Results 1 to 2 of 2
    October 2006
    UK
    How to reassign whisper hotkey on-the-fly?
    Hi all,
    I'd like to be able to use the same push-to-talk hotkey, but change which whisper list it uses based on key input from another device.
    Basically I want to use a separate rotary selector to select the whisper channel. I'd be happy to use extra software like autohotkey to do this, but I can't figure out how to get ts3 to switch whisper lists with the same key.
    Or is there an even better solution that I'm missing?
    Thanks,
    phoenix1963
    October 2006
    UK
    It can be done using Autohotkey
    I've used a rotary switch connected to Leo Bodnars BU0836A USB device to select which key gets sent from my push-to-talk button on a joystick with the following code for Autohotkey. A couple of points to remember: firstly DON'T set your push-to-talk key as a TS3 hotkey; secondly, you must have the input devices set as Default, i.e. Settings->Options->Hotkeys->Default (on bottom right) . My selector switch is joystick 5, the push-to-talk key is on joystick 4 (a Saitek X-52 throttle), because I've not soldered-up a diode matrix, the selector keys are in an odd order. You'll have to change all this.
    <code>
    JoystickA = 5
    JoystickB = 4
    PTT = 7
    Hotkey %JoystickB%joy%PTT%, TALK
    Return
    TALK:
    GetKeyState, Select1, %JoystickA%joy31, "P"
    GetKeyState, Select2, %JoystickA%joy25, "P"
    GetKeyState, Select3, %JoystickA%joy19, "P"
    GetKeyState, Select4, %JoystickA%joy13, "P"
    GetKeyState, Select5, %JoystickA%joy7, "P"
    GetKeyState, Select6, %JoystickA%joy1, "P"
    if Select1 = D
    send {F4 down}
    keyWait, %JoystickB%joy%PTT%
    send {F4 up}
    else if Select2 = D
    send {F5 down}
    send {F5 up}
    else if Select3 = D
    send {F6 down}
    send {F6 up}
    else if Select4 = D
    send {F7 down}
    send {F7 up}
    else if Select5 = D
    send {F8 down}
    send {F8 up}
    else
    send {F3 down}
    send {F3 up}
    Return
    <\code>
    This bboard has no <code></code> options, but I'm sure you understand.
    phoenix1963
  1. Replies: 2
    Last Post: March 20th, 2015, 12:45 AM
  2. [Rejected] Hotkeys for Whisper List Group Toggle (turning the groups on and off via hotkey)
    By Nantucket in forum Suggestions and Feedback
    Last Post: June 6th, 2013, 10:33 PM
  3. Replies: 0
    Last Post: February 19th, 2012, 09:00 AM
  4. [Solved] Whisper hotkey not working with TS3 latest version
    By robscott in forum Bug Reports [EN/DE]
    Last Post: June 4th, 2010, 06:08 AM
  5. Hotkey-Whisper information
    By chevy24go in forum General Questions
    Last Post: April 3rd, 2010, 10:04 AM
