Hi there friends.
Im writing this to ask about an issue that I am having when using TS3 3.0.17
and the little usb device for headphones Sound blaster Play!2 : http://us.creative.com/p/sound-blast...blaster-play-2
Device Driver version 1.2.2.25
and Windows 10 home.
The issue is that all my sound clips when i get connected to a server in ts3.
After the connection is estabilished, or kicks in, the entire Windows sound cuts off.
The White/green meter that we have in the audio device panels is locked not moving, eather for playback or mic.
The system gets freezed
Then if i close TS3 the Windows audio comes back again with no problem.
The error happens in all tries.
I already have tried to change the playback/ capture devices back and forth.
And I can notice that when Im changing the device from Default to Play!2 "name" and push apply, the error happens, and the sound locks.
no other program is clipping this usb device, only TS3.
What should I do to be able to use TS3 with this usb device, please?
TS3 version: 3.0.17
OS: Windows 10 home
Audio card is the little usb device sound blaster play!2, driver version 1.2.2.25 (02/06/2015)
And the onboard audio device VIA HD audio, driver 6.0.11.800 (15/06/2015) is deactivated.
Directx 11
This is the log from one try out:
23/08/2015 00:30:35 Info TeamSpeak 3 Client 3.0.17 (2015-08-04 07:38:33)
23/08/2015 00:30:35 Info SystemInformation: Windows 8 (9200) x64 (AMD or Intel) Binary: 64bit
23/08/2015 00:30:35 Direct Sound Debug setting timer resolution to 1ms
23/08/2015 00:30:35 Info Loading plugin: clientquery_plugin
23/08/2015 00:30:35 Info Loading plugin: lua_plugin
23/08/2015 00:30:35 Info Loading plugin: teamspeak_control_plugin
23/08/2015 00:30:35 Info Loading plugin: test_plugin
23/08/2015 00:30:35 Info Loading plugin: ts3g15
23/08/2015 00:30:35 Query Info listening on 127.0.0.1:25639
23/08/2015 00:30:36 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
23/08/2015 00:30:36 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
23/08/2015 00:30:36 Info *** Time [SERVERVIEW]: 101
23/08/2015 00:30:36 Info *** Time [SERVERVIEWMANAGER]: 210
23/08/2015 00:30:37 InputDevices Info Input device name: Creative Technology, Ltd HID Device
23/08/2015 00:30:37 InputDevices Info UNKNOWN DEVICE: VID_041E&PID_323D&MI_03&COL02#8&26BA05FA&0&0001
23/08/2015 00:30:37 Input Info Default monitoring enabled
23/08/2015 00:30:37 Info *** Time [HOTKEYS]: 136
23/08/2015 00:30:37 Info *** Time [MAINWINDOW]: 1861
23/08/2015 00:30:37 Info *** Time [INIT]: 1877
23/08/2015 00:30:37 ClientUI Info *** Time [SQLITE_CONVERTER]: 578
23/08/2015 00:30:37 ClientUI Info Qt version: 5.4.1
23/08/2015 00:30:37 ClientUI Info Using configuration location: C:\Users\fgb\AppData\Roaming\TS3Client\settings.db
23/08/2015 00:30:38 ClientUI Info Last update check was: Never
23/08/2015 00:30:38 ClientUI Info Checking for update
23/08/2015 00:30:38 Update Info Checking for updates...
23/08/2015 00:30:38 Newsticker Info Newsticker language change detected
23/08/2015 00:30:38 Newsticker Info Newsticker next check:
23/08/2015 00:30:39 Newsticker Info Newsticker not found for language pt
23/08/2015 00:30:40 Newsticker Info Newsticker received for language pt, expires on sáb ago 22 22:00:39 2015, next check in 1800 seconds
23/08/2015 00:30:40 Update Info Check license version: 1
23/08/2015 00:30:40 LicenseViewer Info License language: pt
23/08/2015 00:30:40 LicenseViewer Info Requesting remote license for version 1 and language pt
23/08/2015 00:30:40 LicenseViewer Info Downloaded license file for version 1 and language pt
23/08/2015 00:30:54 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
23/08/2015 00:30:54 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
23/08/2015 00:30:54 Windows Audio Session Debug WAS:penDevice-enter
23/08/2015 00:30:54 Windows Audio Session Debug WAS Buffer size: 970
23/08/2015 00:30:54 Windows Audio Session Debug WAS:penDevice-leave
23/08/2015 00:30:54 PreProSpeex Info Speex version: speex-1.2beta3
23/08/2015 00:30:54 Windows Audio Session Debug WAS::startDevice-enter
23/08/2015 00:30:54 Windows Audio Session Debug WAS::startDevice-leave
23/08/2015 00:30:57 Windows Audio Session Debug WAS::stopDevice-enter
23/08/2015 00:30:57 Windows Audio Session Debug WAS::stopDevice-leave
23/08/2015 00:30:57 Windows Audio Session Debug WAS::closeDevice-enter
23/08/2015 00:30:57 Windows Audio Session Devel DeviceDeleteList::queueDeviceDelete - enter
23/08/2015 00:30:57 Windows Audio Session Devel DeviceDeleteList::queueDeviceDelete - leave
23/08/2015 00:30:57 Windows Audio Session Debug WAS::closeDevice-leave
23/08/2015 00:30:57 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
23/08/2015 00:30:57 Windows Audio Session Devel Waiting for device to close
23/08/2015 00:30:57 Windows Audio Session Devel DeviceDeleteList::clearQueue - enter
23/08/2015 00:30:57 Windows Audio Session Devel DeviceDeleteList::clearQueue - leave
23/08/2015 00:30:57 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
23/08/2015 00:31:28 ClientUI Info Connect to server: voice.teamspeak.com
23/08/2015 00:31:28 ClientUI Info Trying to resolve voice.teamspeak.com
23/08/2015 00:31:28 TSDNS Info SRV DNS resolve unsuccessful for "_ts3._udp.voice.teamspeak.com"
23/08/2015 00:31:28 TSDNS Info No SRV TSDNS found at "_tsdns._tcp.voice.teamspeak.com"
23/08/2015 00:31:28 TSDNS Info DNS resolve successful, "voice.teamspeak.com"=194.97.114.2
23/08/2015 00:31:29 TSDNS Info TSDNS found at "voice.teamspeak.com" and queried successfully. Result: 194.97.114.2:9987
23/08/2015 00:31:29 TSDNS Info SRV TSDNS found at "_tsdns._tcp.teamspeak.com"=>"voice.teamspeak.com: 41144" and queried successfully. Result: 194.97.114.2:9987
23/08/2015 00:31:29 ClientUI Info Lookup finished: 194.97.114.2 9987 voice.teamspeak.com 1 0
23/08/2015 00:31:29 ClientUI Info Resolve successful: 194.97.114.2:9987
23/08/2015 00:31:29 ClientUI Info Blacklist check ok
23/08/2015 00:31:29 ClientUI Info Initiating connection: 194.97.114.2:9987 voice.teamspeak.com
23/08/2015 00:31:29 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
23/08/2015 00:31:29 Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
23/08/2015 00:31:29 Windows Audio Session Debug WAS:penDevice-enter
23/08/2015 00:31:29 Windows Audio Session Debug WAS Buffer size: 970
23/08/2015 00:31:29 Windows Audio Session Debug WAS:penDevice-leave
23/08/2015 00:31:29 Windows Audio Session Debug WAS::startDevice-enter
23/08/2015 00:31:29 Windows Audio Session Debug WAS::startDevice-leave
23/08/2015 00:31:29 ClientUI Info Connect status: Connecting
23/08/2015 00:31:30 PktHandler Devel Puzzle solve time: 22
23/08/2015 00:31:32 ClientUI Info Connect status: Connected
23/08/2015 00:31:32 ClientUI Info Connect status: Establishing connection
23/08/2015 00:31:32 Info Failed to download remote image: Error downloading http://www.teamspeak.com/images/misc/90x90_ts3_logo.png - server replied: Not Found 203
23/08/2015 00:31:32 Info Failed to download remote image: Error downloading http://www.teamspeak.com/media_repos...0-claim_02.jpg - server replied: Not Found 203
23/08/2015 00:31:36 ClientUI Info Connect status: Connection established
23/08/2015 00:31:36 PermManager Info Requesting permissions from server
23/08/2015 00:31:39 ClientUI Info Failed to play wave file: ok
23/08/2015 00:31:40 ClientUI Info Failed to play wave file: ok
23/08/2015 00:31:41 ClientUI Info Failed to play wave file: ok
23/08/2015 00:31:42 ClientUI Info Failed to play wave file: ok
23/08/2015 00:31:45 ClientUI Info Failed to play wave file: ok
23/08/2015 00:31:46 ClientUI Info Failed to play wave file: ok
23/08/2015 00:31:47 ClientUI Info Failed to play wave file: ok
23/08/2015 00:31:48 ClientUI Info Failed to play wave file: ok
23/08/2015 00:31:49 ClientUI Info Failed to play wave file: ok
23/08/2015 00:31:50 ClientUI Info Failed to play wave file: ok
Thanks.
