Page 5 of 5 FirstFirst ... 345
Results 61 to 74 of 74
  1. #61
    August 2014
    11
    Setup guide
    Hello,Can you make a simple setup guide for linux.Thaks!
  2. #62
    June 2014
    17
    This seems to cause apache to randomly crash :/
  3. #63
    December 2011
    14
    it is simple give me some time and i will make one for you and what distro are you useing
  4. #64
    December 2011
    14
    here you go
    If you have Winscp installed
    connect to server as root
    go to the folder teamspeak is located ** i hope your not useing root for your username to run teamspeak **
    make a new folder name it ts3video
    * unzip the folder to a folder on your desktop *
    drop all files into the folder on your server
    edit default.ini with and add a admin password so you can kick/ban people from video
    open putty connect to user
    cd to user folder for teamspeak / ts3 video
    cd ts3video
    sudo screen ./start.sh start
    if not root
    or screen ./start.sh start
  5. #65
    February 2010
    Hollandia
    57
    Can you please help me with a strange problem i have with this plugin.
    Everything works from the start. but when somebody joins the channel i get an error "videoclient.exe has stopped working" A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "Close Program"
    Can you please help me fix this problem?
  6. #66
    February 2010
    Hollandia
    57
    If i join an empty room everything works perfect.
    But when i join a channel where people are already in or they join my channel i get this error.
    please help
  7. #67
    December 2011
    USA
    55
    TS3 Video on mtg
    We worked with Manuel together on the last version. We got it running non-stop on our Public Server. Come check it out. ts3.mtg-esport.de
  8. #68
    May 2012
    32
    Version 0.5
    I've released a new version 0.5. You might try your luck with this one.
    It also comes with support for a public server, which makes it possible to use it, without the need to setup your own server.
  9. #69
    March 2008
    United States
    83
    On version 0.5 I am unable to see anyone on the computer that is used for hosting. I have tried both join now, and join via public server on both the host computer, and others, and no matter what combination is used, the host computer can not see others.
    On 0.4 I was able to choose a channel/channel password and connect to see others just fine.
  10. #70
    February 2011
    Bandung, Indonesia
    99
    Thumbs up my client asked for this plugin
    my client asked to install this plugin and i agreed..the feature so far is good(my client said so.i didnt have any webcam).
    but on the network side, its a bit heavy. if possible, some feature to adjust the quality and bw limit.
    thanks~
  11. #71
    March 2016
    Some users cannot connect
    Hi there,
    Altough the plugin works perfect for some of our users , some others cannot connect.
    Especialy those who use standard windows drivers or make use of an internal onboard video card it seems?
    Is there a solution so any of my users cam use the plugin?
    Sjoerd,
    adverts removed
  12. #72
    October 2011
    Not sure if the developer is still active, but im having some problems.
    Here is the situation. I run a TS server and the ts3video from my always ON HTPC/NAS. My modem is handling my No-IP resolve.
    Friends connect to my server from my NO-IP name. And i connect to my HTPC IP witch is 192.168.25.124
    Other users can see each other but they cant see me or i them.
    Im having the problem that another user had but that workaround does not work anymore.
    Any advices?
  13. #73
    August 2013
    540
    Any chance this gets updated to API21, manuel?
  14. #74
    May 2012
    32
    New Release 0.14 for Teamspeak Client Plugin API 23 available:
    https://mfreiholz.de/ts3video/downloads/
  1. Release ??
    By Scania in forum Client Support
    Last Post: January 20th, 2010, 06:57 PM
