Results 1 to 4 of 4
    April 2015
    Can not change Channel Join Power for Server groups
    Hello, I apologize if this is quite a 'noob' question. However with the current Server Groups interface I see (I am a server admin with permissions to create groups etc though I am not the owner) The interface has changed since I created these groups a few months ago. And I am trying to figure out how to change the the channel join power for some of the groups, as we have specific channels we need to set at say Join power 51 and the groups are based off of the Normal server group so they are set at 50 and I can not change them.
    any help is appreciated.
    Thanks
    SirWence
    18,513
    Sorry but your report is just a lack of details.
    - Set Grant of 75 (for i_channel_join_power)in your own server group.
    - Please paste a permission overview.
    April 2015
    This will be a tich long so I apologize but here is my Server permission overview. Also this Panel is honestly whats causing my confusion in how to change values on server groups - http://imgur.com/lMUfUBa
    All
    		ServerQuery: Login via ServerQuery 1 0 0
    		ServerQuery: Select Virtual Server 1 0 0
    		ServerQuery: View Virtual Server Info 1 0 0 75
    		View Virtual Server Connection Info 1 0 0 75
    		ServerQuery: View List of existing Channels 1 0 0 75
    		ServerQuery: Search for Channels 1 0 0 75
    		ServerQuery: View List of Clients online 1 0 0 75
    		ServerQuery: Search for Clients online 1 0 0 75
    		View List of known Client Identities from Database 1 0 0 75
    		Search for known Client Identities in Database 1 0 0 75
    		ServerQuery: View Client Database Information 1 0 0 75
    		ServerQuery: Search for Permission Assignments 1 0 0 75
    		ServerQuery: Search for Custom Client Properties 1 0 0 75
    		ServerQuery: Start this Virtual Server    100
    		ServerQuery: Stop this Virtual Server    100
    		View List of available Privilege Keys 1 0 0 75
    		Create new Privilege Key 1 0 0 75
    		Use Privilege Keys to gain permissions 1 0 0 75
    		Delete Privilege Key 1 0 0 75
    		ServerQuery: View Virtual Server Logs 1 0 0 75
    		ServerQuery: Write to Virtual Server Log 1 0 0 100
    		Ignore Virtual Server Password 1 0 0 75
    		ServerQuery: Register for Event Notifications 1 0 0 75
    		ServerQuery: Unregister from Event Notifications 1 0 0 75
    		Modify Virtual Server Name 1 0 0 75
    		Modify Virtual Server Welcome Message 1 0 0 75
    		Modify Virtual Server Max Clients    100
    		Modify Virtual Server Reserved Slots 1 0 0 75
    		Modify Virtual Server Password 1 0 0 75
    		Modify Virtual Server Default Server Group 1 0 0 75
    		Modify Virtual Server Default Channel Group 1 0 0 75
    		Modify Virtual Server Channel Admin Group 1 0 0 75
    		Modify Virtual Server Force Silence Limit 1 0 0 75
    		Modify Virtual Server Complaint Settings 1 0 0 75
    		Modify Virtual Server Anti-Flood Settings    100
    		Modify Virtual Server File-Transfer Settings    100
    		Modify Virtual Server File-Transfer Quotas    100
    		Modify Virtual Server Host Message 1 0 0 100
    		Modify Virtual Server Host Banner 1 0 0 75
    		Modify Virtual Server Host Button 1 0 0 100
    		Modify Virtual Server Port    100
    		Modify Virtual Server Autostart Behaviour    100
    		Modify Virtual Server Security Level    100
    		Modify Virtual Server Priority Speaker Dimm Modificator 1 0 0 75
    		Modify Virtual Server Log Settings    100
    		Modify Virtual Server Min Client Version    100
    		Modify Virtual Server Icon ID 1 0 0 75
    		Modify Virtual Server Announcement on Weblist 1 0 0 75
    		Modify Virtual Server Voice Encryption 1 0 0 75
    		Manage temporary server passwords 1 0 0 75
    		Manage own temporary server passwords 1 0 0 75
    		Edit default of temporary channel delete delay 1 0 0 75
    		Channel Min Depth    75
    		Channel Max Depth 10 0 0 75
    		Stop Channel Group Inheritance    75
    		Channel Permission Modify Power 75 0 0 75
    		Needed Channel Permission Modify Power    75
    		ServerQuery: View Channel Info 1 0 0 75
    		Create Sub-Channels 1 0 0 75
    		Create Permanent Channels 1 0 0 75
    		Create Semi-Permanent Channels 1 0 0 75
    		Create Temporary Channels 1 0 0 75
    		Create Private Channels 1 0 0 75
    		Create Channels with Topic 1 0 0 75
    		Create Channels with Description 1 0 0 75
    		Create Channels with Password 1 0 0 75
    		Create Channels with Speex Narrowband Codec 1 0 0 75
    		Create Channels with Speex Wideband Codec 1 0 0 75
    		Create Channels with Speex Ultra-Wideband Codec 1 0 0 75
    		Create Channels with CELT Mono Codec 1 0 0 75
    		Create Channels with Opus Voice Codec 1 0 0 75
    		Create Channels with Opus Music Codec 1 0 0 75
    		Create Channels with Max Codec Quality 10 0 0 75
    		Create Channel with Minimum Latency Factor 1 0 0 75
    		Create Channels with Max Clients 1 0 0 75
    		Create Channels with Max Family Clients 1 0 0 75
    		Create Channels with Sort Order 1 0 0 75
    		Create Default Channel 1 0 0 75
    		Create Channels with Needed Talk Power 1 0 0 75
    		Create Channels with Password only    75
    		Temporary channel delete delay 86400 0 0 75
    		Move Channels 1 0 0 75
    		Change Channel Type to Default 1 0 0 75
    		Change Channel Type to Permanent 1 0 0 75
    		Change Channel Type to Semi-Permanent 1 0 0 75
    		Change Channel Type to Temporary 1 0 0 75
    		Modify Channel Name 1 0 0 75
    		Modify Channel Topic 1 0 0 75
    		Modify Channel Description 1 0 0 75
    		Modify Channel Password 1 0 0 75
    		Modify Channel Codec 1 0 0 75
    		Modify Channel Codec Quality 1 0 0 75
    		Modify Channel Latency Factor 1 0 0 75
    		Modify Channel Max Clients 1 0 0 75
    		Modify Channel Max Family Clients 1 0 0 75
    		Modify Channel Sort Order 1 0 0 75
    		Modify Channel Needed Talk Power 1 0 0 75
    		Channel Modify Power 75 0 0 75
    		Needed Channel Modify Power    75
    		Modify Channel Voice Encryption 1 0 0 75
    		Delete Permanent Channels 1 0 0 75
    		Delete Semi-Permanent Channels 1 0 0 75
    		Delete Temporary Channels 1 0 0 75
    		Force Deletion of Channels 1 0 0 75
    		Channel Delete Power 75 0 0 75
    		Needed Channel Delete Power    75
    		Join Permanent Channels 1 0 0 75
    		Join Semi-Permanent Channels 1 0 0 75
    		Join Temporary Channels 1 0 0 75
    		Ignore Channel Passwords 1 0 0 75
    		Ignore Channel Max Clients 1 0 0 75
    		Channel Join Power 75 0 0 75
    		Needed Channel Join Power    75
    		Channel Subscribe Power 75 0 0 75
    		Needed Channel Subscribe Power    75
    		Channel Description View Power 75 0 0 75
    		Needed Channel Description View Power    75
    		Icon ID 725669885 0 0 75
    		Icon Max Filesize (Bytes) 8192 0 0 75
    		Manage Icons 1 0 0 75
    		Group is Permanent 1 0 0 75
    		Group Auto Update Type 45 0 0 75
    		Group Auto Update Max Value 45 0 0
    		Group Sort ID    75
    		Show Group Name in Tree 1 0 0
    		ServerQuery: View List of Server Groups 1 0 0 75
    		View List of Server Group Permissions 1 0 0 75
    		View List of Server Group Members 1 0 0 75
    		ServerQuery: View List of Channel Groups 1 0 0 75
    		View List of Channel Group Permissions 1 0 0 75
    		View List of Channel Group Members 1 0 0 75
    		View List of Client Permissions 1 0 0 75
    		View List of Channel Permissions 1 0 0 75
    		View List of Channel Client Permissions 1 0 0 75
    		Create new Server Groups 1 0 0 75
    		Create new Channel Groups 1 0 0 75
    		Group Modify Power 75 0 0 75
    		Needed Group Modify Power 75 0 0 75
    		Group Member Add Power 75 0 0 75
    		Needed Group Member Add Power 75 0 0 75
    		Group Member Remove Power 75 0 0 75
    		Needed Group Member Remove Power 75 0 0 75
    		Delete existing Server Group 1 0 0 75
    		Delete existing Channel Group 1 0 0 75
    		Client Permission Modify Power 75 0 0 75
    		Needed Client Permission Modify Power 75 0 0 75
    		Max number of additional connections per Identity 10 0 0 75
    		Max Idle time (Seconds)    75
    		Max Avatar Filesize (Bytes) 200000 0 0 75
    		Max Channel Subscriptions -1 0 0 75
    		Client is Priority Speaker    75
    		Skip Channel Group Permissions 1 0 0 75
    		Force Push To Talk    75
    		Ignore Bans 1 0 0 75
    		Ignore Anti-Flood Measurements 1 0 0 75
    		Issue Client-side ServerQuery Commands 1 0 0 75
    		Use Reserved Slots 1 0 0 75
    		Use Channel Commander 1 0 0 75
    		Request talk power in moderated channels 1 0 0 75
    		Delete other clients avatar 1 0 0 75
    		Sticky client    75
    		Ignore sticky client permission 1 0 0 75
    		ServerQuery: View Client Info 1 0 0 75
    		View Client Permission Overview 1 0 0 75
    		View Own Client Permission Overview 1 0 0 75
    		View Client Remote Address 1 0 0 75
    		ServerQuery Client View Power 75 0 0 75
    		Needed ServerQuery Client View Power 75 0 0 75
    		ServerQuery: View Custom Client Properties 1 0 0 75
    		Client Kick From Server Power 75 0 0 75
    		Needed Client Kick From Server Power 75 0 0 75
    		Client Kick from Channel Power 75 0 0 75
    		Needed Client Kick from Channel Power 75 0 0 75
    		Client Ban From Server Power 75 0 0 75
    		Needed Client Ban Power 75 0 0 75
    		Client Move Power 75 0 0 75
    		Needed Client Move Power 75 0 0 75
    		Client Complain Power 75 0 0 75
    		Needed Client Complain Power 75 0 0 75
    		View List of Client Complaints 1 0 0 75
    		Delete own Complaints 1 0 0 75
    		Delete all Complaints 1 0 0 75
    		View List of Ban Rules 1 0 0 75
    		Create new Ban Rules 1 0 0 75
    		Delete own Ban Rules 1 0 0 75
    		Delete all Ban Rules 1 0 0 75
    		Max Time for Ban Rules in seconds -1 0 0 75
    		Private Textmessage Power 75 0 0 75
    		Needed Private Textmessage Power    75
    		Send Text Messages to Server 1 0 0 75
    		Send Text Messages to Channel 1 0 0 75
    		Send Text Messages to Offline Clients 1 0 0 75
    		Client Talk Power 75 0 0 75
    		Needed Client Talk Power    75
    		Client Poke Power 75 0 0 75
    		Needed Client Poke Power    75
    		Grant Talk Power 1 0 0 75
    		Client Whisper Power    75
    		Needed Client Whisper Power    75
    		Modify all Client Descriptions 1 0 0 75
    		Modify own Client Description 1 0 0 75
    		ServerQuery: Modify Client Settings 1 0 0 75
    		Delete Client Database Properties 1 0 0 75
    		Create a ServerQuery Account 1 0 0 75
    		Browse files without channel password 1 0 0 75
    		ServerQuery: View List of active File-Transfers 1 0 0 75
    		File Upload Power 75 0 0 75
    		Needed File Upload Power    75
    		File Download Power 75 0 0 75
    		Needed File Download Power    75
    		File Delete Power 75 0 0 75
    		Needed File Delete Power    75
    		File Rename Power 75 0 0 75
    		Needed File Rename Power    75
    		File Browse Power 75 0 0 75
    		Needed File Browse Power    75
    		Directory Create Power 75 0 0 75
    		Needed Directory Create Power    75
    		Download Quota per Client (MByte) -1 0 0 75
    		Upload Quota per Client (MByte) 1310720 0 0 75
    Client
    Channel
    	Lobby
    		Needed Channel Permission Modify Power 50
    		Icon ID 700697606
    Channel Groups
    	Guest
    		Group Auto Update Type 10
    Channel Client
    All
    	Group Sort ID    75
    	Sticky client    75
    18,513
    Channel Join Power 75 0 0 75 looks ok
    Check the needed modify power for target group.
    It should be:
    Needed Group Modify Power 75 0 0 x
    This thread shows you how to change permissions manually.
    Advanced-permission-system-is-missing
    --Off-topic--
    There is something in your overview i'd like to comment.
    You do have Query permissions assigned. This is not good.
  1. Replies: 3
    Last Post: May 7th, 2015, 08:50 AM
  2. Join groups of power adjust
    By RavLau in forum Windows
    Last Post: September 16th, 2012, 01:57 AM
  3. Setting join power in sub-groups
    By jknorr in forum Permission System
    Last Post: November 5th, 2011, 07:00 PM
  4. [Resolved] Listening Power + group server channel join power
    By dartzdevil in forum Suggestions and Feedback
    Last Post: August 5th, 2011, 12:09 PM
  5. Replies: 6
    Last Post: June 7th, 2010, 03:17 PM
