Results 1 to 5 of 5
    December 2013
    10
    Modify Channel Name ignores Modify Power?
    hey,
    I have set the Channel Modify Power to 50 and enabled Modify Channel Name for a group. All channels have 75 Needed Channel Modify Power as default.
    With this setup the user with in the group can edit all Channel Names.
    Is this a bug? Does the Modify Channel Name ignore the Modify Power or did I something wrong?
    18,513
    Works fine here.
    <22:02:18> insufficient client permissions (failed on i_channel_modify_power)
    Open your permisions overview and then compare your real i_channel_modify_power.
    December 2013
    10
    Server Group:
    Channel Perms:
    Edit: I have to use i_channel_modify_power? If yes, can I set a global default value for this?
    18,513
    This is not the permission overview.
    Right-click the user/or yourself and then choose permissions -> permission overview.
    Then enter the permission into the filter.
    The bottom will show you the end value (combined of groups , skipped permissions etc)
    Make sure your group does not skip channel permisions. In that case all permissions from a channel will be skipped.
    We did explain this in forum mayn times before.
    December 2013
    10
    I have already found the issue. I have used i_channel_permission_modify_power which is the wrong permission for the channel edit. Unfortunately is i_channel_modify_power not set for all channels as default so I can't allow the specific group to edit channels only in a specific area.
  1. Replies: 0
    Last Post: June 3rd, 2015, 03:05 AM
  2. Channel modify power not working.
    By ZealotZ in forum Permission System
    Last Post: October 15th, 2014, 12:12 PM
  3. Channel modify power
    By CreepYx in forum Permission System
    Last Post: July 19th, 2014, 11:20 AM
  4. [Resolved] permission modify power of a new sub-channel
    By Barungar in forum Permission System
    Last Post: October 19th, 2013, 09:47 AM
  5. Replies: 3
    Last Post: July 15th, 2012, 02:18 PM
