Greetings,
Description of the problem:
Suddenly (no changes in my PC done, nothing new installed, no config changed), I started having lag/packet loss (hearing people like robots) at a TS3 server, while one other worked fine. I tried to check more server adresses and most of them didn't allow me to connect ("Failed to connect to server"):
I tried with like 50 server addresses, only 2 worked fine, the rest failed to connect or connected but I had huge lag inside (takes a lot to load and move to channels, hear people like robots). It is not problem of the servers cause other people can use them fine (I tested)<03:20:38> Trying to resolve hostname voice.teamspeak.com
<03:20:39> Trying to connect to server on voice.teamspeak.com
<03:20:55> Failed to connect to server
However I tested it with a friend and he said he hears me nice (seems no outgoing packet loss, just incoming)
I read some topics on this forum, my router has no "IP flood" firewall enabled, which seemed to cause related problems to mine.
I also tried resetting internet connection (I use a cable), updating to last TS3 version (3.0.18.1)
I also did tracert and ping to two example server that I got problems with:
tracert - in Spanish (noted timeouts)
ping:>tracert ts3.swifthosting.dk
Traza a la dirección ts3.swifthosting.dk [151.80.90.218]
sobre un máximo de 30 saltos:
1 1 ms <1 ms <1 ms 192.168.0.1
2 13 ms 40 ms 63 ms cm-93-156-72-254.telecable.es [93.156.72.254]
3 7 ms 9 ms 5 ms cm-staticIP-212-89-30-21.telecable.es [212.89.30
.21]
4 8 ms 7 ms 7 ms te0-0-0-3.rcr11.ovd01.atlas.cogentco.com [149.6.
106.1]
5 10 ms 11 ms 12 ms te0-1-0-6.ccr22.bio02.atlas.cogentco.com [154.54
.39.201]
6 15 ms 15 ms 15 ms be2293.ccr22.mad05.atlas.cogentco.com [130.117.5
0.26]
7 17 ms 15 ms 18 ms francetelecom.mad05.atlas.cogentco.com [130.117.
14.138]
8 * 16 ms * mad-5-6k.es.eu [91.121.131.105]
9 31 ms 31 ms 31 ms gsw-1-a9.fr.eu [178.33.100.245]
10 37 ms 35 ms 35 ms rbx-g2-a9.fr.eu [213.251.130.54]
11 37 ms 35 ms 39 ms vac1-0-a9.fr.eu [178.33.100.151]
12 37 ms 35 ms 35 ms vac1-1-n7.fr.eu.firewall [178.33.100.152]
13 37 ms 35 ms 35 ms vac1-2-n7.fr.eu [91.121.215.9]
14 38 ms 35 ms 35 ms vac1-3-n7.fr.eu [91.121.215.13]
15 * * * Tiempo de espera agotado para esta solicitud. (timeout)
16 * * * Tiempo de espera agotado para esta solicitud.
17 * * * Tiempo de espera agotado para esta solicitud.
18 * * * Tiempo de espera agotado para esta solicitud.
19 * * * Tiempo de espera agotado para esta solicitud.
20 * * * Tiempo de espera agotado para esta solicitud.
21 * * * Tiempo de espera agotado para esta solicitud.
22 * * * Tiempo de espera agotado para esta solicitud.
23 * * * Tiempo de espera agotado para esta solicitud.
24 * * * Tiempo de espera agotado para esta solicitud.
25 * * * Tiempo de espera agotado para esta solicitud.
26 * * * Tiempo de espera agotado para esta solicitud.
27 * * * Tiempo de espera agotado para esta solicitud.
28 * * * Tiempo de espera agotado para esta solicitud.
29 * * * Tiempo de espera agotado para esta solicitud.
30 * * * Tiempo de espera agotado para esta solicitud.
Traza completa.
>tracert voice.teamspeak.com
Traza a la dirección voice.teamspeak.com [194.97.114.2]
1 5 ms <1 ms <1 ms 192.168.0.1
2 8 ms 45 ms 9 ms cm-93-156-72-254.telecable.es [93.156.72.254]
3 7 ms 6 ms 7 ms cm-staticIP-212-89-30-21.telecable.es [212.89.30
.21]
4 6 ms 8 ms 7 ms 212.89.3.225
5 18 ms 20 ms 45 ms 212.89.3.42
6 20 ms 20 ms 19 ms mad-b2-link.telia.net [195.12.254.133]
7 37 ms 38 ms 35 ms prs-bb3-link.telia.net [213.155.133.200]
8 44 ms 47 ms 47 ms ffm-bb1-link.telia.net [62.115.143.88]
9 46 ms 47 ms 56 ms ffm-b1-link.telia.net [62.115.137.249]
10 44 ms 47 ms 47 ms freenet-ic-138218-ffm-b11.c.telia.net [213.248.7
1.2]
11 49 ms 51 ms 52 ms xe-0-1-1-0.dus2-j.mcbone.net [62.104.191.196]
12 49 ms 51 ms 51 ms Vlan61.dus1-x0.mcbone.net [62.104.198.178]
13 51 ms 51 ms 52 ms pollard.kreml.4players.de [62.104.16.240]
14 50 ms 51 ms 51 ms laurel.teamspeak.4players.de [194.97.114.2]
Traza completa.
"voice.teamspeak.com" seemed to be "ok" on the tests but I still get "Failed to connect" - on the other hand, I can log into the other TS3 in this example (after a few mins waiting), which had ping and tracer problems, but I have a lot of lag inside it.>ping voice.teamspeak.com
Haciendo ping a voice.teamspeak.com [194.97.114.2] con 32 bytes de datos:
Respuesta desde 194.97.114.2: bytes=32 tiempo=49ms TTL=48
Respuesta desde 194.97.114.2: bytes=32 tiempo=48ms TTL=48
Respuesta desde 194.97.114.2: bytes=32 tiempo=51ms TTL=48
Estadísticas de ping para 194.97.114.2:
Paquetes: enviados = 4, recibidos = 4, perdidos = 0
(0% perdidos),
Tiempos aproximados de ida y vuelta en milisegundos:
Mínimo = 48ms, Máximo = 51ms, Media = 49ms
C:\Users\Ignacio>ping ts3.swifthosting.dk
Haciendo ping a ts3.swifthosting.dk [151.80.90.218] con 32 bytes de datos:
Estadísticas de ping para 151.80.90.218:
Paquetes: enviados = 4, recibidos = 0, perdidos = 4
(100% perdidos), (100%lost)
Any idea what can be the source of this problem?
I am really confused that some servers work fine.
I also have no lag in any other program or application that uses internet. (I have a 100mbps DL/10mbps UL connection)
Also while writing this very post, I stopped having lag for 3min, then it's again bad.
Thanks in advance!
