Results 1 to 3 of 3
    July 2015
    Clients losing connection
    VPS hosted in Roubix
    Debian Linux 8 x64
    3 cores
    4 GB Ram
    Load: 0.26 (1 min) 0.67 (5 mins) 0.43 (15 mins)
    Running a single virtual server
    ts3server.ini
    machine_id=
    default_voice_port=9987
    voice_ip=xxx.xxx.xxx.xxx
    licensepath=
    filetransfer_port=30033
    filetransfer_ip=xxx.xxx.xxx.xxx
    query_port=10011
    query_ip=xxx.xxx.xxx.xxx
    query_ip_whitelist=query_ip_whitelist.txt
    query_ip_blacklist=query_ip_blacklist.txt
    dbplugin=ts3db_sqlite3
    dbpluginparameter=
    dbsqlpath=sql/
    dbconnections=10
    logpath=logs
    logquerycommands=0
    dbclientkeepdays=120
    logappend=0
    query_skipbruteforcecheck=0
    Starting Log:
    2015-07-19 18:09:37.821626|INFO    |ServerLibPriv |   | TeamSpeak 3 Server 3.0.11.3 (2015-04-13 13:26:31)
    2015-07-19 18:09:37.822563|INFO    |ServerLibPriv |   | SystemInformation: Linux 2.6.32-042stab108.5 #1 SMP Wed Jun 17 20:20:17 MSK 2015 x86_64 Binary: 64bit
    2015-07-19 18:09:37.822619|INFO    |ServerLibPriv |   | Using hardware aes
    2015-07-19 18:09:37.839635|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2015-07-19 18:09:37.841267|INFO    |DatabaseQuery |   | dbPlugin version: 3.6.21
    2015-07-19 18:09:37.848851|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2015-07-19 18:09:38.180638|INFO    |Accounting    |   | Licensing Information
    2015-07-19 18:09:38.180727|INFO    |Accounting    |   | type              : Non-profit
    2015-07-19 18:09:38.180790|INFO    |Accounting    |   | starting date     : Mon Jun  1 00:00:00 2015
    2015-07-19 18:09:38.180834|INFO    |Accounting    |   | ending date       : Thu Dec 10 00:00:00 2015
    2015-07-19 18:09:38.180869|INFO    |Accounting    |   | max virtualservers: 10
    2015-07-19 18:09:38.180901|INFO    |Accounting    |   | max slots         : 512
    2015-07-19 18:09:39.061555|INFO    |              |   | Puzzle precompute time: 850
    2015-07-19 18:09:39.062047|INFO    |FileManager   |   | listening on xxx.xxx.xxx.xxx:30033
    2015-07-19 18:09:39.147230|INFO    |CIDRManager   |   | updated query_ip_whitelist ips: 127.0.0.1, yyy.yyy.yyy.yyy,
    2015-07-19 18:09:39.150408|INFO    |Query         |   | listening on xxx.xxx.xxx.xxx:10011
    Virtual server start:
    2015-07-19 18:09:39.145094|INFO    |VirtualServer |  2| listening on xxx.xxx.xxx.xxx:9987
    At random occasions clients are dropped:
    2015-07-20 21:33:10.870739|INFO    |VirtualServerBase|  2| client disconnected '*****'(id:27) reason 'reasonmsg=connection lost'
    2015-07-20 21:33:12.274579|INFO    |VirtualServerBase|  2| client disconnected '*****'(id:4) reason 'reasonmsg=connection lost'
    2015-07-20 21:33:15.009013|INFO    |VirtualServerBase|  2| client disconnected '*****'(id:61) reason 'reasonmsg=connection lost'
    2015-07-20 21:33:15.311134|INFO    |VirtualServerBase|  2| client disconnected '*****'(id:10) reason 'reasonmsg=connection lost'
    2015-07-20 21:33:16.013816|INFO    |VirtualServerBase|  2| client disconnected '*****'(id:4) reason 'reasonmsg=connection lost'
    2015-07-20 21:33:22.466609|INFO    |VirtualServerBase|  2| client disconnected '*****'(id:61) reason 'reasonmsg=connection lost'
    Mtr's run at same time from VPS to my home IP. The 100% loss is due to my router config. I believe the reports do not reveal the problem.
    Start: Mon Jul 20 21:32:41 2015
    HOST: devils-battalion.com        Loss%   Snt   Last   Avg  Best  Wrst StDev
      1.|-- 43.ip-37-187-242.eu        0.0%    12    0.1   0.1   0.1   0.1   0.0
      2.|-- rbx-g2-a9.fr.eu            0.0%    12    1.4   1.1   0.8   2.6   0.3
      3.|-- ldn-5-a9.uk.eu             0.0%    12   10.5  10.6  10.2  13.8   0.9
      4.|-- ldn-1-a9.uk.eu             0.0%    12   10.3  10.3  10.2  10.5   0.0
      5.|-- linx-gw2.plus.net          0.0%    12   10.1  10.2  10.1  11.0   0.0
      6.|-- irb.10.central10.ptn-bng0  0.0%    12   10.2  10.5  10.2  11.2   0.0
      7.|-- ???                       100.0    12    0.0   0.0   0.0   0.0   0.0
    Start: Mon Jul 20 21:33:41 2015
      1.|-- 43.ip-37-187-242.eu        0.0%    12    0.1   0.1   0.0   0.1   0.0
      2.|-- rbx-g2-a9.fr.eu            0.0%    12    2.7   1.4   0.8   2.7   0.6
      3.|-- ldn-5-a9.uk.eu             0.0%    12   10.8  10.5  10.1  10.8   0.0
      4.|-- ldn-1-a9.uk.eu             0.0%    12   10.5  10.3  10.2  10.5   0.0
      5.|-- linx-gw2.plus.net          0.0%    12   10.2  10.5  10.1  13.3   0.7
      6.|-- irb.10.central10.ptn-bng0  0.0%    12   10.2  10.5  10.2  12.3   0.4
    Start: Mon Jul 20 21:34:42 2015
      2.|-- rbx-g2-a9.fr.eu            0.0%    12    1.2   1.2   0.6   2.3   0.3
      3.|-- ldn-5-a9.uk.eu             0.0%    12   10.2  11.2  10.2  16.4   1.8
      4.|-- ldn-1-a9.uk.eu            16.7%    12   10.4  13.8  10.4  30.2   6.5
      5.|-- linx-gw2.plus.net          0.0%    12   10.1  13.5  10.1  30.0   7.2
      6.|-- irb.10.central10.ptn-bng0  0.0%    12   10.3  10.6  10.2  12.1   0.3
    I have had the occasional drop of connection via SSH to the VPS. The VPS host is not aware of any problems. Is there a way I can stress test teamspeak, or the VPS in general? Or take further steps to find and solve the my issue?
    Thanks
    4,368
    Mtr's running at the same time but only 12 ticks? That makes no sense.
    July 2015
    I had it run a tick each 5 seconds, so 12 ticks per minute. This was repeated for over a time period
  1. Clients losing connection at random times.
    By archina in forum Linux / FreeBSD
    Last Post: August 31st, 2015, 11:31 PM
  2. TS Losing Connection
    By Maumau in forum Windows
    Last Post: December 12th, 2013, 03:03 PM
  3. Losing connection
    By zaynekro in forum Client Support
    Last Post: May 6th, 2013, 10:14 AM
  4. Losing connection
    By fabianmdp in forum Windows
    Last Post: November 25th, 2010, 01:48 PM
