baneada por query. Intenta mas tarde";
    This is the error... http://prntscr.com/6aln4p
    Not if the method is correct ...
    4,371
    You don't want to post your error, we don't want to post an answer.
    December 2014
    Chile
    13
    The error: http://prntscr.com/6aln4p
    You do not know if I'm doing the method to obtain the image is right also ...
  1. Problem with icon in ServerGroup that no longer exists
    By M4LV4D0 in forum Linux / FreeBSD
    Last Post: June 17th, 2011, 01:04 AM
  2. [Lua Plugin] Enable script to add clients to servergroup/channel group
    By willy_sunny in forum Suggestions and Feedback
    Last Post: April 18th, 2011, 08:55 PM
  3. [bug]Check mark does not show in servergroup menu
    By willy_sunny in forum Bug Reports [EN/DE]
    Last Post: April 19th, 2010, 11:34 AM
  4. [Help] Token add and Show Script
    By Siggi in forum Tools / Web Based
    Last Post: January 15th, 2010, 08:15 PM
