Results 1 to 7 of 7
    April 2015
    Teamspeak3 Client not connecting on Debian
    Hello Guys,
    my TS3Client on my Debian is not connecting to the TS3 server. Here is the full log:
     INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=Musikbot%20von%20ChaoZz&password=&channel=&channelpassword=
    2015-04-27 13:13:18.687860|INFO    |              |   | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
    2015-04-27 13:13:18.688003|INFO    |              |   | SystemInformation: Linux 3.14.32-xxxx-grs-ipv6-64 #1 SMP Sat Feb 7 11:35:27 CET 2015 x86_64 Binary: 64bit
    2015-04-27 13:13:18.688056|INFO    |              |   | Using hardware aes
    2015-04-27 13:13:18.702402|DEBUG   |PulseAudio    |   | connected to pulse audio server
    2015-04-27 13:13:18.725608|INFO    |              |   | Loading plugin: libappscanner_plugin
    2015-04-27 13:13:18.725672|INFO    |              |   | Loading plugin: libclientquery_plugin
    2015-04-27 13:13:18.725712|INFO    |              |   | Loading plugin: liblua_plugin
    2015-04-27 13:13:18.725745|INFO    |              |   | Loading plugin: libsoundbot_plugin
    2015-04-27 13:13:18.725779|INFO    |              |   | Loading plugin: libtest_plugin
    2015-04-27 13:13:18.727384|INFO    |Query         |   | listening on 127.0.0.1:25639
    ClientQueryPlugin: currentServerConnectionChanged 1 (0)
    2015-04-27 13:13:18.969745|INFO    |              |   | *** Time [MAINWINDOW]: 110
    2015-04-27 13:13:18.969896|INFO    |              |   | *** Time [INIT]: 110
    2015-04-27 13:13:18.973598|INFO    |ClientUI      |   | Failed to init text to speech engine
    2015-04-27 13:13:18.973696|INFO    |ClientUI      |   | Qt version: 5.2.1
    2015-04-27 13:13:18.973741|INFO    |ClientUI      |   | Using configuration location: /home/Teamspeak3-MBot/data/ts3/40a31cea-8db6-467e-a40a-ee4a80f66082/dc35916f-8156-441b-8d41-3b07a40a5070/settings.db
    2015-04-27 13:13:19.270123|INFO    |ClientUI      |   | ts3server: 127.0.0.1?port=9987&nickname=Musikbot%20von%20ChaoZz&password=&channel=&channelpassword=
    2015-04-27 13:13:19.270788|INFO    |ClientUI      |  1| Connect to server: 127.0.0.1
    2015-04-27 13:13:19.271755|INFO    |ClientUI      |  1| Blacklist check ok
    2015-04-27 13:13:19.271832|INFO    |ClientUI      |  1| Initiating connection: 127.0.0.1:9987 127.0.0.1
    2015-04-27 13:13:19.556671|INFO    |PreProSpeex   |  1| Speex version: 1.2rc1
    warning: The VAD has been replaced by a hack pending a complete rewrite
    2015-04-27 13:13:19.654510|INFO    |ClientUI      |  1| Connect status: Connecting
    2015-04-27 13:13:19.657782|INFO    |ClientUI      |   | Last update check was: So. Jan. 1 00:00:01 2017
    2015-04-27 13:13:19.658975|DEVELOP |PktHandler    |   | Puzzle solve time: 4
    2015-04-27 13:13:19.671137|INFO    |ClientUI      |  1| Connect status: Disconnected
    2015-04-27 13:13:19.671211|INFO    |ClientUI      |  1| Disconnected or forced to leave, want autoreconnect = 0
    If you need some more information you can post it here.
    I hope someone can help me.
    ChaoZz
    17,851
    Is there a server running and listening to 127.0.0.1 on the same machine ?
    April 2015
    Yes there is a TS3 server listening on 127.0.0.1 but what shall i change?
    April 2015
    Can no one help me?
    How can i have client and server on one linux system?
    17,851
    Quote Originally Posted by ChaoZz View Post
    Make sure that the server is realy running/listen on 127.0.0.1 on port 9987.
    Can no one help me?
    Normal this can be done in any operation system (Linux / FreeBSD / OSX / Windows). I do test that weekly.
    It will not work, when 127.0.0.1 is not your ip.
    April 2015
    The server listens on 0.0.0.0:9987
    Problem is still there. Maybe becuase this warning pops?:
    Edit: when i try to start the client via './ts3client_runscript.sh' i get this:
    QXcbConnection: Could not connect to display
    17,851
    VAD = voice activation detection. This has nothing to do with connection.
    QXcbConnection: Could not connect to display = The GUI can not load and be shown an your desktop.
    Your first log does look a bit different from a normal client.
    Is this a real client installed on a Computer with a Desktop and not only a console?
    In case you do not have a desktop OS: We do not support that.
    I can not solve your problem. check your firewall settings or whatever blocks the client from connecting to 127.0.0.1. also do try another server to valid that your client can connect to other servers.
  1. Teamspeak3 Client not connecting to any servers?
    By STARBUCK_107 in forum Windows
    Last Post: August 24th, 2015, 12:54 AM
  2. TeamSpeak3 autostart Linux Debian 5
    By nfsmw15 in forum Tools / Web Based
    Last Post: February 12th, 2015, 09:56 AM
  3. [DEBIAN] Trying to start teamspeak3 server with screen
    By Ghostaunt in forum Linux / FreeBSD
    Last Post: November 10th, 2013, 11:55 AM
  4. Teamspeak3 Client 3.0.10 not connecting
    By Ray Lang in forum Windows
    Last Post: January 3rd, 2013, 08:03 AM
