Results 1 to 11 of 11
    June 2013
    29
    How to reset permissions
    How do I reset all channel server permissions back to default and also maybe server groups.
    17,711
    Just login into the ServerQuery and then perform the command permreset. In case you do have access to it.
    Please use the serveradmin account to perform the permreset.
    This happens on the selected virtual server after permreset:
    - Stops the virtual server
    - Removes all permissions from users and channels
    - Deletes all server and channel groups
    - Recreates all default groups from server instance template
    - Creates a privilidge key for the Server Admin group
    - Starts the server
    This will not be touched and stays as it was:
    + Users and their avatar (will only lose permissions as mentoined above)
    + Channels and their settings (except channel permissions and icon setting)
    + Server settings
    + Stored files on server / In channel
    How to use the Query
    http://forum.teamspeak.com/showthrea...e-Server-Query
    Last edited by dante696; January 15th, 2016 at 08:07 AM. Reason: Added more information to merge threads in the future
    June 2013
    29
    I get error id=2568 msg=insufficient\sclient\spermissions failed_permid=47
    [email protected] [~]# sudo telnet localhost 10011
    Trying ::1...
    telnet: connect to address ::1: Connection refused
    Trying 127.0.0.1...
    Connected to localhost.
    Escape character is '^]'.
    TS3
    Welcome to the TeamSpeak 3 ServerQuery interface, type "help" for a list of commands and "help <command>" for information on a specific command.
    login danny xxxxxx
    error id=0 msg=ok
    permreset
    permreset
    use 9987
    error id=1033 msg=server\sis\snot\srunning
    17,711
    Login as serveradmin and not with your generated account.
    Info added to my main post.
    June 2013
    29
    Ok, so the answer to my question is:
    Login to your server via SSH
    login serveradmin yourserverpassword (as set when you do './ts3server_startscript.sh start serveradmin_password=yourpasswordhere')
    serverlist
    use port=9987
    then finally do the command
    permreset
    June 2015
    Reset Permissions / New Privilege Key
    So I have had an issue with my permissions on my server. I am unable to change the sort id of my server groups. I was advised by my provider to do a reset of permissions and then get a new privilege key. If I do this, will this remove anything from my server like current rooms, server groups, etc? Will I have to start from scratch? Or will everything be in its place, and just have to mess with permissions?
    Thanks!!!
    Edit: I also have access to the Server Query from the host website. Would anyone know the command I would need to input to re-add the permission i_needed_modify_power_group_sort_id
    4,319
    Settings, channels, files and icons (but not their assignments) will be kept. Everything related to permissions will be gone.
    April 2011
    Permission reset
    Is there a way to reset all permissions on a server to a default ?
    17,711
    You need to login into the ServerQuery and then use the command permreset.
    Read post #2 to get more details.
    February 2016
    Croatia
    7
    Reseting server to default groups but keep the channels
    So as tittle says I wanna reset my server to default server groups and settings but leaving my channels as they are if its possible, thanks in advance
    July 2015
    Teamspeak 3 server permissions
    So my teamspeak server is around a year and a half old, and as such, many people have come and gone, and many permissions have been edited.
    I logged on to see that my friend had messed with permissions a bit.. and things are really fucked up.
    I host the teamspeak server myself on a laptop right above me, so accessing it is no issue.
    But there used to be a way to access the server through a connection with windows and with the logon, you had full permissions to the server and could add and remove permissions as needed.
    Remind me, how do I access that? And if anyone had a guide on adding permissions, that would be nice.
    Last edited by dante696; December 30th, 2016 at 10:01 PM. Reason: merged, see post 2
  1. Permissions Reset after TS3 Reboot
    By djentire in forum Permission System
    Last Post: December 22nd, 2013, 06:29 PM
  2. Reset Permissions TS3.
    By ROkii in forum Permission System
    Last Post: October 2nd, 2012, 08:56 AM
  3. Guest permissions reset
    By neverdark in forum Permission System
    Last Post: November 19th, 2011, 07:59 PM
  4. Reset Channel Permissions?
    By Omlet in forum Permission System
    Last Post: January 14th, 2010, 06:48 AM
  5. Suggestion: Permissions Reset
    By falc97 in forum Permission System
    Last Post: December 29th, 2009, 09:21 PM
