Results 1 to 13 of 13
    December 2014
    Chile
    13
    [Release][MultiLang] TS3ManagerGroup Basic - System management ranks by sort_id
    Hi, today I bring you a small contribution was a project I put together for a community using TS3.
    In that TS3 is a series of "ranges" are merely decorative and to automate these ranges give way to design this little script which asks your UID ts3 and gives you a list of available ranges (configurable from / data /config.php) so you can select the ones you want (with a limit of ranges to be assigned which is configurable)
    NOW WHITH LANGUAGES ;3 (Spanish, English, Polish)
    Images
    Use:
    -First you must modify the configuration file located in (./data/config.php)
    -For the icons of the groups to be used you should be run after editing the configuration file next file (./iconos/geticonos.php)
    *To avoid saturating the connection to ts3 icons are stored locally on the webhost so you should periodically run (or edit an icon depending on whether a group) geticonos.php file to save changes to the webhost.
    Download
    The files are located in https://github.com/Doc94/TS3IconManager
    It is a simple post and that in itself is simple ... the script uses Bootstrap and TS3 PHP Framework
    I hope you like it and find it useful to you, any comments are welcome: 3
    More info in GitHub repository
    June 2014
    It can add an extra option. You have to give even your IP . People will have fun taking and adding others rank // Sry me english so bad
    December 2014
    Chile
    13
    Quote Originally Posted by Anoni View Post
    i add an system of confirmation via code send by POKE to clientUID.
    Upgrade in GITHUB :3
    March 2010
    Finland
    This is amazing . I really like the idea of having decorative icons but the problem has been limiting how many you can have. This solves it perfectly!
    I suggest you translate it to English
    May 2014
    10
    Contact me please.
    December 2013
    10
    can anyone give me a quick setup to how run it ?
    December 2014
    Chile
    13
    Quote Originally Posted by Wre1M View Post
    This was a project of boredom ... and he would not publish it ..
    Most likely I put options available to language, 3
    December 2014
    Chile
    13
    That's because you need a permit to run the command checks the github project page there ready the necessary permits if so issues still fails contact me via the same web.
    What to add more groups this is based on the group sort_id so if you want other groups listes you must assign the sort_id in which you list ...
    December 2014
    Chile
    13
    Quote Originally Posted by Deror View Post
    i can add check ip in the project right ? because anyone can get my [ UUID ] and he will spam to me ? how i can slove this problem ?
    I am aware of that malfunction, but I want to avoid at all costs the use of a database to compare ...
    Until then and I could not prevent abuse of check uid.
    When you achieve something throw the appropriate update.
    June 2015
    December 2014
    Chile
    13
    Upgrade
    New version 1.4 release.
    New Langs and Support Multi SORTID Group ;3
    More in https://github.com/Doc94/TS3IconManager/releases
    August 2015
    Hi ..
    I've used your (TS3maneger) since 3 weeks ago and i want you to help me with something ..
    I want to link (TeamSpeakuser--with--website bot ) immediately without verification i mean link with ip no need for verification Code . Thank
    August 2015
    Hi..
  1. RC Icon Pack (Grades (From 1 To 55) & Normal Ranks & Admin Ranks)
    By Shaniya in forum Skins / Icon & Sound Packs
    Last Post: November 6th, 2015, 03:27 PM
  2. Ranks Editing other ranks issue
    By Pandaz in forum Server Support
    Last Post: January 26th, 2014, 07:45 AM
  3. [RELEASE] Tactical Aviation Radio System (TARS)
    By Headspace in forum Client Plugins / Lua Scripts
    Last Post: May 2nd, 2013, 03:34 PM
