Page 1 of 5 123 ... LastLast
Results 1 to 15 of 69
    March 2014
    7
    Connection issues with light-speed servers.
    Hi guys, I know this question must have been asked a million times haha.
    Anyways I've been locked out of my usual teamspeak for almost a week now. I have google'ed all the answers I could (Which brings me to thread mostly from this forum) and have tried everything I could.
    -Restarted my PC
    -Restarted my router
    -Uninstalled TS3
    -System Restored to a earlier point
    -Changed my internet connection (Went from wired to wire-less and vice versa)
    -Called my ISP (They couldn't do anything)
    -Checked my firewall
    -Checked my Anti-Virus Program
    -Tried logging in using the server's actual IP address
    I have checked it if was maybe my TS3 in general, but I am able to connect to any other TS server no problem.
    one night I was talking to some friends in a channel and I was just booted, no one else was affected.
    Only thing I can add (Not sure if maybe it triggered it) Was a friend had a file he wanted to share with me and another friend, so he uploaded it to the TS and we both downloaded it (Through the File Browser). Right before it finished that was when i was kicked out of my server. The file finished downloading shortly after. My other friend who was downloading the file had no problems, he stayed on the server and finished downloading the file. I'm not sure if this may have contributed to it, but I'm assuming since it never happened before (I've never used File Browser or TS to download anything before) it must have?
    Here is the log when I try to sign in the server as well
    3/10/2014 2:40:12 PM		Info	TeamSpeak 3 Client 3.0.13.1 (2013-10-23 12:10:11)
    3/10/2014 2:40:12 PM		Info	SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 32bit
    3/10/2014 2:40:12 PM	Direct Sound	Debug	setting timer resolution to 1ms
    3/10/2014 2:40:12 PM	Query	Info	listening on 127.0.0.1:25639
    3/10/2014 2:40:13 PM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    3/10/2014 2:40:13 PM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    3/10/2014 2:40:13 PM		Info	*** Time [SERVERVIEWMANAGER]: 172
    3/10/2014 2:40:13 PM	Input	Info	Default monitoring enabled
    3/10/2014 2:40:13 PM		Info	*** Time [MAINWINDOW]: 572
    3/10/2014 2:40:13 PM		Info	*** Time [INIT]: 572
    3/10/2014 2:40:13 PM	ClientUI	Info	Qt version: 4.8.3
    3/10/2014 2:40:13 PM	ClientUI	Info	Using configuration location: C:\Users\Julian\AppData\Roaming\TS3Client\settings.db
    3/10/2014 2:40:13 PM	ClientUI	Info	Last update check was: Mon Mar 10 14:29:48 2014
    3/10/2014 2:40:22 PM	ClientUI	Info	Connect to server: fierce2.teamspeak3.com
    3/10/2014 2:40:22 PM	ClientUI	Info	Trying to resolve fierce2.teamspeak3.com
    3/10/2014 2:40:23 PM	TSDNS	Info	SRV DNS resolve successful, "_ts3._udp.fierce2.teamspeak3.com"=>"ts101.light-speed.com:9161" = 216.127.64.32:9161
    3/10/2014 2:40:23 PM	TSDNS	Info	DNS resolve successful, "fierce2.teamspeak3.com"=216.127.64.32
    3/10/2014 2:40:23 PM	ClientUI	Info	Lookup finished: 216.127.64.32 9161 fierce2.teamspeak3.com 0 0
    3/10/2014 2:40:23 PM	ClientUI	Info	Resolve successful: 216.127.64.32:9161
    3/10/2014 2:40:23 PM	ClientUI	Info	Blacklist check ok
    3/10/2014 2:40:23 PM	ClientUI	Info	Initiating connection: 216.127.64.32:9161 fierce2.teamspeak3.com
    3/10/2014 2:40:23 PM	TSDNS	Info	TSDNS found at "teamspeak3.com" and queried successfully. Result: 216.127.64.32:9161
    3/10/2014 2:40:23 PM	TSDNS	Info	SRV TSDNS found at "_tsdns._tcp.teamspeak3.com"=>"tsdns.light-speed.com:80" and queried successfully. Result: 216.127.64.32:9161
    3/10/2014 2:40:23 PM	TSDNS	Info	TSDNS found at "fierce2.teamspeak3.com" and queried successfully. Result: 216.127.64.32:9161
    3/10/2014 2:40:23 PM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    3/10/2014 2:40:23 PM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    3/10/2014 2:40:23 PM	Windows Audio Session	Debug	WAS::openDevice-enter
    3/10/2014 2:40:23 PM	Windows Audio Session	Debug	WAS Buffer size: 896
    3/10/2014 2:40:23 PM	Windows Audio Session	Debug	WAS::openDevice-leave
    3/10/2014 2:40:23 PM	Windows Audio Session	Debug	WAS::startDevice-enter
    3/10/2014 2:40:23 PM	Windows Audio Session	Debug	WAS::startDevice-leave
    3/10/2014 2:40:23 PM	Windows Audio Session	Debug	WAS Buffer size: 960
    3/10/2014 2:40:23 PM	PreProSpeex	Info	Speex version: speex-1.2beta3
    3/10/2014 2:40:23 PM	Windows Audio Session	Debug	WAS::associateAECDevice-enter
    3/10/2014 2:40:23 PM	Windows Audio Session	Debug	WAS::associateAECDevice-leave
    3/10/2014 2:40:23 PM	ClientUI	Info	Connect status: Connecting
    3/10/2014 2:40:28 PM	ClientUI	Info	Connect status: Disconnected
    3/10/2014 2:40:28 PM	ClientUI	Info	Failed to connect to server, want autoreconnect = 0
    Thanks for the help guys!
    4,350
    Please post a tracert.
    March 2014
    7
    Tracingroute to ts101.light-speed.com [216.127.64.32]
    over a maximum of 30 hops:
    1 1 ms 1 ms 1 ms homeportal [192.168.1.254]
    2 71 ms 27 ms 26 ms 76-217-28-3.lightspeed.yrlnca.sbcglobal.net [76.217.28.3]
    3 26 ms * * 75.20.0.220
    4 27 ms 27 ms 27 ms 12.83.38.149
    5 30 ms 27 ms 27 ms ggr2.la2ca.ip.att.net [12.122.129.105]
    6 26 ms 25 ms 26 ms ae7.lax21.ip4.tinet.net [199.229.231.29]
    7 * * * Request timed out.
    8 * * * Request timed out.
    9 30 ms 27 ms 27 ms . [72.8.181.6]
    10 63 ms 66 ms 63 ms ae19.bbr01.eq01.dal03.networklayer.com [173.192.18.140]
    11 64 ms 64 ms 63 ms ae5.dar01.sr01.dal05.networklayer.com [173.192.18.215]
    12 65 ms 64 ms 63 ms po1.fcr01.sr01.dal05.networklayer.com [173.192.118.131]
    13 65 ms 64 ms 66 ms xe0-0-1.cr1.dal01.light-speed.com [50.22.63.227]
    14 64 ms 64 ms 63 ms 216.127.64.32
    Trace complete.
    March 2014
    I too had the same issues after performing a file transfer though the kick happened only to me and I can't log in to that server on my home network or school! I even uninstalled ts3 with config deleted and still no joy. At first I thought it was a network/internet issue but since I can't connect on three different networks, and this problem is on two different computers (one is my desktop win8, and the other is my laptop win7). I am not banned from the server either.
    Tracing route to ts66.light-speed.com [216.127.64.196]
    1 <1 ms <1 ms <1 ms 192.168.0.1
    2 9 ms 17 ms 12 ms c-69-181-144-1.hsd1.ca.comcast.net [69.181.144.1]
    3 9 ms 9 ms 9 ms te-0-3-0-11-sur03.sanjose.ca.sfba.comcast.net [68.87.197.21]
    4 16 ms 15 ms 15 ms te-1-13-0-0-ar01.sfsutro.ca.sfba.comcast.net [69.139.198.58]
    5 19 ms 27 ms 15 ms he-1-6-0-0-cr01.sanjose.ca.ibone.comcast.net [68.86.90.157]
    6 18 ms 20 ms 20 ms pos-0-2-0-0-pe01.11greatoaks.ca.ibone.comcast.net [68.86.87.10]
    7 16 ms 18 ms 18 ms xe-9-3-0.sjc10.ip4.tinet.net [213.200.80.165]
    8 22 ms 24 ms 88 ms xe-4-3-2.lax21.ip4.tinet.net [141.136.106.189]
    9 * * * Request timed out.
    10 * * * Request timed out.
    11 47 ms 30 ms 24 ms . [72.8.181.6]
    12 29 ms 27 ms 28 ms ae7.bbr02.cs01.lax01.networklayer.com [173.192.18.167]
    13 31 ms 26 ms 26 ms ae0.bbr02.eq01.sjc02.networklayer.com [173.192.18.150]
    14 24 ms 28 ms 37 ms ae5.dar02.sr01.sjc01.networklayer.com [173.192.18.251]
    15 22 ms 22 ms 26 ms po2.fcr01.sr01.sjc01.networklayer.com [50.23.118.133]
    16 24 ms 25 ms 23 ms xe0-0-1.cr1.sjc01.light-speed.com [50.23.109.131]
    17 25 ms 25 ms 23 ms 216.127.64.196
    Trace complete.
    and this is my ping:
    Pinging ts66.light-speed.com [216.127.64.196] with 32 bytes of data:
    Reply from 216.127.64.196: bytes=32 time=23ms TTL=55
    Reply from 216.127.64.196: bytes=32 time=25ms TTL=55
    Reply from 216.127.64.196: bytes=32 time=26ms TTL=55
    Reply from 216.127.64.196: bytes=32 time=24ms TTL=55
    Ping statistics for 216.127.64.196:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 23ms, Maximum = 26ms, Average = 24ms
    Here is my client log:
    3/11/2014 12:11:07 AM Info TeamSpeak 3 Client 3.0.13.1 (2013-10-23 12:10:11)
    3/11/2014 12:11:07 AM Info SystemInformation: Windows 8 (9200) x64 (AMD or Intel) Binary: 32bit
    3/11/2014 12:11:07 AM Direct Sound Debug setting timer resolution to 1ms
    3/11/2014 12:11:07 AM Query Info listening on 127.0.0.1:25639
    3/11/2014 12:11:07 AM Soundboard Info Remote audio toggled
    3/11/2014 12:11:07 AM Info *** Time [PLUGINS]: 224
    3/11/2014 12:11:07 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    3/11/2014 12:11:07 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    3/11/2014 12:11:07 AM Input Info Default monitoring enabled
    3/11/2014 12:11:07 AM Info *** Time [MAINWINDOW]: 484
    3/11/2014 12:11:07 AM Info *** Time [INIT]: 485
    3/11/2014 12:11:07 AM ClientUI Info Qt version: 4.8.3
    3/11/2014 12:11:07 AM ClientUI Info Using configuration location: C:\Users\Censored\AppData\Roaming\TS3Client\settin gs.db
    3/11/2014 12:11:08 AM ClientUI Info Last update check was: Mon Mar 10 03:36:19 2014
    3/11/2014 12:11:08 AM Info Checking for updates...
    3/11/2014 12:11:08 AM TSDNS Info DNS resolve successful, "update.teamspeak.com"=176.9.148.78
    3/11/2014 12:11:08 AM Info Update check, my version: 1382530211, latest version: 1382530211
    3/11/2014 12:11:10 AM ClientUI Info Connect to server: unkso.teamspeak3.com
    3/11/2014 12:11:10 AM ClientUI Info Trying to resolve unkso.teamspeak3.com
    3/11/2014 12:11:11 AM TSDNS Info DNS resolve successful, "unkso.teamspeak3.com"=216.127.64.196
    3/11/2014 12:11:11 AM TSDNS Info SRV DNS resolve successful, "_ts3._udp.unkso.teamspeak3.com"=>"ts66.light-speed.com:8760" = 216.127.64.196:8760
    3/11/2014 12:11:11 AM ClientUI Info Lookup finished: 216.127.64.196 8760 unkso.teamspeak3.com 0 0
    3/11/2014 12:11:11 AM ClientUI Info Resolve successful: 216.127.64.196:8760
    3/11/2014 12:11:11 AM ClientUI Info Blacklist check ok
    3/11/2014 12:11:11 AM ClientUI Info Initiating connection: 216.127.64.196:8760 unkso.teamspeak3.com
    3/11/2014 12:11:11 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    3/11/2014 12:11:11 AM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    3/11/2014 12:11:11 AM Windows Audio Session Debug WAS:: openDevice-enter
    3/11/2014 12:11:11 AM Windows Audio Session Debug WAS Buffer size: 960
    3/11/2014 12:11:11 AM Windows Audio Session Debug WAS:: openDevice-leave
    3/11/2014 12:11:11 AM Windows Audio Session Debug WAS::startDevice-enter
    3/11/2014 12:11:11 AM Windows Audio Session Debug WAS::startDevice-leave
    3/11/2014 12:11:11 AM Windows Audio Session Debug WAS Buffer size: 3840
    3/11/2014 12:11:11 AM PreProSpeex Info Speex version: speex-1.2beta3
    3/11/2014 12:11:11 AM ClientUI Info Connect status: Connecting
    3/11/2014 12:11:11 AM TSDNS Info SRV TSDNS found at "_tsdns._tcp.teamspeak3.com"=>"tsdns.light-speed.com:80" and queried successfully. Result: 216.127.64.196:8760
    3/11/2014 12:11:11 AM TSDNS Info TSDNS found at "teamspeak3.com" and queried successfully. Result: 216.127.64.196:8760
    3/11/2014 12:11:11 AM TSDNS Info TSDNS found at "unkso.teamspeak3.com" and queried successfully. Result: 216.127.64.196:8760
    3/11/2014 12:11:16 AM ClientUI Info Connect status: Disconnected
    Last edited by SilentSadist; March 12th, 2014 at 01:22 AM. Reason: Adding Tra cert
    4,350
    Tracerts are OK, so please contact light-speed and tell them:
    • Their UDP network configuration obviously sucks.
    • Their first (DNS SRV) TSDNS server returns another address than all other services do.
    • Their second (DNS A) TSDNS server's configuration file is in the wrong format and therefore returns a newline as port.
    • Their third (DNS A TLD) TSDNS server returns an empty result (a failed result should be the string 404).
    • They are noobs if it comes to any kind of networking.
    March 2014
    7
    Oh I see, thanks for the help so far.
    So pretty much besides telling them to step up their networking game we are boned?
    No way to fix this on our end?
    2,698
    Quote Originally Posted by Akagi240 View Post
    Try to connect directly to the server final IP and port 216.127.64.196:8760
    does it with same or better result?
    March 2014
    7
    Here's the Log when I try to connect directly to the server IP:
    3/11/2014 4:58:59 AM		Info	TeamSpeak 3 Client 3.0.13.1 (2013-10-23 12:10:11)
    3/11/2014 4:58:59 AM		Info	SystemInformation: Windows 7 SP1 (7601) x64 (AMD or Intel) Binary: 32bit
    3/11/2014 4:58:59 AM	Direct Sound	Debug	setting timer resolution to 1ms
    3/11/2014 4:58:59 AM	Query	Info	listening on 127.0.0.1:25639
    3/11/2014 4:58:59 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    3/11/2014 4:58:59 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    3/11/2014 4:58:59 AM		Info	*** Time [SERVERVIEWMANAGER]: 108
    3/11/2014 4:58:59 AM	Input	Info	Default monitoring enabled
    3/11/2014 4:58:59 AM		Info	*** Time [MAINWINDOW]: 349
    3/11/2014 4:58:59 AM		Info	*** Time [INIT]: 350
    3/11/2014 4:58:59 AM	ClientUI	Info	Qt version: 4.8.3
    3/11/2014 4:58:59 AM	ClientUI	Info	Using configuration location: C:\Users\Julian\AppData\Roaming\TS3Client\settings.db
    3/11/2014 4:59:00 AM	ClientUI	Info	Last update check was: Tue Mar 11 04:57:50 2014
    3/11/2014 4:59:15 AM	ClientUI	Info	Connect to server: 216.127.64.196
    3/11/2014 4:59:15 AM	ClientUI	Info	Blacklist check ok
    3/11/2014 4:59:15 AM	ClientUI	Info	Initiating connection: 216.127.64.196:8760 216.127.64.196
    3/11/2014 4:59:15 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - enter
    3/11/2014 4:59:15 AM	Windows Audio Session	Devel	DeviceDeleteList::waitForDeletes - leave
    3/11/2014 4:59:15 AM	Windows Audio Session	Debug	WAS::openDevice-enter
    3/11/2014 4:59:15 AM	Windows Audio Session	Debug	WAS Buffer size: 896
    3/11/2014 4:59:15 AM	Windows Audio Session	Debug	WAS::openDevice-leave
    3/11/2014 4:59:15 AM	Windows Audio Session	Debug	WAS::startDevice-enter
    3/11/2014 4:59:15 AM	Windows Audio Session	Debug	WAS::startDevice-leave
    3/11/2014 4:59:15 AM	Windows Audio Session	Debug	WAS Buffer size: 960
    3/11/2014 4:59:15 AM	PreProSpeex	Info	Speex version: speex-1.2beta3
    3/11/2014 4:59:15 AM	Windows Audio Session	Debug	WAS::associateAECDevice-enter
    3/11/2014 4:59:15 AM	Windows Audio Session	Debug	WAS::associateAECDevice-leave
    3/11/2014 4:59:15 AM	ClientUI	Info	Connect status: Connecting
    3/11/2014 4:59:20 AM	ClientUI	Info	Connect status: Disconnected
    3/11/2014 4:59:20 AM	ClientUI	Info	Failed to connect to server, want autoreconnect = 0
    Pretty much the same thing. . . . .
    2,698
    I connect without issue:
    11/03/2014 13:12:02	ClientUI	Info	Connect to server: 216.127.64.196
    11/03/2014 13:12:02	ClientUI	Info	Blacklist check ok
    11/03/2014 13:12:02	ClientUI	Info	Initiating connection: 216.127.64.196:8760 216.127.64.196
    11/03/2014 13:12:02	ClientUI	Info	Connect status: Connecting
    11/03/2014 13:12:03	PktHandler	Devel	Puzzle solve time: 14
    11/03/2014 13:12:03	ClientUI	Info	Connect status: Disconnected
    11/03/2014 13:12:03	ClientUI	Info	Disconnected or forced to leave, want autoreconnect = 0
    the server asks me for password but this is once I'm connected (Puzzle solve time: 14)
    This is my tracert:
    Microsoft Windows [Versión 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation. Reservados todos los derechos.
    C:\Users\PotaBlava>tracert  ts66.light-speed.com
    Traza a la dirección ts66.light-speed.com [216.127.64.196]
    sobre un máximo de 30 saltos:
      1    <1 ms     1 ms     1 ms  192.168.1.1
      2    48 ms    47 ms    47 ms  84-18-16-1.usul.arrakis.es [84.18.16.1]
      3    62 ms    63 ms    62 ms  84-18-0-238.usul.arrakis.es [84.18.0.238]
      4     *        *        *     Tiempo de espera agotado para esta solicitud.
      5    61 ms    62 ms    61 ms  t2c2-ge0-0-0.es-mad3.eu.bt.net [166.49.199.105]
      6    75 ms    76 ms    75 ms  t2c2-ge3-0-0.es-bar.eu.bt.net [166.49.195.138]
      7    76 ms    76 ms    75 ms  t2c1-ge6-2.es-bar.eu.bt.net [166.49.164.41]
      8   104 ms   105 ms   122 ms  t2c3-xe-11-0-0-0.nl-ams2.eu.bt.net [166.49.195.0]
      9   104 ms   106 ms   105 ms  t2c4-xe-1-3-1-1.nl-ams2.eu.bt.net [166.49.237.211]
     10   106 ms   106 ms   105 ms  xe-0-1-2.ams20.ip4.tinet.net [141.136.99.85]
     11   113 ms   113 ms   113 ms  xe-4-3-0.ams12.ip4.tinet.net [89.149.180.141]
     12     *        *        *     Tiempo de espera agotado para esta solicitud.
     13     *        *        *     Tiempo de espera agotado para esta solicitud.
     14   111 ms   112 ms   112 ms  . [72.8.181.50]
     15   115 ms   115 ms   116 ms  ae7.bbr02.eq01.ams02.networklayer.com [50.97.18.213]
     16    99 ms    99 ms   100 ms  ae0.bbr02.tg01.lon01.networklayer.com [50.97.18.210]
     17    98 ms    99 ms    98 ms  ae7.bbr01.tg01.lon01.networklayer.com [50.97.18.206]
     18   166 ms   166 ms   167 ms  ae1.bbr02.tl01.nyc01.networklayer.com [50.97.18.204]
     19   186 ms   185 ms   187 ms  ae1.bbr01.eq01.chi01.networklayer.com [173.192.18.132]
     20   187 ms   186 ms   187 ms  ae7.bbr02.eq01.chi01.networklayer.com [173.192.18.171]
     21   213 ms   213 ms   213 ms  ae1.bbr02.cs01.den01.networklayer.com [173.192.18.131]
     22   238 ms   239 ms   239 ms  ae1.bbr01.eq01.sjc02.networklayer.com [173.192.18.148]
     23   238 ms   238 ms   237 ms  ae5.dar01.sr01.sjc01.networklayer.com [173.192.18.249]
     24   240 ms   241 ms   240 ms  po1.fcr01.sr01.sjc01.networklayer.com [50.23.118.131]
     25   240 ms   238 ms   239 ms  xe0-0-1.cr1.sjc01.light-speed.com [50.23.109.131]
     26   241 ms   240 ms   239 ms  216.127.64.196
    Traza completa.
    It seems there is "something" between your public IP and the server itself that is blocking the connection.
    In any case, *.light-speed.com is almost the "number one" with threads in the forum for having connection issues.
    4,350
    It also worked for me (but I didn't know the server password), but there seems to be some kind of address filter for UDP only. There is nothing we can do except for using a system-wide proxy (e.g. Hotspot Shield). However, that can't be a long-term solution.
    Kind of the same problem that this Polish guy had with Brazilian servers.
    March 2014
    7
    Oh yeah, I failed to mention that all my other friends can get into the server no problem. I can also access the server from a computer in another house. Yeah that was pretty dumb of me to forget to mention.
    I downloaded that file (Which finished after I got kicked from the server btw). Got kicked from the server and can't come back. Is there maybe a setting or a network bug that is preventing me from coming back to the server perhaps?
    I also tried going to another light-speed server, and I couldn't get in there as well. . . .
    March 2014
    I'm attempting to interface my router and manually set my primary/secondary dns to see if this helps any. Will post up with results in a bit.
    Okay, so I reassigned my primary and secondary dns according to NameBench's recommendation for optimization. While the dns configuration was a success, my ability to connect to the ts3 server remains a failure.
    March 2014
    OKAY WOO HOO. I got this fixed!
    So go to this link to talk on chat live: https://cp.light-speed.com/live_chat...ight-speed.com
    I told them I had issues connecting to my clan server after a file transfer. They asked me for the server IP:PORT, and verified I was firewalled. They were able to take me off the list in 30 seconds.
    So yeah, considering Akagi and I had the same issue with the same server host, I would bet fair money that this will solve Akagi's problem.
    March 2014
    7
    Thank you Silent, the support seems to be closed as of now, but I will try again in the morning. Thank you for the heads up!
    March 2014
    7
    Went to chat support just now and after I explained my situation to the support guy, he asked for the address of the server which I gave. He then told me that address I had was incorrect by saying the port # was different then what I put down (Though i'm sure I was using the same address I always type). When I asked how it could be different after I downloaded that file he said he was not sure. Still putting the new port # in fixed everything and i'm back to the server. I don't know if I was just being daft, but this seems like a easy problem I just didn't figure out hahaha.
    Anyways THANK YOU SO MUCH Silent!! you are a life saver!! Also thanks everyone else who took the time to help out. Much appreciated!
  1. Replies: 1
    Last Post: July 17th, 2015, 10:13 PM
  2. Replies: 1
    Last Post: September 28th, 2014, 08:07 PM
  3. Can i speed up the file transfer rate speed in TS3?
    By KEVN38 in forum General Questions
    Last Post: April 5th, 2011, 12:04 AM
