Page 5 of 6 FirstFirst ... 3456 LastLast
Results 61 to 75 of 82
  1. #61
    March 2016
    TS client not responding, wont even slightly load
    This has confused me, i recently did a complete reset on my PC and all was going fine, except of TS3. Everytime i install it its fine but as soon as i run it it instantly comes up with Teamspeak is not responding, i have tried EVERYTHING, updated windows updated driver, got hold of an old version of TS and tried to update, nothing will work, Please help!
    Error detail:
    Fault Module Version: 12.0.21005.1
    Fault Module Timestamp: 524f83ff
    Exception Code: c000001d
    Exception Offset: 0000000000096cd5
    OS Version: 6.1.7600.2.0.0.768.3
    Locale ID: 2057
    Additional Information 1: 1fab
    Additional Information 2: 1fab4d6e6a1d4090fe281f284a3b7c00
    Additional Information 3: 2e6c
    Additional Information 4: 2e6ccb7448c9ada25ccb362d88a0c4a4
    Read our privacy statement online:
    http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
  2. #62
    April 2016
    Teamspeak 3.0.19 crashing
    I just updated my TS to the latest version out now, and now it is crashing on open every time..
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: ts3client_win64.exe
    Application Version: 3.0.19.0
    Application Timestamp: 56fe4998
    Fault Module Name: MSVCR120.dll
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 1033
    Additional Information 3: 4431
    Additional Information 4: 44315a5ba44569b427d9f1530b1c346e
    thats my problem log
  3. #63
    April 2016
    Error launching Teamspeak 3 64 Bit
    I tried reinstalling but nothing works by the way.
    here is the problem details.
    Problem signature:
    Problem Event Name: BEX64
    Exception Offset: 000000000006dd3d
    Exception Code: c0000417
    Exception Data: 0000000000000000
    OS Version: 6.1.7600.2.0.0.256.48
    Locale ID: 13321
    Additional Information 1: 1356
    Additional Information 2: 1356cfcb48fc027f984f0ebe0f11fd4d
    Additional Information 3: 498c
    Additional Information 4: 498c75bd2b339a92b44c32ef1cf1f316
  4. #64
    May 2016
    Teamspeak 3 APPCRASH
    So basically i downloaded teamspeak 3 before but it always say "TeamSpeak 3 Client has stopped working"
    then i kept on reinstalling it cause it never worked.
    I Clicked "View Problem details and it says.
    Problem signature:
    Application Timestamp: 571e1788
    Locale ID: 1033
    Additional Information 3: c945
    Additional Information 4: c945d69eb4f9390118dcf44deceb7daa
    Someone Please help me fix this problem.
  5. #65
    May 2016
    3.0.19.1 installs but client doesn't run
    My old Windows box halted-and-caught-fire last week, so now I'm installing all my toys on a new box. Still Windows 7, 64-bit. I installed TeamSpeak using the current downloader (3.0.19.1) and it seemed to install successfully. I've tried putting it both in \Users\Don\AppData and in the default \Program Files, with the same result, to wit: When I click to open the client, the cursor spins briefly but no window appears. Unlike some similar threads I saw, I also do not get an icon in my task bar. If I watch the Task Manager I can see the tsclient process appear for a couple seconds and then it goes away completely.
    Is there some way I can capture some log info that might explain why the process is exiting immediately?
    Since I still have the installer for 3.0.5 from when I built the old box, I tried putting it in instead. It does open the client window, but of course it can no longer connect to current servers. It offers to update to 3.0.19.1, but when I tell it to do so the update fails (see output below). But it raises the possibility that if I can still obtain a copy of the 3.0.19 installer, perhaps it would be able to open a window. (I could deal with the risk of an arcane unicode string!)
    The output from the Client Update log seems to indicate it cannot even contact a server; for all I know 3.0.5 is so out of date that even the method of locating a mirror have changed, but I'd doubt that. Is there a firewall rule I need to add to let the updater run?
    Previous update session for v. 1461588969 found
    Starting update process
    Download / check product ini
    Downloading client_win64.ini
    http://teamspeak.gameserver.gamed.de...ient_win64.ini returned 404
    file client_win64.ini timed out on mirror Eighth mirror
    http://mirrors.uk.multiplay.co.uk/te...ient_win64.ini returned 404
    Connection timed out
    http://ftp.4players.de/pub/hosted/ts...ient_win64.ini returned 404
    http://dl-2.verygames.net/teamspeak/...ient_win64.ini returned 302
    Connecting to host failed:
    Host ftp2.globalnet.de not found
    Mirror Eighth mirror failed too many times, removing
    Connection refused to host 217.114.222.179
    Mirror Forth mirror failed too many times, removing
    Mirror Sixth mirror failed too many times, removing
    There are no (more) known working mirrors available
    Update cancelled
  6. #66
    6,078
    In fact the way updates are done has changed in the past and anything older than at least client 3.0.16 I believe won't be able to update automatically anymore as the old system was removed / shut down by now.
    As for the client not working, check the logs folder in the config location. This can either be "Path to Client Install\config\logs" or "%AppData%\TS3Client\logs" Maybe the logs will contain some information.
  7. #67
    May 2016
    The logs do not appear in either of those places. Could there be a file permissions error preventing its creation, and could that be my problem? (I tried running the client as Admin but it still failed in the same way.)
  8. #68
    6,078
    Client shouldn't (have to) be run as admin.
    See if (Client Install Path)/config exists, if it does uninstall the client, then reinstall making sure to select "store in user files" during installation.
    Also check to see if %AppData%\TS3Client\crashdumps does exist and / or contains files.
    Make sure you meet the system requirements too, most notably an up to date operating system including all service packs and an SSE2 capable CPU.
  9. #69
    May 2016
    problem solved: was missing SP1
    I found the Windows Event Log and examined the Error events when I tried to run the TS client. They were cryptic but included a dll name. Adding that to the search located this thread:
    http://forum.teamspeak.com/threads/1...-(64-bit-only)
    in which the problem was solved by installing SP1. To my surprise, I found that the techs who set up my new box indeed failed to install SP1. I installed that and now TS runs fine.
  10. #70
    May 2016
    TS3 crashes immediately upon booting
    Hello!
    I am having some issues with teamspeak. Yesterday, I had to do a clean installation of my operating system. Today, after installing teamspeak, it fails to boot up. I have tried uninstalling and reinstalling, but I'm kinda stuck at this point. Any advice?
    System specs in case they are needed.
    CPU: i5-4690k
    GPU: MSI GTX 960
    RAM: 16GB
    OS: Windows 7 64bit
    This is the error I get under "problem details."
    Locale ID: 1033
    Thanks in advance!
  11. #71
    October 2012
    553
    Install Service Pack 1, then try again.
  12. #72
    May 2016
    Crash after install - TS3 cant be open
    Someone could help me.
    My windows is 64 bits. I dl the software and install.
    After that when i click at icon to open the software, this happens:
ID:	13908Click image for larger version.
  13. #73
    June 2016
    Team speak 3 crush
    Well, i installed TS3 in my PC and always i try to open it crush
    I copy the message that appears below:
    Firma con problemas:
    Nombre del evento de problema: APPCRASH
    Nombre de la aplicación: ts3client_win64.exe
    Versión de la aplicación: 3.0.19.0
    Marca de tiempo de la aplicación: 576bc171
    Nombre del módulo con errores: MSVCR120.dll
    Versión del módulo con errores: 12.0.21005.1
    Marca de tiempo del módulo con errores: 524f83ff
    Código de excepción: c000001d
    Desplazamiento de excepción: 0000000000096cd5
    Versión del sistema operativo: 6.1.7600.2.0.0.256.1
    Id. de configuración regional: 13322
    Información adicional 1: 1fab
    Información adicional 2: 1fab4d6e6a1d4090fe281f284a3b7c00
    Información adicional 3: 4c62
    Información adicional 4: 4c62c311633f861eae19fe2ac7afb455
    I have tried reinstalling TS3 but it still crush.
    Please any help will be well receibed.
  14. #74
    September 2016
    ts3 crashes
    my ts3 crashes after my windoes users crashed i have putted a pure ghost/gho *if u don't know what ghost is ,it is a back up system but it backs up the hole system* so once i got the pc i backed up after installing windoes and setting up the gpu drivers i puted this ghost/gho simply i just have i new windoes or something like thatAttachment 14254Attachment 14254 and now the ts3 crashes once i open it i uninstalled it and install it couple time but it didn't work and i think it was working before the crash idk if this an update problem or mine but please take care of it
    Last edited by dante696; September 7th, 2016 at 11:08 AM. Reason: merged, we have a search feature
  15. #75
    September 2016
    не запускается
    не запускается после обновления
    Сигнатура проблемы:
    Имя события проблемы: APPCRASH
    Имя приложения: ts3client_win64.exe
    Версия приложения: 3.0.19.4
    Отметка времени приложения: 57876839
    Имя модуля с ошибкой: MSVCR120.dll
    Версия модуля с ошибкой: 12.0.21005.1
    Отметка времени модуля с ошибкой: 524f83ff
    Код исключения: c000001d
    Смещение исключения: 0000000000096cd5
    Версия ОС: 6.1.7600.2.0.0.768.3
    Код языка: 1049
    Дополнительные сведения 1: 1fab
    Дополнительные сведения 2: 1fab4d6e6a1d4090fe281f284a3b7c00
    Дополнительные сведения 3: dfb0
    Дополнительные сведения 4: dfb07baf30916a2f47fc0c8d93a55ee7
  1. After Crash: Client won't start!
    By ThomasTailor93 in forum Client Support
    Last Post: January 5th, 2013, 05:44 PM
  2. TS3 crash and don't start now
    By tnagiurd in forum Windows
    Last Post: March 9th, 2010, 03:48 PM
  3. [BUG] Crash at start-up...
    By Elric2 in forum Windows
    Last Post: January 20th, 2010, 10:28 AM
