Results 1 to 2 of 2
    September 2015
    Server Admin Server Group does not have total control over Permissions
    Hi! I'm hosting my TeamSpeak server on a VPN over at DigitalOcean. Everything started out well and good, I was able to set up the server admin user group, which I renamed to Overseer. I also added in client permissions, so even if I remove myself from the SA "Overseer" group, I can still re-add me. However, I'm unable to change some permissions. I'm unable to change permissions above 75 (75 is default for Overseer), and on the ranks below(Example: I've got a normal "admin" with some permissions limited down to 60. I cannot, as a Overseer change the "ignore permissions modify power" permission on the "admin").
    I tried re-adding the token thorugh putty and telnet, but it says the token is already in use. It's feeling like this is a bug.
    18,151
    It's a wanted behavior to stop users to be like a ServerQuery.
    You do not need permissions above 75! And you do not need "ignore permissions modify power".
    Use the ServerQuery and not the client to act like a ServerQuery.
  1. Replies: 1
    Last Post: January 11th, 2014, 05:10 PM
  2. Reset only the group for server admin permissions
    By Mindless in forum Permission System
    Last Post: July 9th, 2013, 03:33 PM
  3. No permissions to view this group with Server Admin
    By M at t in forum Permission System
    Last Post: March 1st, 2013, 10:28 AM
  4. Editing Server Admin Group - Not enough permissions!
    By mSlat3r in forum Server Support
    Last Post: July 26th, 2012, 02:06 PM
  5. How to change Server Admin group permissions
    By Bobo Balde in forum Permission System
    Last Post: January 11th, 2012, 06:09 PM
